Sony XBR-49X700D: Vertical Lines
  • lothian
    • Sep 2013
    • 10
    • usa
    Sony XBR-49X700D
    Manuf: 2017
    Yet another post complaining about vertical lines in an LED...
    I have a Sony XBR-49X700D that decided one day to display a black screen and the dreaded "Sony Six Red Blinks". I buried my face in my hands, fully aware that this particular error code typically means either of two things: a failed T-CON board, or (more likely) one or more dead backlight LEDs.
    I did the easiest thing first: I swapped the T-CON board... with no change in status. I heaved a plaintive sigh, and began the onerous chore of complete disassembly of the TV to get to the LED backlight. Sure enough, one of the LEDs in one of the boards tested dead. I replaced the bad LED strip with new. The backlight array works perfectly with no red blink code. However...
    Now the display has vertical lines on both sides and a large swath of grey cuts along the middle (see image). Vertical lines typically are caused by a bad T-CON board followed by a poor connection of the ribbon cable. I swapped the former and re-seated the latter--no change.
    Surely there's some simple thing I've overlooked. I am stumped.
    What causes vertical lines? What else should I check?
    Re: Sony XBR-49X700D: Vertical Lines
    Tab bonding could have been damaged when you disassemble the panel.
    • lothian
      • Sep 2013
      • 10
      • usa
      I have no idea what tab bonding is. But I'm guessing it refers to the hard connection between the many flex ribbon connectors affixed to the panel display. And I'm further guessing a problem with tab bonding is game over.
      In any case, I've jiggled, pressed and yanked on each ribbon at the panel with no apparent effect on the display. So, other than palpation, how do test these things?
      • budwich
        • Jul 2015
        • 3097
        post some pictures of the back of the set so the forum can see how things are connected up. Right now, I would say you have a poor connection between the tcon and main board. From there, start checking "labelled voltages" (ie. pins / connections that are labelled at the connectors). Post those results (ie. pin #, label, measured voltage).
        • lothian
          • Sep 2013
          • 10
          • usa
          The panel must be removed to access the backlight, and I was especially careful when I removed that thing. Nevertheless, the vertical lines appeared after I put the thing back together.
          I have two TCON boards; I've swapped in both with no change.
          At this point, I suspect I damaged three of the panel ribbon connectors--somehow. I cannot believe the panel ribbon connectors are so sensitive you can't breath on them without breaking the bond. I've pressed/pulled on the panel ribbons nearest the vertical lines with the display powered on--there's no change in the vertical lines.
          I remain stumped.
          Oh look... BestBuy has a couple 55" LG 4K TV's for under $500.
          Methinks it might be time to monetize the innards of this TV on eBay...
            • 12196
            • U.S.
            Black Friday cometh soon.
            • lothian
              • Sep 2013
              • 10
              • usa
              Perzactly.
              I'd like to fix this two year old TV. I'd like to confirm this TV is irreparable (i.e., damaged panel). I'd prefer to not spend a few hundred buck on a new TV.
              But my time has value.
              On another subject...
              I read in other forums that the Sony TV "six flash code" is basically a harbinger of death for the affected TV.
              In my case with this XBR-49X700D, it began one day with a dark panel and a "six flash code". My problem morphed from one problem (which I seemingly fixed) to another (vertical lines).
              Oh well.
                • 12196
                • U.S.
                Taping buffer board to panel when switching out led strips, at 3:46: https://www.youtube.com/watch?v=y5d_JkOEBSg
                  • 12196
                  • U.S.
                  Could try cleaning your tcon ribbon cable ends, some use a pencil eraser.
                  • lothian
                    • Sep 2013
                    • 10
                    • usa
                    Did that (sans pencil eraser). Both ends. I disconnected the two short ribbon cables btwn the TCON and panel buffer boards and "cleaned" the ends with isopropyl alcohol and a Q-tip. No change to the vertical lines.
                      • 12196
                      • U.S.
                      Does lvds cable from tcon to mainboard have a good connection and clean? maybe unhook and reconnect it.
                      • budwich
                        • Jul 2015
                        • 3097
                        how is the bottom (top?) edge board designed and connected to the panel? Is there multiple boards on each side or just one per "half"? Picture?
                        • lothian
                          • Sep 2013
                          • 10
                          • usa
                          Two boards, left and right, each with six ribbon cables affixed (i.e., "bonded") to the panel.
                          • budwich
                            • Jul 2015
                            • 3097
                            thanks... the set also has tabs on the side, right?
                            It is strange that the issue shows up "symmetrically" on both sides.... that seems to indicate a problem further up than the panel.... maybe.
                            what happens when you disconnect one cable from the tcon to panel. That side should go "smooth white".
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              When you removed the tcon and also when you replaced it did you lift the tabs on the cable connectors to release the ribbon cables or did you pull out/push in?
                              If you did not lift the tabs to release the ribbon cables them then the cable ends with the gold contacts could be damaged.
                              • lothian
                                • Sep 2013
                                • 10
                                • usa
                                You are exactly correct: I damaged the ribbon connectors at the panel when I flipped the panel over. D'oh!
                                Truly a bummer. I had successfully repaired the source of the "5 blink" code on this TV--a bad LED strip--and in doing so, managed to jostle the panel just enough to break the connection somehow.
                                Oh well... live and learn.
                                • Daren87
                                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                  by Daren87
                                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                  08-13-2023, 03:25 PM
                                • gpo23
                                  Sony KDL-40V3000 - Vertical lines
                                  by gpo23
                                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                  With the new t-con the color are good but there are vertical lines on all the screen :
                                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                  Is there a way to fix the vertical lines on the new t-con ?
                                  Thank you for your help
                                  gpo23...
                                  10-04-2023, 09:11 AM
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • noisykid
                                  Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                  by noisykid
                                  5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                  12-30-2024, 07:15 PM
                                • dustman1747
                                  Sony XBR-65X900H vertical lines
                                  by dustman1747
                                  I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
                                  Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
                                  09-18-2023, 09:05 PM
