Sharp LC-70SQ15 PWB DPS-206EP problem
    Re: Sharp LC-70SQ15 PWB DPS-206EP problem
    At this point, it looks like the Boost converter is working but the Q7202 is not getting the DIMOUT (pin 11) drive of the BD9488 to drive the Gate to turn that MOSFET on and off to allow the LED current to flow. Check the resistance between GND and the DIMOUT pin to see if it shows low resistance reading or not. You should also test R7299 (connected to pin 11) and also the resistor connected to the Gate of Q7202, also check Q7202 itself.
    • rabitbay
      • Aug 2019
      • 20
      • BC
      Between DIMOUT and GND got 12.5k
      The resistor to the gate R7231 labeled as 2.49k seem ok, with 2.47k
      I couldn't find the R7299 I'm assuming you are talking of the jumper resistance R7229, have 0 as labeled
      Some days ago I removed the MOSFET to test it out, and couldn't find any faults, but just to double check I removed it again, I've attached the readings. Also no continuity between gate and S on any direction
        "Also no continuity between gate and S on any direction"
        It is MOSFET, that is why.
        https://www.elprocus.com/mosfet-as-a...free-circuits/
        No Gate drive for the MOSFET may mean the IC is bad or something is locking out the drive output.
        • rabitbay
          • Aug 2019
          • 20
          • BC
          Yeah!! After trying to test it on ON state, both of the MOSFET was not Closing, so Both MOSFET are OPEN ??
          I will replace them an tell you what happend
          • rabitbay
            • Aug 2019
            • 20
            • BC
            Well, this is not going good, I did changed the MOSFETs and still is in black.
            Still have 0v on DIMOUT not even a peak when I plug to AC, now I'm really lost.
            Ok but now something weird happened, when I connect my positive probe to
            PWM1 or PWM2 the LED's turned ON, well that's a progress I guess, but I thought that the driver DIMOUT was controlled by ADIMM, and Why is this happening, I've attached some pictures, you can see the backlight through the holes
            Can I hook up everything to test it out?
              The Backligts can be dimmed by ADIM (Analog dimming control by varying the DC level), the PWM1 and 2 are for the Pulse Width Modulation dimming scheme by varying the pulse width, it will be setup for one or the other, not both. Most TV use PWM Dimming control. You board uses the word DIMMER and you do have >3V that DIMMER pin of the PD pin, so this one may be using Analog dimmer setup.
              MOSFET Q7201 is for boost converter circuit as explained before and it is OK otherwise you will not have that Boosted Voltage so I do not understand why you replace that one.
                • 12145
                • U.S.
                #27
                Check bottom of board for any bad/cold solder joints.
                • rabitbay
                  • Aug 2019
                  • 20
                  • BC
                  #28
                  Yes I understand that
                  Just in case
                  • rabitbay
                    • Aug 2019
                    • 20
                    • BC
                    #29
                    It reads 45v AC from HOT to COLD just to verify, is that normal?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4318
                      • Italy - Milan
                      #30
                      Hi, you have changed Q7201, but if it was failed also the Rs will be failed, that one connected to pin 11 CS of the IC and to the source of Q7201.
                      • rabitbay
                        • Aug 2019
                        • 20
                        • BC
                        #31
                        I agree with you, I appreciate your answer, do you know some technique to check if it has the right values?, for Rs just by reading the number, but in the other components
                          Q7201 is for the boost converter and you DO HAVE 268V per your post #17 LED boosted Voltage, PWM Controlled Q7202 is the one that is not getting the drive to turn it on.
                          So are you saying now that you no longer have LED boosted Voltage?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4318
                            • Italy - Milan
                            #33
                            Rs is less than 1ohm, don't know how much. Yes i have forgot you have a boosted tension for an instant, have you tested the power diode? It is maybe that one in TO220..
                            • rabitbay
                              • Aug 2019
                              • 20
                              • BC
                              #34
                              I'm thinking to make a video, so I can show you better, because I'm starting to think that I'm misunderstanding some points or maybe or maybe I am misjudging some testings.
                              So some points I'm gonna cover is:
                              Voltage tests on LED pins
                              Voltage peak on LED pins when tv is turned on
                              Returned voltage on each strip
                              PMW effect of multimeter probe when testing pin 5/6 on LED driver
                              • rabitbay
                                • Aug 2019
                                • 20
                                • BC
                                #35
                                After trying to make a small simulation of the OpAmp IC7202, the simulator gave me the same values on pin 3 and 2, but on reality I have very difrent values,
                                PD: I didn't find the TO220
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4318
                                  • Italy - Milan
                                  #36
                                  I mean D7216 if i see well..
                                  • rabitbay
                                    • Aug 2019
                                    • 20
                                    • BC
                                    #37
                                    I remove it to check it out, and it's ok, no short or open on any of both diods
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4318
                                      • Italy - Milan
                                      #38
                                      there was no need to remove it..
                                      • edugimeno
                                        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                        by edugimeno
                                        Hi There!
                                        I'm trying to help my friend who owns a restaurant be just bought.
                                        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                        It's stuck using, I guess, the 2 sided tape that comes with the strip
                                        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                        09-05-2024, 09:34 AM
                                      • adelage
                                        220v Led strip flickering
                                        by adelage
                                        Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                                        I know that the best solution would be to get a voltage...
                                        11-03-2024, 09:49 AM
                                      • benareeno
                                        Adjustable dc power supply and tcl led strip
                                        by benareeno
                                        I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                                        I have an adjustable dc power supply and was trying around 9 volts.
                                        I have a pic of a single diode...where to put pos and neg terminals to light it up?
                                        Pic of middle of strip..is this where i light the entire strip?
                                        And pic of end...or does this light the entire strip?
                                        Where to put pos and neg for single diode..multiple diodes and the entire...
                                        07-11-2021, 02:31 PM
                                      • mikey5791
                                        Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                        by mikey5791
                                        Got this working ips led monitor by the brand of
                                        Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                        Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                        09-04-2023, 03:50 AM
                                      • advant
                                        by advant
                                        02-03-2020, 12:25 AM
