Bush LED40127FHDCNTD No Picture
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Hi, I have a Bush LED40127FHDCNTD
    The TV powers on, and backlights illuminate solid, for a few seconds, but no image is diplayed, and after a few seconds the backlights become dimmer, and flicker exceptionally fast, like a strove light effect. No image is ever displayed on the screen.
    If I unplug the ribbon cable from mainboard to tcon/driver board, the backlights still act in the same strobe like manor, they do not stabilise
    Any advice greatly appreciated
    • 12151
    • U.S.
    Re: Bush LED40127FHDCNTD No Picture
    Seems like the usual backlight circuit issue, either bad connection or bad led/s.
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Would that affect the no image problem also??
        • 12151
        • U.S.
        Good question, maybe unplug the backlights at powerboard, look at the screen with a flashlight hit menu etc. see if you see any text or anything on screen.
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          Ill give it a go.
          Just Ive been reading through some old threads where people have described the flashing backlight issue, but they still had an image, and could navigate through menus etc, where as I get nothing.
          Would there be any point illuminating the backlights with LED tester to see if they still flash? Or would that be pointless?
            • 12151
            • U.S.
            The tester might tell you if you are getting the proper voltage from the leds.
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              How would I go about testing using this plug with being 6 wires?
                Beside the flickering backlights, it should not affect the T-CON function to produce the image on the screen. Did you check to see if you do have 12VDC at both ends of the T-CON fuse with ref. to the chassis gnd?
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  Yes m8 I did, steady 12.36v both sides
                  Dont know if its relevant, but there is what I would describe as a fluttering noise coming from the blue one on powerboard, I would say in sync with the flashing backlights
                  • Bloopeta
                    • Jun 2018
                    • 526
                    • United Kingdom
                    Again, not sure if this is relevant but when TV firsts starts up, the screen illuminates brighter as you would expect and lights are steady, but no image, then after a few secomds dims down, and you get the pulsating/strobing backlights, which, the strobing tbh isnt so visable looking at the screen, its more noticable as I have the back cover removed and can be seen through the holes in the chassis from the rear.
                    I have tried to capture it in a dark room in the following attached pictures. Please note the 1st pic, when the screen is bright and steady, its not multicoloured, its just the usual grey you would expect as normal, but for some reason my camera shows colours lol
                    • Bloopeta
                      • Jun 2018
                      • 526
                      • United Kingdom
                      I have stripped this down today, this is the first time I have came across a TV with backlight set up like this.
                      So all the backlights are lit, just with a strobe light effect. Have checked all the plugs and connections, no change.
                      What is the best way to go about testing these in the correct manor?
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        Also, just having a look on the underside of the powerboard, and came across this bit, does that look strange to anyone? Or would that be normal???
                        • Bloopeta
                          • Jun 2018
                          • 526
                          • United Kingdom
                          Do these readings look ok?? Readings taken with TV turned on and backlights strobing
                          Backlight Plug
                          1. 86.1v fluctuates up to 88.2v and down to 80.7v
                          2. 17.1v
                          3. 16.7v
                          4. 80.7v fluctuates 80.9v
                          5. 23.8v fluctuates 24.0v
                          6. 16.7v fluctuates 16.8v
                          Plug to Mainboard
                          1. 24.9v
                          2. 0v
                          3. 0v
                          4. 0v
                          5. 03.01v
                          6. 0v
                          7. 00.6v
                          8. 0v
                          9. 05.5v
                          10. 12.4v
                          11. 05.5v
                          12. 05.3v
                          13. 12.8v
                          14. 12.4v
                          15. 25.1v
                          16. 03.3v
                          17. 03.4v
                          18. 03.3v
                          19. 0v
                          20. 0v
                          • Bloopeta
                            • Jun 2018
                            • 526
                            • United Kingdom
                            Anyone??
                            • Bloopeta
                              • Jun 2018
                              • 526
                              • United Kingdom
                              Also, when inspecting the tcon/driver board, this capacitor cd7 looks a bit dodgy
                              • DXseekerMO
                                TCL 55US57 backlights, no picture.
                                by DXseekerMO
                                So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                                The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                                Power Supply, main and T-CON board are working.
                                Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                                Unhook FFC from left side...
                                09-18-2021, 03:56 PM
                              • sordids999
                                SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                by sordids999
                                Hi
                                Really stuck on this TV
                                I'm thinking it's a bad screen ?
                                Voltages all seems good
                                Tcon 12v ok
                                Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                even tried the tape trick still no luck
                                Thanks...
                                05-12-2025, 10:36 AM
                              • stinger
                                Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                by stinger
                                When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                04-17-2024, 03:06 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
