LG55LS4500 picture went bye bye
  • Tim K
    • Jul 2019
    • 16
    • US
    Re: LG55LS4500 picture went bye bye
    Originally posted by budm
    1) Check the reistance between VGH and Ground to see what you get.
    2) Disconnect the cables between T-CON and the LCD panel and see what VGH will be.
    BTW, VGL is the LCD minus power supply so it should show as minus reading on your meter, I.E. -6.85V.
    Here is some info about LCD Bias power supply function:
    Sorry, I didn't even notice, but YES both VGL and VGH were actually negative values.
    VGL: -6.85
    VGH: - 0.77
    VGH resistance to ground is 1.52
    With both cables disconnected resistance was the same.
      VGL: -6.85
      VGH: - 0.77
      1.52 Ohms? Start check the caps connected to that VGH pad, you have shorts some where.
      I see caps C182, 183 which are filter caps for the VGH, so remove them to see if the shorts go away or not.
      https://www.badcaps.net/forum/attach...2&d=1564087548
      • Tim K
        • Jul 2019
        • 16
        • US
        When you say "remove them" what do you mean?
          Unsolder the caps.
          • Tim K
            • Jul 2019
            • 16
            • US
            Unsolder the caps.
            How confident are you that the problem lies somewhere on the T-con board? At some point I may just want to replace it for $20 rather than start unsoldering things I can barely see.
              Well, that 1.52 Ohm reading on VGH without LCD panel connected is definitely not right.
              • Tim K
                • Jul 2019
                • 16
                • US
                #27
                At this point I don't mind spending $20 on a new T-con if that's the cause. I'd just hate to do it and that not fix things. Is there any way to rule out there being a problem on the other boards?
                • nomoresonys
                  • 12274
                  • U.S.
                  #28
                  Well did you check the caps for shorts ala post 22??
                    So you are willing to spend $20 on KNOWN GOOD WORKING T-CON (make sure to match the bar coed sticker numbers not the white silkscreen printing on the board) on 55 inch TV, then just do it.
                    I gave free guide troubleshooting steps by step to get to this point at no charge which is worth a lot more than $20.
                    We know that the backlights is working and the main board is sending the command signal to turn on the power supply and the backlights circuits, that is all we know at this point.
                    • Tim K
                      • Jul 2019
                      • 16
                      • US
                      #30
                      It's not that I don't appreciate the help, or that $20 is nothing....it's just I don't think I can proceed any further. I was able to remove and replace a ceramic disc capacitor last year without any problem, but I don't have the precision tools or the dexterity to unsolder 2 tiny caps. Even if I managed to remove them without damaging the board, I don't think I would ever be able to solder them back in place.
                      • nomoresonys
                        • 12274
                        • U.S.
                        #31
                        Ok, test the caps on the board, see if they read shorted.
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • CyberPhoenix
                          Issue with picture quality of Sony bravia TV
                          by CyberPhoenix
                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                          01-22-2024, 02:08 AM
