Have a LG 37lh40 with a bad power supply EAX55357701/32 board. tv tries to light back lights but can't - cycles forever. took power board out and bench tested. has 5V, jumper pwr on to 5v and 12V good, 20V good. Have a second power board - it turns on tv - works perfectly, I have checked all caps (ESR), looked for bad solder, checked all xsistors, and no luck, anybody have any experience with these power supply boards ? thanks
eax55357701 repair
Re: eax55357701 repair
Have you checked the dc voltage across the two legs of the 450V 68uF capacitors on both power supplies to see if there is a difference.Willing to help but I'm no expert.Comment
tested both boards - broken board has 162V across C611 (68UF 450V cap) with plug in. with PWR_ON HI = 385V.
good board has 162V across C611 (68UF 450V cap) with plug in. with PWR_ON HI = 377V.
all fuses good. seems like a bad solder joint but don't see anyComment
So does the backlights try to come on at all when using the bad board?
Did you check inverter transformers winding resistances and compared them to the working board?Never stop learning
put small wire on ic301 pin 14 - never moves off 0 volts. I had a good ground (used GRD on main connector - P201). assume the IC301 turns on inv lights (ON/OFF) ? have bad IC301 ?
windings resistance across output of inv xformer were: good board - 22.9 ohms each output - total across both 46.8 ohms
bad board - 26.7 ohms across both - 50.9 ohms
symptoms of set were that it would gradually take longer and longer to turn on (red led indicator on front bottom of set would turn solid blue led). It finally stopped turning on (led front bottom indicator never turns blue - stays red).
seems like main board is telling it to shut down. going to check voltages again on bad board in set.Last edited by ajshoe; 10-16-2019, 11:03 AM.Comment
In your first post you saytook power board out and bench tested. has 5V, jumper pwr on to 5v and 12V good, 20V good."
On the bad board what voltage do you have at Fuse F501 when you power up out of standby.Last edited by dick_barton; 10-16-2019, 11:28 AM.Willing to help but I'm no expert.Comment
earlier posts I was checking and reading voltages on bench. I tested them again on bench - they are correct and constant. The last posts were tested with bad power board in tv. I then plugged in set and then turned power switch on. took readings that I posted - voltages are varying. I thinking now that the power supply can't supply enough current on 12V. Can I load test the 12V and 20V line ?
also - I ohmed the pin 14 to inv on/off - it is good - 1K ohms on both boardsLast edited by ajshoe; 10-16-2019, 01:17 PM.Comment
The board only has one power transformer (LLM-001) to provide always on 5V Standby and the switched 12V, 20V, so you are indicating that the 12V and the 20V are not stable, so are you sure that the 5V Standby is stable since is generated by the same power transformer LLM-001 when connected back in the TV.Never stop learning
Is the variation of the 5V in sync with the variation of the 12V/20V?
May be try heating the power supply board with hair dryer to see all the Voltages will become steady or not.Never stop learning
installed new lm431 - to92 - made lm431 work. installed board and now have solid 5 volts. 12V and 20V come up but cycles to 0 about every 5 secs.
DC voltage at F501 is 377V but cycles to 250V every 5 seconds. observing IC301 pin14 inv on/off - never goes to 3VLast edited by ajshoe; 10-18-2019, 10:07 AM.Comment
It sounds like the PS-ON is going on and off.Never stop learning
Assuming...7 Photos -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by NicktronicHey everyone,
This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
Anybody... - Loading...
