LCD LG (LGP32-08H) repair
  • gorgi991
    • Sep 2019
    • Greece
    ok i own this 32 inch lg
    after 10 years of use it just turned off
    after inspecting the pcb i found a bulged cap
    replaced it,but i still get no lights on the inverter
    while i put the flash on the screen i see an image
    after inspecting the 24v thats supposed to go on the inverter i only get 13
    and weird thing is that on the other side (that controls the mainboard voltage)
    i should get a 12 volt (which i read 7)
    and 16.5 volt (which i read 8)
    and its weird because it seems to function fine (because i get image)
    so what should i do about the inverter?
    and where should i look next?
    thanks in advance
    Re: LCD LG (LGP32-08H) repair
    Please upload good clear pictures of the whole backside of the TV showing all the boards and then the pictures of the whole top and bottom side of the power supply board.
    What does your meter show when you test the Voltage of the 1.5V battery?
    • gorgi991
      • Sep 2019
      • Greece
      i also checked the inverter pcb,it only has 2 caps on it which seems fine and all the other elements,btw when i turn the tv on a blue led lights up on the inverter board and it fades off soon
        12/24 volt compressor cooler box inverter capacitor failure
        This is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
        Found a 47uf@63 volts double the ESR value of a new one
        The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
        The main filtering capacitor was not replaced because I did not have that was not too tall
        Where the 220uf capacitor is some type of switching power...
        08-30-2022, 05:28 PM
      • x_orange90_x
        Vizio E55-E1 bad backlights or bad inverter?
        by x_orange90_x
        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
        I don't know how exactly to test the inverter itself. Is it...
        01-29-2025, 09:24 PM
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
      • valvashon
        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
        by valvashon
        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
        01-04-2024, 01:44 PM
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        11-16-2025, 12:34 PM
