Sony xbr-75x940d
  • nomoresonys
    • 12335
    • U.S.
    Re: Sony xbr-75x940d
    Guess it's possible that the download may have gotten corrupted somehow, if trying a different flash drive don't work, I would start over and see what happens: https://www.sony.com/electronics/sup...loads/00016190
    • Diah
      • Feb 2013
      • 6647
      Originally posted by GAStuntman
      So, when I turned the tv back on today I had the flashing orange/green light.
      TV delivered with out MB need to inspect the set deeply. PWB much like Okay. need to consider on this points.
      1- the LED back light. need to check the voltage on LED socket and LED back light driver. post here photo with your measurement on sockets. also notice and report if the back light come on or not.
      2- check the T-CON Fuse and read voltage on both side with it
      3- go down to the Panel taps and disconnected the left side ribbon between T-CON and panel ( left side mean when you stand behind the set) or took out the metal shield which covered the panel Taps and on it there the last small flat ribbon Jumper disconnected it ( to block the feed back SOS signal of the panel in-case hat issue
      if there issue with other hardware the MB will register it and block it to upgrade firmware and i think this is the case we do have here.. try it and report back with details and photos please.
      • GAStuntman
        • Dec 2017
        • 65
        Ok. I will try a different flash drive
        • GAStuntman
          • Dec 2017
          • 65
          I tried s different flash drive but I'm still getting the same flashing light. I'll try a different firmware tomorrow.
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • stav242
            Sony KD-55X8509C white flashing/pulsing LED
            by stav242
            I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
            On inspection, there was no physical issues.
            I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
            - this seems to indicate repairing required, done by Firmware update.
            so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
            Inserted the drive and repowered the TV.
            LED changed to white flashing/pulsing ... and it sat there for over an hour.
            i was unsure what was happening so repowered the TV and now it just...
            01-08-2024, 07:39 AM
          • cheeky2
            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
            by cheeky2
            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
            01-08-2024, 05:56 AM
          • Richi777
            Sony KD-49x8505b flashing Red Led
            by Richi777
            Hello guys , i have one Sony kd-49x8505b with flashing Red Led anyone know common faults or this problem
            Thanks in advance...
            12-10-2024, 06:57 AM
          • joby91
            SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
            by joby91
            I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
            I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
            I found one chat about firmware on ************** forum but i cannot read the comments.
            https://**************/forum/108-114100-1#880537
            09-04-2024, 01:34 PM
