Sony KDL-46ex520
  • Global Safari
    • Nov 2019
    • 32
    Sony KDL-46ex520
    Hello Everyone,
    I am new to the group and trying to figure out some voltages.I am in the
    process of troubleshooting a voltage issue.I am trying to figure out where a certain voltage comes from.In the picture that I have attached it shows 12.35 volts at pin 1 of CN6001.My question is,that voltage generated from the main
    board in the picture, or is it a direct voltage from my power supply board.
    If so, where can I check to see this voltage on my power supply board.Power
    supply board has no markings of voltage reference points. The tv I am working
    on has no 12.35 voltage at that test point.
  • neilc6
    • Nov 2015
    • 1550
    Re: Sony KDL-46ex520
    The 12V for the tcon is generated on the power supply board and switched through the main board. You should give a more general description of the problem you are trying to fix and pics of the entire back of the tv and power supply board. The 12V will pass through a fuse on the tcon that should also be checked. Sonys typically flash diagnostic blink codes if you count the number of blinks.
    • Global Safari
      • Nov 2019
      • 32
      Thanks for the reply.I have uploaded more pictures of the back showing the
      boards.Led blinks 5 times then loops again.As I mentioned in the first thread
      there is no 12 volts at that Pin..that 12 volts get sent to the T Con board.
      Since that is not present, thats why I am getting the 5 blinks.
        • 12210
        • U.S.
        Do test #3 below since the board has no legend just put down the number of the pin followed by voltage in standby (tv plugged in but off) and the voltage when you hit the power button, maybe we can try to figure out what's up, might not be easy.
        • Global Safari
          • Nov 2019
          • 32
          Will do.Will be back soon. Thanks.
            • 12210
            • U.S.
            This sony probably has pullup resistors, try with tv unplugged from power, unhook cable from powerboard to mainboard, leave unhooked, plug power cord into powerboard, see if backlights come on and stay on, that is if they are not on at present.
            • Global Safari
              • Nov 2019
              • 32
              Okay..took voltages at standby by and with power on( found out that wire harness from main to power board has issues).
              Also I tried the step in your last reply..no backlights
              PIN 1 Standby PIN 1 Power on
              O VOLTS DC 0VOLTSDC
              PIN 2 PIN 2
              0 Volts DC O Volts DC
              PIN 3 PIN 3
              3.3vdc 3.3 VDC
              PIN 4 PIN 4
              0VDC 0VDC
              PIN 5 PIN5
              3.3 3.3
              PINS 6 -11 PINS 6-11
              12.5 12.5
              PINS 12-14 PINS 12-14
              0VDC 0VDC
              Left side is standby..right side is with the power button pushed. No change in voltages from standby to power on. Sorry for the numbers close to each other.
                • 12210
                • U.S.
                Ok, be CAREFUL on this test, with everything hooked up, it's testing the big filter capacitors on powerboard, looks like you have 3 of them, the ones that say 450 volt, KILLER voltage, with tv in standby meter on 600 dcv, negative probe on negative side positive probe on positive side, should get about 160 v in standby, then power up tv, should be about 400 v or a little less, only touch the capacitor legs with the meter probes, keep hands well away.
                • Global Safari
                  • Nov 2019
                  • 32
                  I only have 2 on my board.In standby and power on, I get 393 vdc.
                  Scratching my head on this one.
                  • neilc6
                    • Nov 2015
                    • 1550
                    Check for blown fuses on the main board.
                    https://www.badcaps.net/forum/showthread.php?t=66995
                    • Global Safari
                      • Nov 2019
                      • 32
                      Hi
                      Can you tell me from what I have tested does it point to the
                      main board?
                        • 12210
                        • U.S.
                        Not sure, maybe check diodes D6602, D6603, D6604, so what's going on with the wire harness? do any of the connector ends look burnt, you can check it for continuity, just be careful not to expand the connector ends.
                        • Global Safari
                          • Nov 2019
                          • 32
                          On the power supply board or the main board?
                            • 12210
                            • U.S.
                            Maybe check those big capacitors again with cable from powerboard to mainboard unhooked.
                              • 12210
                              • U.S.
                              Unhook it from both and check harness for continuity from end to end.
                                • 12210
                                • U.S.
                                I've used stripped bread ties to put in the ends, when meter probes are too big and to keep from stretching connectors out of shape.
                                  • 12210
                                  • U.S.
                                  Maybe check pin 3 and pin 5 again, with everything connected, see if one of them changes voltage when you toggle the power on and off.
                                    • 12210
                                    • U.S.
                                    Those diodes are on the powerboard.
                                      • 12210
                                      • U.S.
                                      If we knew what pin 1, 2 and 4 was for it would be easier or had a schematic.
                                        • 12210
                                        • U.S.
                                        Maybe take the powerboard out and check underside for bad/cold solder joints, sometimes they look ok but can be loose, look closely at anything on a heatsink and the transformer legs joints, they take the most abuse, be very CAREFUL not to touch the HOT parts, they can hold a BIG charge for quite a while.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • delpiero3
                                          Sony Vaio SVS MBX-261 board failure
                                          by delpiero3
                                          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                          Nevertheless, let's say, i don't come as a total beginner.
                                          I have this old laptop, which suit perfectly my needs, with the...
                                          10-29-2024, 06:16 AM
                                        • huj3r
                                          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                                          by huj3r
                                          Hi there!
                                          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                                          Photo of the situation after the black shadow dissipates:
                                          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                                          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                                          > This indicates HFR Communication error. [ HFR Communication...
                                          08-15-2023, 10:55 AM
