LG 47LE5900 no picture
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Hi, I have an lg 47le5900, when you turn on the TV, it starts up fine, LG logo screen comes on as normal, but then nothing, just a blank screen, but a blue line down left side and yellow line down right side, backlights are on
    Have cleaned all plugs n ribbon cables to no avail.
    Any help greatly appreciated
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: LG 47LE5900 no picture
    Bad solder on the main processor under the large heat sink in the middle. It needs to be either reflowed (not a reliable, long lasting option) or reballed (much better option but way more difficult).
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Ill have a look and let you know
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        Reflowed with heatgun, now have picture, but still have the blue and yellow lines on edges, any ideas please?
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          Couldnt get lines to go off, so removed bezel and metal frame from around LCD panel, ran a thin line of black insulation tape down each side, reassembled, now cant see lines and tape is barely visable.
          • Glaval
            Sony OLED XBR-65A8G 4 flashes
            by Glaval
            Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
            01-23-2025, 04:04 PM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • sigmeyer
            43UM7100PLB, no picture but have half picture when i disconnect 1 side of panel
            by sigmeyer
            Like the title says , this is a very interesting problem , never experienced this before so i thought i'd share and maybe get some help on this. So the problem is as such: TV comes on , some gibberish flashes on screen and the screen remains black , the owner of tv said he heard sound. Now i checked some things cleaned all connections first of all so i dont run in a circle. Then i disconnected one of the cables for the panel , and viola, the left side of screen comes on, then i tried to switch it , with left side disconnected and right connected. Same problem persists. I checked some voltages...
            09-09-2021, 10:30 AM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
