Panasonic TX-55CX400B backlights flashing on and off
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Panasonic TX-55CX400B backlights flashing on and off
    Just an update on my repair x5 leds out which I replaced due to you cant buy any new sets anywhere
    But only issue now is I cant get any panasonic remote to work I have even replaced the sensor but no luck
    Any ideas
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Obvious question that the batteries are OK. Does the sets led indicate that the remote has been pressed.
      • sordids999
        • May 2013
        • 2161
        • uk
        Yes tested the batterys and there fine tried a few panasonic remotes but no luck
        And nothing on the led sensor to show the remote is working at the present time I'm having to use the side controls
        • nomoresonys
          • 12276
          • U.S.
          Strange, wonder if the ir sensor replacement is bad.
            You can check the IR OUT of the IR receiver module with DC Voltmeter, you should see it changes when it receives the IR signal from the remote, but this test does not verify if it is putting out the correct signal or not, it just shows the activity.
            • armoured_smiler
              • Sep 2008
              • 13
              Hi, Please can you tell me how did you stop/not get the 'white halo effect' when putting theLED backlight lens back on?
              Originally posted by Judderz
              Hi guys sorry jump on this thread but it's the only one with my TV
              (Tx-55cx400b)
              I'm waiting for a few bits to arrive to test properly, the screen was blank so I've done the strip down and checked and I have 3leds out (fingers crossed that is the only fault)
              • Chrissygizmo
                Panasonic TX-48CX350B backlights but white screen , blank screen
                by Chrissygizmo
                Hi all, I’ve got a problem I hope someone can help me fixi.
                I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                01-11-2025, 03:18 PM
              • hidperf
                Samsung UN60H6203AFXZA steady flashing backlights
                by hidperf
                After spending unknown hours searching the web, I keep ending up here so I'm hoping someone can help me with my problem.
                I did find this thread https://www.badcaps.net/forum/showthread.php?t=69298 but the OP didn't report back on his results.
                As the title says, I have a Samsung UN60H6203AFXZA and as soon as I plug it in, the LED backlights begin to steadily flash. The TV does not power up that I can tell. I get no boot-up sequence or sound.
                Power supply board is BN44-00775A. I don't see any bad caps or signs of excessive heat anywhere on the boards....
                01-05-2020, 05:10 PM
              • rddube
                LG 50lb6100 flashing backlights unsusual fix!
                by rddube
                Thought I'd share this find for the repair of an LG tv which had started to turn on but would only get flashing backlights. Backlights would flash at a few second intervals, and when I opened it, noticed that only the 3 bottom rows were flashing, the 2 top rows were completely dead. Replaced a few burnt leds (tested with my led tester), put everything back together, tested all led strips and they were all good, but again the 3 bottom rows would go into this flashing cycle.
                Read all the discussions on the web and on Badcaps (wonderful forum!!) and...
                03-16-2022, 05:46 AM
              • Andre Gilbert
                by Andre Gilbert
                11-20-2024, 08:52 PM
              • Chrissygizmo
                Polaroid p49fn0038k backlights flashing split second
                by Chrissygizmo
                Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
                When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
                Any help would be greatly appreciated
                Thanks in advance
                11-10-2022, 10:30 AM
