LG 55LS4500 No Standby light will not power on
  • RFITTS46
    • 17
    Original owner, several years ago lost audio but used analog outputs.
    No other problems and currently has no standby light and will not power on.
    The Pwr On (3.5V signal back from main brd) is erratic, sometimes there sometimes not. sometimes when connected to mains it is there and 12V and 24V present and across the big caps 380V present. There is a green LED on psu board and it sometimes blinks 5 times repetively.
    Sometimes when connected to mains no 3.5V Pwr On from main board. The 2X 3.5V present from psu board but no 12V or 24V and it reads 179V across the big main caps.
  • RFITTS46
    • 17
    Re: LG 55LS4500 No Standby light will not power on
    when mains connected and no Pwr On present from control board....jumpered 3.5V Std By and the psu board seems to have all voltages present. the big filter caps have 380V across them. I measured 56V leaving the top of the psu board P201 and P203. this must be supplying the LED strips? the board has marked on 78V?
    just looked at what was marked on the board for Pwr On (P201) and it has 24V. Is this the signal sent back from the control board and it should be 24V and not 3.5V?
    • diif
      • Feb 2014
      • 6978
      • England
      Start on page 13, troubleshooting.
      • RFITTS46
        • 17
        3.5V present P403 pin 9
        3.5V present Micom Voltage
        measure X201 clock
        will Fluke 83 be able to measure 24mhz?
        If so this is a two leaded component assume one probe on each should read 24mhz?
        • RFITTS46
          • 17
          okay looks like the Fluke max's out at 200khz. I have an analog 20mhz oscilloscope?
          • R_J
            • 9535
            There are two rows of pins on P201
            pin #1 = PWR-ON
            pin #2 = 24v
            pin #3 = 24v
            pin #4 = 24v
            pin #5 ~8= GND
            pin #9~12 = 3.5v (standby)
            etc.
            Shopjimmy does have a few eeprom's for this model, that might be the problem. If you do order one make sure you get the correct one for your board.
              At this point we need to know what the Voltages are for all the pins of the power supply connector that goes to the main board when TV is off and when power switch is activated.
              We also need pictures of the whole back side of the TV showing all the boards so we can see what we are dealing with.
              "Pwr On (P201) and it has 24V"
              Based on that, Please make sure to count or inspect the pin names and numbers correctly, the connector has Odd and Even number columns.
                BTW, is this your power supply board?
                https://www.shopjimmy.com/lg-eay6251...-led-board.htm
                Other boards:
                https://www.shopjimmy.com/catalogsea...?q=LG+55LS4500
                • RFITTS46
                  • 17
                  P201 on powers supply board, Mains Connected, no standby light on
                  P-Dim2 .04
                  12V .04
                  12V .04
                  12V .04
                  GND 0
                  GND 0
                  3.5V 3.5
                  3.5V 3.5
                  GND 0
                  GND 0
                  PWR ON 0
                  pressing power on .....no change
                  I jumpered 3.5V to PWR ON before I realized it was supposed to be 24V
                  jumpering 3.5V all voltages present. 380V on large filter caps
                  • RFITTS46
                    • 17
                    sometimes when mains are connected the 12V, 24V, and across big filter caps 380V is present. The yellow led blinks 5 times repetitively.
                    when this occurs there is no standby light.
                    it isn't doing it right now.
                    • RFITTS46
                      • 17
                      when jumpering 3.5V to Pwr On the LED strip voltage is 56V. Seems low should be 78V.
                        It also need DRV-ON (BL-ON) for backlights circuit to come on, sometime the Dim control pin may also need to be forced on too.
                        When performing force on you must disconnect the cable going back to the main board first otherwise you can damage the main board, it should also be done using resistors in case wrong connection is made.
                        BTW, you did not report all the pins' Voltages of P201.
                        • RFITTS46
                          • 17
                          budm..
                          jumper 3.5V to Pwr On
                          P-Dim2- 3.5
                          12V- 12.2
                          12V- 12.2
                          12V- 12.2
                          GND- 0
                          GND- 0
                          3.5V- 3.5
                          3.5V- 3.5
                          GND- 0
                          GND- 0
                          24V - 24.8
                          PWR ON 3.5
                          where the LED voltage is only 56V could it be booster circuit?
                            Again, you only report the Odd column (Exposed pins you can see from the top side of the board). The Even column you have to use skinny probe on the wire entrance side of the connector.
                            See the printed chart for pins right next to the connector, as you can see, it has lots more pins than what you are reporting, you can see the DRV_ON (BL-ON) pin and other pins as well listed for the Even column.
                            • RFITTS46
                              • 17
                              P201 on power supply board, Mains Connected, no standby light on
                              P-Dim2 .04
                              12V .04
                              12V .04
                              12V .04
                              GND 0
                              GND 0
                              3.5V 3.5
                              3.5V 3.5
                              GND 0
                              GND 0
                              24V 0
                              PER ON 0
                              ERROR 0
                              P-Dim .139
                              N.C .015
                              DRV-ON .124
                              VSYNCH-IN 0
                              GND 0
                              3.5V 3.5
                              3.5V 3.5
                              GND 0
                              GND 0
                              24V 0
                              24V .017
                              PUSHING PWR ON SWITCH NO DIFFERENCE
                                • 12181
                                • U.S.
                                If you're properly jump starting the powerboard by itself and your voltages are not coming up to specs., I'm thinking you have a powerboard issue.
                                • RFITTS46
                                  • 17
                                  last set of posted P201measurements were taken without jumping 3.5V to Pwr On pin because budm said something about properly jumping the psu board. awaiting proper jumping instructions so no damage is incurred to control board.
                                  earlier threads show proper power supply measurements evident when jumping 3.5V to P201 Pwr On pin.
                                  budm wanted the second row of P201 pins measured.
                                  I thought it maybe best to post non jumpered measurements first.
                                  If it is requested to jumper and provide measurements of second row of P201 will do so.
                                  • RFITTS46
                                    • 17
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      This sounds like a bad backlight issue. He doesn't seem to understand what budm is saying and asking. If you jumped the Std-by 3.5V to the PWR-ON and getting the 12V and 24V. He should leave that jumper in place and make another jumper from 3.5V to DRV-ON. With the Backlights connected. The backlights should com on and stay on if they are good.
                                        Testing power supply/backlights circuits:
                                        1) TV is not plugged into AC outlet. Disconnect the cable between power supply board and the main board, leaving everything else connected.
                                        2) Put resistor (any value between 330 ~ 1000 Ohms 1/4 W or what ever you have) between 3.5V pin and PWR-ON pin.
                                        3) Put resistor (any value between 330 ~ 1000 Ohms 1/4 W or what ever you have) between 3.5V pin and DRV-ON pin.
                                        4) Plug TV into the AC outlet, the backlights should then come on and stay on as long as the AC is being applied to the TV. If the backlights still do not come on then we may have to use another resistor on the Dim control pin, but try the test first to see what happen.
                                        But based on your report (all boards connected) that the PWR-ON pin Voltage does not change state when power switch is toggle, it means you have problem on the main board.
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
