Panasonic tx55cr730b no picture
  • Rob0904
    • 57
    • Uk
    Hi. I have a Panasonic tx55cr730b which doesn't display a picture (no start up logo, no menus). It does show a green power light, goes into and out of standby fine. When the green light is on I can hear clicking from the av board. Would thus suggest that the av boards is faulty or a power board issue.
    Any help would he great.
    Rob
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic tx55cr730b no picture
    Do you have all the signals/voltages required by the PSU from the Main Bd.? You seem to have the signal/voltage required by the Main Bd. from the PSU.
    • Rob0904
      • 57
      • Uk
      To be honest I've just had a quick mess about in the back, no major investigation. If I pull any of the cables out of the av board the tv wont turn on at all. So that's as far as ive gotten.
      Clicky av board and normal reactions from the remote.
      I will have to get the multimeter out. So hoping someone may of had the same symptoms as mine and kind of say yeah 99% this board.
      Rob
        We need more details such as if you getting backlights or not, or if the backlights only come on for seconds only, without light source then you will not be able to easily see anything on the screen.
        • Rob0904
          • 57
          • Uk
          Yeah sorry forgot to say back lights come on and stay on. It looks like the back lights change if I press source or tv buttons on remote. It's only slight but something is happening.
          Rob
          • Rob0904
            • 57
            • Uk
            Hi all, changed the av/main board but still getting a no picture and a clicking sound from the new board.
            Still turns on as it should no flashing red light.
            There is two power boards in this tv, if I pull any cable out of the av board the tv doesn't power on.
            Any help would be great.
            • nomoresonys
              • 12097
              • U.S.
              Start with the basics: Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on.
                Lets see the pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
                • Rob0904
                  • 57
                  • Uk
                  Thanks for the replies. I'm at work at the minute but I've had a mess earlier.
                  I can get sound but no picture even doing the the flash light trick. I pulled each ribbon from the tcon board and made no difference.
                  Does this point to the tcon board?
                  I will get pictures up tomorrow.
                  Rob
                    Need to at least find out if the T-CON is getting 12VDC for it to run or not.
                    • nomoresonys
                      • 12097
                      • U.S.
                      Do a quick check of the fuse on tcon board should be labeled Fxx, see if you have about 12 volts on each side of fuse, red probe on one side then the other, black probe on chassis ground.
                      • Rob0904
                        • 57
                        • Uk
                        Thank you, I will get on it as soon as I can might be the weekend now tho....
                        Rob
                        • Rob0904
                          • 57
                          • Uk
                          Hi, my brother managed to get a new tcon board before I have got chance to have a look at the tv. It now has the colour test screen cycling red, green, blue ect...
                          Any idea how to get out of it?
                            Did he match the P/N for the PCB assembly as printed on the sticker NOT the PCB P/N as printed on the board?
                            • nomoresonys
                              • 12097
                              • U.S.
                              May have gotten a mismatch as suggested, did you try unplug tv for a few minutes? If same when you plug it back in, try turning off and on with the buttons on the tv.
                              • nomoresonys
                                • 12097
                                • U.S.
                                Press and hold the TV's power on button for 30 seconds and then release the button. Plug in the TV power cord back into the wall outlet, then try it.
                                • nomoresonys
                                  • 12097
                                  • U.S.
                                  Hold down the power button on the tv not the remote, while the tv is still unplugged for 60 seconds after 60 seconds continue to hold down the power button and plug it in.
                                  • Rob0904
                                    • 57
                                    • Uk
                                    Hi all, just an update none of the above things worked. As we had changed the av board, I got my brother to put the original one back in and hey presto the tv is alive!!
                                    I can send the replacement av board back so not a bad result.
                                    Thank you for all your help and time.
                                    Rob
                                    • nomoresonys
                                      • 12097
                                      • U.S.
                                      Good to hear, must have been a dirty/loose connection or ground or maybe the tv somehow got a proper reset with the replacement board.
                                      • Rob0904
                                        • 57
                                        • Uk
                                        Original av board and new tcon sorted it out.... time to send the spare av board back for a refund 👍👍
                                        Thank you again for the help.
                                        Until next time 🤣🤣
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:18 AM
