Re: Hitachi 50HYT62U no picture
I camt seem to locate any test points on the driver boards themselves, nor a fuse??
Thats not to say they arent any, its just everything is that small, and my eyes arent the greatest lol
Need to locate Voltage test points on those board and start checking Voltages. Start by looking for 12V input and the fuse.Leave a comment:
I do not expect any of those ceramics cap to show <100 Ohms.Leave a comment:
So Ive tested all caps on those boards, they were all between 50 and 120Leave a comment:
Always do resistance check when power is not applied, i.e. unplug the TV or what ever you are working on from any power source.
BTW. you do know how to replace SMD parts, correct?Leave a comment:
If you see any that are noticeably lower than the others you will know, last ones I measured were pretty much over 100 on 200 setting.Leave a comment:
Put ur meter in ohm mode check and see if any read very low ohms, one probe on each side of cap, doesn't matter which way around.Last edited by nomoresonys; 12-13-2019, 02:04 PM.Leave a comment:
There are many caps on those boards, you have done them before in other threads, did you not?Leave a comment:
Yep those are the driver boards.Leave a comment:
by mecha1166KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
by KYBOSHPicked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
No picture but you hear the TV static (white noise) playing loud and clear.
The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
But it seems they didn't get too far and just left it.
When I first took a look I was amazed at how pristine the inside looked.
Its as if the TV had been in a time capsule.
Caps looked like they were just pulled off the self.
Copper coils had no sign of corrosion on... -
by DXseekerMOSo here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
Power Supply, main and T-CON board are working.
Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
Unhook FFC from left side... -
by sordids999Hi
Really stuck on this TV
I'm thinking it's a bad screen ?
Voltages all seems good
Tcon 12v ok
Remove one tcon cable at a time no half image on the screen just backlight and no picture
even tried the tape trick still no luck
Thanks... -
by stingerWhen I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
- Loading...
