Sanyo FW43D25F no power
  • jason424
    • Dec 2015
    • 187
    Trying to help a coworker fix this tv.
    Does not power on, no standby light (which I'm not positive if it even has one). Testing the power coming in to the power board I do get 120v and hear a slight hum/buzz when plugging it in.
    I couldn't find a legend for the connector that goes to the video board. But when testing the pins I get (from top to bottom in pic):
    1: 0
    2: 0
    3: 0
    4: 0
    5: 0
    6: 0
    7: 0
    8: 18
    9: 18
    10: 0
    11: 0
    12: 0
    Unplugging the video board from power board garners no change.
    NOTE: I did take pics of the boards while I had the cables unplugged already.
    I did also test the F602 fuse (not isolated from the board) and it ohms out good. No leaking or bulging capacitors.
    Not sure what else to check before buying a new power board.
  • R_J
    • 9627
    Re: Sanyo FW43D25F no power
    You only checked half the pins, there are 23 pins on that connector, The fault might be a shorted cap on the main board. see this thread: https://www.badcaps.net/forum/showth...light=FW43D25F
    I suspect the power supply is ok if you have 18 volts, which is likely the P-ON+21V point
    • jason424
      • Dec 2015
      • 187
      Ugh, you’re correct. I will check the other side tomorrow. And to check the capacitor it needs to be isolated from the board correct?
      Thank you for pointing out what I missed.
        Check resistance between Gnd and P-ON21V jumper, Gnd and AMP+13V jumper, then check the Voltage between Gnd and P-ON21V jumper, Gnd and AMP+13V jumper. The 3.3V for running the main board is generated on the main board.
        This TV is made by the same people that make Emerson/Magnavox.
        • jason424
          • Dec 2015
          • 187
          Resistance between Gnd and P-ON21V jumper: 0 and slowly increases
          Resistance between Gnd and AMP+13V jumper: 0 and slowly increases
          Voltage between Gnd and P-ON21V jumper: 31.7v
          Voltage between Gnd and AMP+13V jumper: 16.5v
          EDIT: and I did check that C3209 and it ohm'd closed.
            Are you sure that your meter batteries are good due to the fact that those Voltages are reading much higher than normal?
            • jason424
              • Dec 2015
              • 187
              I did try another battery, although the orig was good. And got the same results. I'm trying to track down another meter...have a freebie from Harbor Freight somewhere around here.
              • jason424
                • Dec 2015
                • 187
                With another meter I got:
                Voltage between Gnd and P-ON21V jumper: 31.4v
                Voltage between Gnd and AMP+13V jumper: 16.2v
                Also testing of all 23 pins (with cable from power to main disconnected):
                1: 0
                2: 0
                3: 0
                4: 0
                5: 0
                6: 0
                7: 0
                8: 0
                9: 0
                10: 0
                11: 0
                12: 0
                13: 0
                14: 17.7
                15: 17.7
                16: 17.7
                17: 17.7
                18: 0
                19: 27.4
                21: 27.4
                22: 27.4
                23: 27.4
                  https://www.shopjimmy.com/sanyo-a5gv...rial-only.htm#
                  1) Your result does not make sense, you trace the board out you will see that jumper P-ON21V and AMP+13V are connected directly the connector so I cannot see how you can the Voltages on the Jumpers not the same as the connector.
                  2) What Voltages do you get on the jumpers (P-ON21V, AMP+13V) if you have all the boards connected?
                  3) D653, 655A are for AMP+13V
                  4) D650, 651, 652, 659 are for P-ON21V.
                  • jason424
                    • Dec 2015
                    • 187
                    When the boards are all plugged in (power to main cable previously unattached) I get 31.5 at P-ON21V and 16.2 at AMP+13V.
                    I get this same measurement whether I'm checking the main board pins at the connector, or the connector on the power board.
                    I'm not familiar with tracing a board, I'm extremely novice (as you could probably tell).
                    I just re-read the posts and perhaps I'm not testing the "jumper"? I'm testing the pins right at each connector where the cable from main to power board connects.
                    • jason424
                      • Dec 2015
                      • 187
                      budm, is the testing I reported following your instruction or am I doing something wrong?
                      If not testing incorrectly, does the odd voltages point to a faulty power board?
                      Thank you,
                      Jason
