Philips 32pfh4309/88 restart problem
  • Bibu
    • Mar 2016
    • 88
    • Italy
    Hi to everybody, i have a problem with the tv in title.
    The tv reboot it self when i give power to It.
    Sometimes show the Philips logo and restart, sometimes only the backlight on and off.
    There isn't Power led on.
    I opened the tv and i don't see any blow caps or burn PCB.
    I read in other discussion about an upgrade firmware with USB, i just try It without success.the TV restart before start the upgrade.
    I think that in my case Is an hardware problem, what i can check and what are the problems for you?
    Thanks to everybody
  • CapLeaker
    Leaking Member
    • 8325
    Re: Philips 32pfh4309/88 restart problem
    can you post a straight shot, high resolution picture of your main board?
    • yokoono
      • Apr 2010
      • 505
      Last firmware
      http://www.p4c.philips.com/cgi-bin/c...scy=DK&slg=AEN
      • Bibu
        • Mar 2016
        • 88
        • Italy
        Originally posted by yokoono
        I Just try to update the firmware with USB,but doesn't work... The tv restart before start the procedure
        • Bibu
          • Mar 2016
          • 88
          • Italy
          This Is the main board
          • CapLeaker
            Leaking Member
            • 8325
            Aaaah! I see a NAND IC (U405), where the Scart plug is. If you have a programmer like a TL866II or RT809H etc., read the NAND and save the file. Then erase the IC, followed by a blank check. Chances are there are bad blocks on that IC. Copy the content from the old NAND chip to a new NAND chip and reinstall it.
            • yokoono
              • Apr 2010
              • 505
              Procedure
              • Bibu
                • Mar 2016
                • 88
                • Italy
                I know the procedure, but i can't do it.because the TV restare before beginning the update
                • yokoono
                  • Apr 2010
                  • 505
                  Turn on the TV and give it a cooling spray (freeze spray) on the nand memory.
                  • janos6662000
                    Philips 47PFS7509/12 LCD TV problem
                    by janos6662000
                    Hi
                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                    I downloaded original firmware and applied the update, but the problem remained.
                    From a colleague i received a "factory package software" which is a lot bigger.
                    I made another firmware update, but still did not solve the problem.
                    Somewhere on the way the error got worse, because at the moment the...
                    08-12-2025, 12:54 PM
                  • courtcircuit
                    Philips HTS8000 home cinema noise problem
                    by courtcircuit
                    Hello
                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                    Removed each of tyhe boards
                    02-08-2025, 08:22 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • bohaboha
                    PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                    by bohaboha
                    Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                    how to fix it thanks
                    02-05-2025, 09:23 PM
                  • atkallu
                    Philips 58PUS8545 t-con problem or something else ?
                    by atkallu
                    Hello
                    I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                    See the attached image.
                    I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                    But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                    T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                    01-13-2025, 11:23 AM
