LG55LS4500 picture went bye bye
  • Tim K
    • Jul 2019
    • 16
    • US
    LG55LS4500 picture started displaying dark horizontal lines (alternate picture lines were basically black). Then the next day no picture at all. Now there is basically no picture except for some vertical light gray bands that seem to move across the screen. I opened up the TV and saw no fried caps or any obvious failures. Last year (about 18mo ago) this TV POPPED and went black. I opened it up and found a fried cap. I replaced it and everything was good. This time there is no obvious cause. Backlight works fine. I checked and reset all the ribbons. Nothing. See attached photos. I'd like to fix this TV as it's not that old and it is just used for my kids to play xbox.
    Thanks,
    Re: LG55LS4500 picture went bye bye
    We need to see the pictures of the whole backside of the TV showing all the boards.
    Does it have stand alone T-CON board? If it does, what do you get on the screen if you have only one ribbon cable between the T-CON and the LCD panel connected one at at time?
    • Tim K
      • Jul 2019
      • 16
      • US
      Here is the back panel. I assume you are referring to the two ribbons at the top...the one with the black connector and the one with the white. If BOTH are connected, I get the mostly black screen with the vertical white/grey patches that change location over time. If I disconnect either ribbon, I see the same thing for a second, then it all goes dark and a yellow LED starts flashing on the right side of that orange main board.
      Thanks,
      Tim
        Your T-CON board is under the metal shileld at the bottom center of the TV, you see white flat cable with blue marking.
        Those two cables you pulled ARE NOT cables for T-CON, those are for LED backlights, make sure you put them back on correctly.
        • Tim K
          • Jul 2019
          • 16
          • US
          When I disconnect the white ribbons with the blue tape from the T-con and turn it on, the backlight works but the screen is blank. When the cable is connected to the t-con, the screen gets that grey/white vertical band that moves left to right across the screen (it changes position every couple of seconds).
          Is this a bad T-con, and if so does it need to be replaced or are there parts available cheaper?
            That is not the cable (between T-CON and the Main board) I want you to disconnect, there are two ribbon cables between the TCON and the LCD panel that you need to have one ribbon cable connected one at a time.
            Did you remove the metal shield to get to the T-CON board.
            Pictures of the T-CON?
              • 12201
              • U.S.
              Are you disconnecting both ribbons at the same time? You need to unplug tv, take out one ribbon, plug tv back in try it then do the same other side. (best practice is don't unplug any cables while tv is plugged in) so you unplug tv before disconnecting cable.
              • Tim K
                • Jul 2019
                • 16
                • US
                OK. I didn't see the two cables at the bottom before.
                [yes, I always unplug the TV before doing anything inside it]
                I disconnected one, powered up....checked the screen. right side is white, left side is black with vertical lines. unplugged. reconnected the first, disconnected the other, powered up...checked the screen. left side is white, right side is black with vertical lines.
                • Diah
                  • Feb 2013
                  • 6376
                  i remember on this forum was some one from UK had same issue and it was BGA at main board which he backed his MB and it worked perfectly
                  • Tim K
                    • Jul 2019
                    • 16
                    • US
                    I read some of those threads. I tried heating the back of the chip on the MB but that had no impact. Looking for other suggestions. If I need to replace a board and its cheap enough I'll just do that.
                      Please up load good clear straight shot pictures of the T-CON board so I can locate the Voltage test points.
                      • Tim K
                        • Jul 2019
                        • 16
                        • US
                        Here you go. Hope it's clear enough.
                          The test points that I can see so far are
                          HVDD
                          VDD
                          VGL
                          VGH
                          VIN
                          Vcore
                          VCC
                          VCC18
                          • Tim K
                            • Jul 2019
                            • 16
                            • US
                            HVDD
                            VDD
                            VGL
                            VGH
                            VIN
                            Vcore
                            VCC
                            VCC18
                            Here are some more shots. Hopefully a little clearer.
                              Just check those test points and report them.
                              • Tim K
                                • Jul 2019
                                • 16
                                • US
                                Can you confirm I have the points right? Some of them are unclear which points they are indicating. See below drawing. If I have any of them wrong please let me know.
                                Thanks again.
                                Tim
                                • Tim K
                                  • Jul 2019
                                  • 16
                                  • US
                                  HVDD, VIN and VCC are particularly unclear to me.
                                    You got it right. The bare copper dots are the test points, so you have it on the leg of the component which you can see that it goes to each bare copper dot.
                                    • Tim K
                                      • Jul 2019
                                      • 16
                                      • US
                                      Here are the voltages. Sadly, at 45 I had to find a magnifying glass to see what I was doing....
                                      HVDD: 5.79
                                      VDD: 11.56
                                      VGL: 6.85
                                      VGH: 0.77
                                      VIN: 11.79
                                      Vcore: 1.78
                                      VCC: 3.25
                                      VCC18: 1.78
                                        1) Check the reistance between VGH and Ground to see what you get.
                                        2) Disconnect the cables between T-CON and the LCD panel and see what VGH will be.
                                        BTW, VGL is the LCD minus power supply so it should show as minus reading on your meter, I.E. -6.85V.
                                        Here is some info about LCD Bias power supply function:
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
