Sony White Screen (after move)
  • r2d2leboss
    • Aug 2014
    • 16
    • France
    Hello all,
    I moved my TV and there has been a kind of "split inside". Now I have a kind of white screen. I can see a bit my movie.
    It is a Sony Bravia 55XF90.
    In general, do you know if it can be fixed or it is the LCD ?
    • 12330
    • U.S.
    Re: Sony White Screen (after move)
    Not understanding "split inside" can you clarify?
    • Diah
      • Feb 2013
      • 6573
      Sony XF XD series suffer from this because they make the LCD holding round plastic very funny and there distances between LCD and the last sheet. easy way to solve it : take clean dry Micro fasser cloth and massage the screen starting from the middle toward the top and side and down . the white will disappear.
      • Ihandyrepair
        sony 55X850D black screen no front white or red led light.
        by Ihandyrepair
        Hi guys
        strange one
        I have a dead Sony 55X850D
        when plug in, black screen, no front white or red LED, no back light no screen
        Voltages I get
        3.3v LD/power and main board
        reg 12V
        reg 19V
        3.3v on power on pin
        no Tcon on
        no tcon 12v
        no BL_on
        I do get BL_ERR 2.0v
        I tried to bypass it by ground it but still get same symptom
        I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
        or is possible the chip next to...
        08-07-2024, 04:58 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
