Sony xbr-75x940d
  • GAStuntman
    • Dec 2017
    • 65
    Sony xbr-75x940d
    Hi, I have a Sony tv that did not have a mainboard in it. I guess the previous owners took it out. I'm not sure. I bought a replacement main board and installed it. Now I'm getting a flashing orange & green light when I turn on the tv with no sound or picture. I have been researching the tv but all I was able to find is the flashing orange & green light means the tv needs a firmware update. So far, that hasn't fixed the issue. Any suggestions where to start?
  • jetadm123
    • 2169
    Re: Sony xbr-75x940d
    The question that's begging to be asked is that do you have the correct replacement main board? You can try shopjimmy.com to verify what main boards fit your tv and compare the part number(s) of that main board to yours.
    • GAStuntman
      • Dec 2017
      • 65
      Yes, the main board is the correct board and I did order it from shop jimmy
      • Diah
        • Feb 2013
        • 6435
        this is android Sony ... !!! make hardware reset
        Turn off the TV by( pull out the power cord from the outlet )
        Disconnect all sources of signal, CAM-module, router and power cable for a few minutes ...
        On the TV case, press and hold the [VOL-] and [Power] buttons simultaneously (not on the remote control!) ...
        3. While holding down the [VOL-] and [Power] buttons, plug the power cord of the TV
        Wait view seconds until the LED on the TV turns green ...
        Release the buttons ...
        The TV will restart twice and return to the initial setup menu ...
        Perform initial setup.
        you still there on sony new firmware of July 2019 rolled out you can try it after that make reset as above again
        • GAStuntman
          • Dec 2017
          • 65
          Thanks, I will give that a try.
          • Michale32086
            • Nov 2011
            • 1453
            Flashing Green/Orange means you have the wrong firmware..
            I went thru this a bit ago...
            Diah was a big help when I had my issues...
            • GAStuntman
              • Dec 2017
              • 65
              I have tried holding down the buttons and it's still flashing. The firmware should be the right version since I just downloaded it from the Sony website for this particular model tv. As soon as I connected the mainboard and turn the power on, the orange & green light was flashing trying to install the firmware.
              • GAStuntman
                • Dec 2017
                • 65
                I tried it again and it turned green
                • Michale32086
                  • Nov 2011
                  • 1453
                  Do you have an access indicator on the thumb drive?? Something that flashes on and off when it's being accessed??
                  I have worked on a couple XBRs and when I did the firmware update, it took close to an hour to do...
                  I never had luck with the LED TURNS GREEN reset.. But I have update the firmware on a couple units and it worked ok...
                  • GAStuntman
                    • Dec 2017
                    • 65
                    Yes, it turned green and then white and I heard a click and the tv went off with no light. Came back on and started flashing orange and green again. I inserted the flash drive for the firmware after about 45 minutes after the light turned green. After inserting the flash drive. The light is still flashing the same colors but at a slower pace. I can see the flash drive is working because it's red and flashes from time to time but it's hard to tell if anything is actually happening because I cannot see anything on the tv as of now.
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Yea, I would leave it alone as long as possible.. With the flash drive I used, it would sharply flash on and off on access and then would slowly pulse on and off when there was no access..
                      I let it sit until I was sure there were just the slow pulses.. As I said, it took a long time.. As much as an hour..
                      If you have the TV upright and can see the Power LED.. When the Power LED is off for a significant amount of time (5-10 mins) you can try powering the TV on by the remote or the power button..
                      • GAStuntman
                        • Dec 2017
                        • 65
                        Ok, thanks. The flash drive have been running for almost an hour now. It's still pulsing as of now.
                        • Michale32086
                          • Nov 2011
                          • 1453
                          The best indicator will be the TV Power LED.. When it's off for a good while, it will likely be safe to power up the TV...
                          I wish TV's were more expressive when doing firmware updates.. On screen indicators and the like.. Would make it a LOT less stressful..
                          • jetadm123
                            • 2169
                            Did the previous owner ever say what the original problem was?
                            • GAStuntman
                              • Dec 2017
                              • 65
                              no he didn't. It has been over an hour. I pressed the power button and this time the indicator turned white for a few seconds and now it's blinking red.
                              • jetadm123
                                • 2169
                                Is the red light blinking in any type of sequence?
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  don't do any more update or reset to your tv.. your MB and firmware now okay... red flashing or stable.. if stable red it mean went to standby mode... if it flashing you need to count how many time blinking... as it indicate other hardware fault need to check
                                  • GAStuntman
                                    • Dec 2017
                                    • 65
                                    Sorry I'm just responding. The red light is flashing but I'll have to see if it's a sequence or not. I had to turn the tv off due to a thunderstorm in my area.
                                    • GAStuntman
                                      • Dec 2017
                                      • 65
                                      So, when I turned the tv back on today I had the flashing orange/green light.
                                      • nomoresonys
                                        • 12274
                                        • U.S.
                                        Maybe try a different flash drive, seems that the orange/green should be gone if firmware installed correctly.
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • stav242
                                          Sony KD-55X8509C white flashing/pulsing LED
                                          by stav242
                                          I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
                                          On inspection, there was no physical issues.
                                          I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
                                          - this seems to indicate repairing required, done by Firmware update.
                                          so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
                                          Inserted the drive and repowered the TV.
                                          LED changed to white flashing/pulsing ... and it sat there for over an hour.
                                          i was unsure what was happening so repowered the TV and now it just...
                                          01-08-2024, 07:39 AM
                                        • cheeky2
                                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                          by cheeky2
                                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                          01-08-2024, 05:56 AM
                                        • Richi777
                                          Sony KD-49x8505b flashing Red Led
                                          by Richi777
                                          Hello guys , i have one Sony kd-49x8505b with flashing Red Led anyone know common faults or this problem
                                          Thanks in advance...
                                          12-10-2024, 06:57 AM
                                        • joby91
                                          SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                          by joby91
                                          I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                          I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                          I found one chat about firmware on ************** forum but i cannot read the comments.
                                          https://**************/forum/108-114100-1#880537
                                          09-04-2024, 01:34 PM
