LG LM290WW2 No Display MPS6142 Blown
  • m4a2t0t
    • Mar 2013
    • 276
    Trying to find a compatible IC to replace the MPS6142 that is blown on the board.
    34UM60/29UM60/29UM59A EAX67451201 (1.1)
    If anyone has a datasheet for the board or the IC that would be helpful too. I'm not finding anything
    Thanks.
    Re: LG LM290WW2 No Display MPS6142 Blown
    It looks like MPS164?, please verify.
    MPS1642 has less pins.
    • m4a2t0t
      • Mar 2013
      • 276
      Woops it is mps1642 but mine has 14 pins per side
        I do not think your IC is MPS1642.
        Are you sure the last digit is '2'?
        How about the next line, MP33??
        • m4a2t0t
          • Mar 2013
          • 276
          what about
          https://pdf1.alldatasheet.com/datash...S/MP3378E.html
          The second number is MP33, some number, 8, and im pretty sure the last is an E. Unless there are more numbers under the scorched areas.The missing number looks like a 4 in the negative image I added to this post.
          • m4a2t0t
            • Mar 2013
            • 276
            the MP3378E worked
            • Azagalord
              • Jul 2020
              • Ecuador
              Can you help, with some information pls, the MP3378E worked in your monitor that was the only one part that you had to replace?
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                Originally posted by m4a2t0t
                what about
                I believe that these IC's have a design flaw where they burn up in exactly the same place as in the picture above. Worse still is when they burn the tracks away and carbonise the circuit board.
                • jmillado
                  • Sep 2013
                  • 7
                  what about
                  The one with "8E" is not compatible with the burned IC parts. Because the "8E" has 12 pins each side, while the burned IC has 14 pins each side. I have the same problem, identical with the model and burned IC. But mine shows the 3rd number which is "7". So it will be MPS337x "where X irepresents "8" or other number or maybe none.
                  • jmillado
                    • Sep 2013
                    • 7
                    Originally posted by jmillado
                    The one with "8E" is not compatible with the burned IC parts. Because the "8E" has 12 pins each side, while the burned IC has 14 pins each side. I have the same problem, identical with the model and burned IC. But mine shows the 3rd number which is "7". So it will be MP337x "where X irepresents "8" or other number or maybe none.
                    Should be MP337x
                    • jmillado
                      • Sep 2013
                      • 7
                      Should be MP337x
                      My Bad..i don't know how to delete my previous posts. But, I confirmed that the above claim to be COMPATIBLE (MP3378E). My apology.
                      • jimmyfu
                        • Feb 2017
                        Have you been able to find the correct part? This just happened to me and a bit bummed
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          My IC which was a 28 pin IC was an MP3378E and I have the spares in front of me.
                          • pat0te
                            • Oct 2022
                            • 6
                            • spain
                            Hello guys, here another dealing with a blown IC501 (mps3378e) in a LG TV (49lh5100).
                            I'm attaching a pic of my main board.
                            It seems a typical failure of this chip.
                            If any had replace it, please comment experience. I will try to replace it without replacing nothing more to see if works.
                            • TecnicaNTT
                              • Feb 2015
                              • 65
                              • Portugal
                              the MP3378E worked
                              what was the symptom ? my screen has led light but no image. was your the same ?
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • cmlewis89
                                LG 47LB5DF blown power supply board
                                by cmlewis89
                                Hi folks,
                                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                09-03-2024, 07:50 PM
                              • ledbylight
                                M1 A2337 Macbook - No Display, likely due to logic board
                                by ledbylight
                                Hi all!
                                This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                11-04-2024, 06:36 PM
                                Acer Chromebook Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) Chromebook 311 Specification for Upgrade or Repair
                                This specification for the Acer Chromebook Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) boardview and Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) schematic. Our users have donated...
                                09-07-2024, 01:00 AM
