phillips 42PFL5432d/37 TV no sound
  • R_J
    • 9624
    Re: phillips 42PFL5432d/37 TV no sound
    Look at the picture in post 19, I labeled the pins, If you look closely at the pc board, you will see what looks like a crack, it goes from the edge of the board, through the hole for the jack alignment pin, and ends at pin 6. the trace from pin 7 is likely cracked and the crack will need to be repaired.
    • dsm482
      • Dec 2019
      • 39
      damnn..
      I will try to soother a bridge between 6 and 7 right there on the board.
      and see if it works.. if crack interferes I would get a new board.
      damn you got eyes holy shit
        Did some one work on this board before? There must have been impacted some how to crack the board like that.
        • R_J
          • 9624
          If the crack is where I pointed it out, simply shorting pins 6 & 7 AT the jack will not fix it, you need to run a wire like I suggested
          Soldering across 6 & 7 will not have an effect because the crack is between the headphone jack pin7 and the 14 pin plug.
          • dsm482
            • Dec 2019
            • 39
            ITs fixed..
            Thank for your information.. crack was not bad, but I still put wire across it .. it worked both ways. Got sound and works great. I never used headphone jack since new.
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • JDC
              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
              by JDC
              ONN 100012588
              Issue: No Power, Then Rebooting After Main Board Change
              Short answer: replace main board and power board
              Technical answer: replace main board and Q306 & Q307 on power board.
              Long answer:
              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • mrautom8
              Samsung TV UN75H6350AFXZC main board schematics?
              by mrautom8
              Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
              Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
              While relay is on, all voltage rails are present and steady (scoped) on main board.
              I love a good logic puzzle but getting lost without any schematics.
              No shorts on ANY capacitor main board.
              Thermal camera shows 3.3V inductor getting warm instantly but...
              10-19-2025, 06:32 PM
