LG 55LF6000-UB Screen goes white and bright on occasion
  • dman535
    • Dec 2013
    • 16
    I picked up this TV and did an LED replacement. Seems to work fine - then today the screen goes white and gets all washed out.
    Everything when back together fine with the exception of the Tcom board, the chassis was a little different and didn't accommodate mounting - would that cause this problem? It seems to only happen after the tv has been on for a while and is fixed by unplugging it and plugging it back in.
    Re: LG 55LF6000-UB Screen goes white and bright on occasion
    That looks like bad GAMMA Voltage.
    "Everything when back together fine with the exception of the Tcom board, the chassis was a little different and didn't accommodate mounting" What do you mean by that? Some one put something else in place?
    • Diah
      • Feb 2013
      • 6374
      try to had reset with command ( IN_STOP ) to roll back all driver.
      • dman535
        • Dec 2013
        • 16
        I had brand new LED strips installed in an LG 55LB5550-UY but the panel was damaged. I used that chassis to mount everything from the 55LF6000, and it fit fine - with exception of the tcom board at the center bottom. So I let the board float and secured the wires. It didn't appear that the board needed to be grounded or that there was a heat dissipation need - maybe I was wrong.
        • diif
          • Feb 2014
          • 6978
          • England
          I had exactly the same after I'd replaced a gamma IC. I forgot the thermal pad and they are sensitive to heat. Picture was ok for a while then washed out.
          • dman535
            • Dec 2013
            • 16
            The chip I outlined in red is the gamma ic if I am not mistaken. Can I just add a heat sink to it to help dissipate the heat - I have some small ones I picked a while ago.
            • diif
              • Feb 2014
              • 6978
              • England
              I had to replace it again once the picture had gone white, it had failed again. They usually use a thick flexible thermal pad that touches the tcon shield like https://www.aliexpress.com/item/32392804900.html stacking if necessary to touch the shield
              As long as it's not going to short anything whilst attached or again if it falls off I don't see why an aluminium one couldn't be used if you can't use your original shield as part of the heatsink.
              You can measure the gamma voltages on the test points GM1, GM2.. to confirm it is the gamma IC that has failed.
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                I would also add a ground wire from the tcon board to the chassis.
                • dman535
                  • Dec 2013
                  • 16
                  As I am looking over the pictures. I came to the conclusion that the 55LB5550-UY had a shield and the 55LF6000-UB did not. This picture I posted matches what this video screen shot from Shop Jimmy shows. If there is no shield than there is no provision for the silicone pad..am I mistaken?
                  Next steps:
                  Add ground wire
                  Check voltages at Tcon board and replace if needed.
                    • 12196
                    • U.S.
                    Looks like you have the right conclusion, no shield required, one question is are the screws that hold the tcon in place also used for grounding? Is the chip too hot to touch? maybe check the tcon test points, might just be bad tcon. The tests narrow down the possibilities.
                      • 12196
                      • U.S.
                      Do you mean unplugging power cord and replugging. If so do you do it immediately and it's cleared up even before tv cools down?
                      • dman535
                        • Dec 2013
                        • 16
                        I gave it maybe 2 minutes to cool down before plugging it back in.
                          • 12196
                          • U.S.
                          Ok, so if it takes a while for fault to show up, maybe test those testpoints on tcon when first turned on, make note, then test them after fault shows up, see if you notice a difference on any of them. Would be nice to have a guide handy that told what each of those testpoints should read, would make troubleshooting tcons a lot easier.
                            • 12196
                            • U.S.
                            Tcon here if that is the one you have, click picture to enlarge: https://www.shopjimmy.com/lg-st5461b...-con-board.htm
                            • dman535
                              • Dec 2013
                              • 16
                              I added grounds and updated firmware on the TV. You can see the difference in the chassis to the board. Not how I usually want to do things, but thought ripping off the brand new LED strips from the old chassis would have caused more problems.
                              Will see if problem reappears, I did not make any attempts at this point to adapt any cooling to the IC.
                                So the two LCD panels are not the same model number, correct since the T-CON mounting holes are not the same?
                                May be one draws more current than the other?
                                I would look up the spec sheet of both panels and compare them.
                                • dman535
                                  • Dec 2013
                                  • 16
                                  All the the components match from the original unit, with exception to the metal backing. Everything fit the same as the original except for the tcom board.
                                  I had already replaced led strips on the 55lb550 and the lcd panel for damaged, so I got the 55lf600 and used all of its pieces with the 55lb550 back.
                                    Like I said, the panel are not the same model that is why the mounting holes for the T-con are not the same. https://www.badcaps.net/forum/attach...7&d=1565543476
                                    You cannot use the T-CON board that was made for LCD panel that its belongs to?
                                    What are the model number of the LCD panel? not the model number of the TV.
                                    You can see the sticker: https://www.badcaps.net/forum/attach...4&d=1565533811
                                    The spec sheet of the LCD panel will give you the electrical specification of the T-CON board which comes with the LCD panel.
                                      • 12196
                                      • U.S.
                                        • 12196
                                        • U.S.
                                        Ok, if I understand it right, your panel is the ub, so you need a ub tcon at least, wasn't there a tcon in the other one?
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
                                        • hcinne
                                          Dell G15 ryzen edition black screen 2 amber 1 white
                                          by hcinne
                                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                          07-23-2024, 07:56 AM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
