LG 50LF561V LEDs
  • nomoresonys
    • 12323
    • U.S.
    #41
    Re: LG 50LF561V LEDs
    The 2835's are a lot brighter than the older 3528's, no doubt why people are getting bright spots, specially noticeable when replacing single leds.
    • diif
      • Feb 2014
      • 6978
      • England
      #42
      The ones I use are of a similar brightness but the colour is slightly off.
      Having looked at old ones under the microscope, they are cracked and discoloured and moments away from death.
      • angelos
        • Dec 2012
        • 573
        • South Africa
        #43
        Yes, take it from me. Replacing individual LED's is the lazy mans way of doing things. I had plenty comebacks because the remaining LED's failed soon after my repair. It's a pain but you have to replace all the LED's.
        • Bloopeta
          • Jun 2018
          • 526
          #44
          No one mentioned only replacing the failed LEDs, all I said was, I didnt want the whole strips, I wanted the individual LEDs to replace them all, as it is more cost effective
          • diif
            • Feb 2014
            • 6978
            • England
            #45
            I'd want to ensure I could align the lenses correctly before replacing all 45 LEDs, they are a pain, with bright spots on the LCD if they aren't.
            • Bloopeta
              • Jun 2018
              • 526
              #46
              Yeah I know m8, learnt that the hard way with the first ever one I did, had to strip it all back down amd re align a couple.
              Tbh even if I was only changing a couple of LEDs in this particular set, I would still have to realign alot of the lenses, as they are very poorly adhered, the slightest knock and they fall off. There was already one loose inside the chassis when I stripped it, and on the strips that had to be removed with bad LEDs they all fell off when pulling the strip away from the cassis, I would hate to think I went to all the trouble and one or more were to drop off in the near future.
              Ive never came across a set before where the lenses have been so loose, not sure if they are just poorly adhered from factory, or if the adhesion has degraded with time and excessive heat perhaps?
              • diif
                • Feb 2014
                • 6978
                • England
                #47
                LGs lenses are like bloody lemmings, look at them the wrong way and off the pop.
                It degrades over time with the heat, loosing it's grip on the little feet.
                • Bloopeta
                  • Jun 2018
                  • 526
                  #48
                  🤣🤣🤣 too true, they big daft things aswel
                  • mc900fthanna
                    Visio M70-C3 LED replacement strips
                    by mc900fthanna
                    So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
                    Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
                    11-28-2022, 03:03 PM
                  • lmcancu
                    RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                    by lmcancu
                    Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                    Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                    Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                    Instead of putting it back together I decided to replace...
                    04-01-2023, 01:11 PM
                  • Firentiosi
                    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                    by Firentiosi
                    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                    The issues are as follows: the...
                    11-27-2024, 12:33 AM
                  • anupkg1985
                    Insignia NS-50DF710NA21 Replacement LED strips
                    by anupkg1985
                    I have this Insignia tv with most of the led's damaged. I'm not able to find the replacement LED strips for the same. The numbers marked on LED strips are -
                    LB-GM3030-GJBETTY504XBBB19. Please find the photo for the same. Can somebody help finding replacement/equivalent led strips for the same....
                    05-02-2022, 04:59 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
