Vizio E32-C1 No Standy Voltage
  • fharris1977
    • May 2017
    • 132
    Hello. I am trying to repair a Vizio E32-C1 dead set. When I plug the set up, I don't get the standby led. So I assumed it was the power supply. Tested it and the standby voltage wasn't present. So I've ordered numerous power supplies (715G6934-P01-001-002H) and all of them have no standby voltage present, even with just the power supply plugged in. Am I getting bad boards or does this particular set generates its standby voltage from a different source. Anyone familiar with this particular set and power supply, your help would be greatly appreciated. Thanks in advance.
    Re: Vizio E32-C1 No Standy Voltage
    Lets see the pictures of your boards.
    https://www.shopjimmy.com/vizio-adtv...upply-unit.htm
    is this your board?
    So the connector of the power supply that goes to the moan board shows 0V on all the pins?
    • fharris1977
      • May 2017
      • 132
      Hi. Yeah this is the board I have. I don't get any voltage for Ps On or any of the 5V lines. I do get all of the 12 volts for the 12 volt lines though.
      • fharris1977
        • May 2017
        • 132
        I have ordered over 4 boards and all of them are reading 0 volts on all the 5V lines.
          Well, that power supply is running.
          Show us the whole back side of the TV so we can see all the boards.
          This power supply only has 12V output, the 5V section is not used so the parts for the 5V power supply section is not stuffed with parts as you can see.
          PS-ON is not used either.
          • R_J
            • 9628
            If you look at the bottom of the board, you will see the +5v is not used, If you have 12v the power supply is working
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              OK. With all Bds connected and screwed down in place, when you plug in the TV to the ac you do not see a stand-by led on. Now when you press the Power button on the TV or the Remote, the TV does not turn ON and the stand-by led remains OFF?
                • 12323
                • U.S.
                • fharris1977
                  • May 2017
                  • 132
                  I have checked plugged the boards up and connected them and I still don't get a standby Led. Could the main board or led strips cause no standby led?
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Did you press the Power button on the Remote or the TV?
                    • fharris1977
                      • May 2017
                      • 132
                      I pressed the power button on the TV. I have to find the remote to see. I was thinking maybe the power switch was bad also
                        • 12323
                        • U.S.
                        Sounds dumb but did you check your power cord or try another one?
                        • fharris1977
                          • May 2017
                          • 132
                          Lol. Yeah I checked it after the first 2 boards didn't work. I'll check that power switch and see if it's getting any power.
                            • 12323
                            • U.S.
                            I can't imagine all your boards having the same problem but on some of these e model vizios the rectifier diode/s short out, causing a dead board. I'll leave this BUT I got my threads mixed up, was thinking you had a completely dead board so this doesn't apply here.
                              Power board is sending the 12V to run the main board, since you do not even getting the Standby LED to come on so you have something going with your main board but I cannot tell you where to check on your main board since we do not have the pictures of the boards.
                                • 12323
                                • U.S.
                                Is your mainboard on this page, go by the sticker numbers as directed: https://www.shopjimmy.com/catalogsea...sult/?q=E32-C1
                                  • 12323
                                  • U.S.
                                  The correct way to test the powerboard voltages is in #3 in my signature bellow, try to do it just as directed, looks like the 5v isn't connected, so don't worry about that one.
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • x_orange90_x
                                    Samsung UN55KU6300F no standby voltage
                                    by x_orange90_x
                                    I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                    Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                    05-21-2025, 09:59 PM
                                  • Bad_IC
                                    Philips TV 37pfl5604h/12 no standby voltage
                                    by Bad_IC
                                    I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                                    These are the voltages in some pins of IC fsq510:
                                    Vcc=18v
                                    D=320v
                                    Vstr=154v
                                    Unfortunately, I couldn't find the schematic
                                    What else could I check?
                                    Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                                    Thank you​...
                                    11-08-2024, 01:07 PM
                                  • Mbd3
                                    Vizio E550i-b2e no standby voltage
                                    by Mbd3
                                    Hi All, I have a vizio e550i-b2e that has no standby voltage. I am hoping some one can help. I am getting 10-14volts bouncing at pin 5 of ic901 (Vcc). According to the data sheet for that ic I need atleast 16v for it to turn on. I did a thermal scan and the only thing that glowed was d901....
                                    03-13-2022, 12:17 PM
