LG 32LC7D No Backlight
  • neilc6
    • Nov 2015
    • 1550
    I repaired this model before with capacitor replacement but this one has a different power supply. I found one bulged 1000uF cap which I replaced.
    TV powers on, flashing front green led goes steady green with no backlight.
    On state skipping GND pins, all DCV
    12V 12.25
    3.4V 3.48
    6V 6.05
    19V 18.4
    3.4_ON 1.52
    6V 6.05
    DIM 3.20
    ST5V 5.09
    I-B 1.72
    ERR 0.03
    I-C 0.07
    ST5V 5.09
    ON/OFF 1.98
    ADC 4.98
    Main filter cap 395V
    Inverter board fuse - good, 24VDC on both sides
    Inverter transformers pins 1-2 380-400 ohm, 1-3 780-800 ohms
    Was going to replace all the caps but decided to test after replacing just a few including the bulged one.
    Edit: found service manual on Elektrokanya. I-C is inverter control and I-B is inverter brightness. Added relevant schematic page.
  • CapLeaker
    Leaking Member
    • 8321
    Re: LG 32LC7D No Backlight
    sounds like the inverter isn't getting the turn on signal. I-C 0.07
    I_C = Inverter control = BLon
    BLon comes from the main board, goes through the PSU and over to the inverter board. Check and see if BLon is actually dead on the main board too.
    If there is still I-C 0.07V on the main board, while the TV is on, then go through the test points for that Inverter Control on the main board.
    • neilc6
      • Nov 2015
      • 1550
      Thanks capleaker. I-C is marked INV ON/OFF on the main board and is probably active high. Most likely bad bga connections on the cpu. TV is only worth $40 and a new main is $20 and it needs $10 worth of new caps. Need to decide I want to break even on it and save it from the landfill.
      • CapLeaker
        Leaking Member
        • 8321
        Look at these test points on the main board first. If there is indeed nothing coming from the main cpu. Try to unhook the BLon pin coming from the main board to the PSU. Then cheat a little using a 1k resistor and jumper maybe the on/off pin to I-C. Turn the tv on and see what happens. All you need is a valid active high more than 1.5V on the I-C pin.
        • neilc6
          • Nov 2015
          • 1550
          Cut the I-C wire and put a 1K resistor from ON/OFF to I-C. Front led flashes green and goes steady as before and backlights come on but no video. At least this confirms the inverter, power supply and backlights are good.
          The schematic isn't an exact match but does show how that pin is driven from the CPU.
            Since you have backlights but no video, then it is has more than BL-ON control problem.
            Do you get the 12V at T-CON fuse?
            32" is not really worth much but for $20 main board, then it is not too bad.
            • CapLeaker
              Leaking Member
              • 8321
              most of the time if there is no BLon, the main IC is at fault.
              • neilc6
                • Nov 2015
                • 1550
                Fixed with a new main board. Found one for $18 but will break even selling the TV after capacitor replacement.
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • lostone
                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                  by lostone
                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                  05-19-2024, 11:40 AM
                • robgerr
                  Asus N580VN no backlight lcd. Main X580VN rev 3.0
                  by robgerr
                  Good morning forum. , This notebook has problems with the backlight being absent. If I shine a flashlight on the screen, i can see the image. I tried to change several LCDs but the same problem. When I disassembled it, I noticed the LVDS connector was a little burned in the backlight pins. I also found oxide in the LVDS connector on the motherboard. I replaced the LVDS cable, same defect. I replaced the LVDS connector on the motherboard, same problem. I took some measurements on the pins (I used the boardview of the X580VD).
                  pin 36,37,38,39 19,40v
                  pin 35 no connected
                  pin...
                  07-23-2024, 05:04 AM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
