Samsung UN65MU6500FXZA won't turn on
  • Rotorcraft230
    • Jan 2015
    • 27
    Re: Samsung UN65MU6500FXZA won't turn on
    Aw man, LOL, you thanks for helping.
    and thanks R_J and CapLeaker as well.
    Successfully fixed: Sanyo 42" LCD, Sony 52" Bravia XBR9,
    • Rotorcraft230
      • Jan 2015
      • 27
      Originally posted by R_J
      Ok, then that power supply is working like it should.
      Hey R_J, should I be concerned the voltages are higher
      2V for standby
      1V for on
      Mark
      • CapLeaker
        Leaking Member
        • 8146
        I we would be concerned about that, you would know that already.
        • R_J
          • 9535
          I would not be concerned, It is very likely the board is marked wrong. If you look next to that voltage mark it says A13v:12.8V which is the same point
          • Rotorcraft230
            • Jan 2015
            • 27
            Thanks for the reassurance. I’ll get a main board and post back.
            Thanks Mark
            • Rotorcraft230
              • Jan 2015
              • 27
              Re: Samsung UN65MU6500FXZA won't turn on EDIT FIXED
              Just wanted to update the repair on the TV and thanks to
              brandontvparts on Ebay
              he gave me the best price on the main board and shipping was super fast.
              the TV is up and running. Thanks to everyone that helped, you guys are the best and Ill be back on the next one, in the mean time I'll be here reading and learning.
              thanks Mark
                • 12145
                • U.S.
                #27
                Glad to hear it, thanks for follow-up report.
                • brucetv
                  • May 2015
                  • 281
                  • united states
                  #28
                  We are seeing a lot of these coming in with a short in the lower driver board. It's tedious to go through the caps removing them one by one to find the short but it's doable. If your Tv backlights and optical on main board are turning on and off unplug the Tv and remove on ribbon cable going to the panel one at a time. If the backlights and optical stays on then the short is on that side you have disconnected. You have to remove the speaker and the lower driver board cover and test those itty bitty caps. Solder tweezers really come in handy for this job. You can also isolate it since each side has two bottom boards by disconnecting the U shaped ribbon. I am seeing most coming in with 3 green and one blue and the short was always on the blue. It's almost like Samsung had a "Houston, we have a problem here" and shoved a piece of crap board in there just to get by. It's marked BN96-39042A Once you unhook that oddball blue driver board the backlights and Tv stays on fine in most cases if it's not the Main board. Check two caps next to CK2 and CK3 on that blue board. We now save the lower driver boards on damaged panel tv's to get the good caps off them for future repairs. I also tell all my customers to avoid this model like the Covid19 virus because this is happening on 2 year old Samsung's and that's not worth the money SAMSUNG! Samsung engineering>
                    More failed MLCC.
                    Is that SAMSUNG LCD panel, or other OEM?
                    • brucetv
                      • May 2015
                      • 281
                      • united states
                      #30
                      Yes Bud...more crap from Samsung in their quest to do away without a Tcon board it's taking these caps out prematurely. Samsung panel for sure....here's the panel number. It's a pain in the ass repair and we are so busy we don't even do them anymore for fear another one will go out.
                        LCD panel Made in Mexico? I did not expect that.
                        • brucetv
                          • May 2015
                          • 281
                          • united states
                          #32
                          I remember there was a shortage of MLCC's during that production time so I'm sure they stuck some crap MLCC's in there just to get production out. Also explains why there are 3 green lower tab boards and one blue. Really blows for loyal Samsung fans. Please put the Tcon board back in your Tv's Samsung! Jeez. The whole model sucks with it's cheap snap in plastic bezel that is the ONLY thing holding the panel in. Sucks. The CEO's of Samsung should return their end of the year bonus's for spewing out crap like this out of their Mexican plant.
                          • JaredT
                            • Jan 2015
                            BruceTV, you have perfectly described the issue I am having with a UN65MU6500FXZA. I plug it in and the backlight and TV come on for a few seconds, then powers off. If I unplug the mainboard, it stays powered on and lit up. I read this post and saw that I do have 1 Blue and 3 Green lower driver boards. I tested with just the blue one disconnected, and it stays on. I also tried with the blue one connected, and the other side U cable removed, and it stays on. This leaves me wondering if I have the same issue or not. The blue board is marked BN96-39042A.
                            Any help would be greatly appreciated.
                            • colt45lush
                              • May 2016
                              • 17
                              • usa
                              #34
                              I just picked up this exact tv at the curb. Back light doesn't come on and screen doesn't show anything when I use my led tester to power the back light. Disconnecting the cable to the main board the back light powers on. The red led light on the bottom flashes in response to inputs from the select/power button but the optical port doesn't have a red light on inside it (is it supposed to?) Also detaching the ribbon cables from the main board connectors does nothing. Could a EPROM replacement fix my problem.
                              • colt45lush
                                • May 2016
                                • 17
                                • usa
                                #35
                                Also the main board heat sink is warm so is got to be processing something. Any ideas? I'll check back in the morning.
                                • colt45lush
                                  • May 2016
                                  • 17
                                  • usa
                                  #36
                                  It's going to get the hammer and contractor bag trash treatment I guess. Shooting in the dark is not my style. I have not enough experience outside of led strip quick fixes to justify throwing money at something. There is only 2 topics that mentioned this model. Not a lot to go on
                                    • 12145
                                    • U.S.
                                    #37
                                    put pretty much any samsung un65 or un55 model in the search, there's a lot of info here about such.
                                      • 12145
                                      • U.S.
                                      #38
                                      it may take some investigation, can you post some good focused straight on pictures of each board and one of the whole back as to see how everything is connected? can use the go advanced for posting pics.
                                      • colt45lush
                                        • May 2016
                                        • 17
                                        • usa
                                        #39
                                        Ok I didn't know to search outside of my specific model number. Un65 un55 are in the same samsung build style and diagnostics should be the similar. Got it will search some more. I'm lucky it's nice out and I am working on some mowers instead of smashing and breaking down the tv. Lol.
                                          • 12145
                                          • U.S.
                                          #40
                                          here's a good video on testing, I usually suspect a problem on the panel driver board/s, maybe a shorted/bad capacitor or other component, can follow those tests there to try to narrow down the problem, lots of good videos on there: https://www.youtube.com/watch?v=77tymvTJDxo
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
