Sharp LC-60LE741E 3 Blinks
+ More Options
Posts
  • london-freddie
    • May 2015
    • 472
    Re: Sharp LC-60LE741E 3 Blinks
    Just freeze sprayed mainboard and tv powered up, however I switched it off quickly as mainboard was not mounted and heatsinked.
    refitted mainboard and now not powering up so looks like a mainboard is needed for this tv
    • london-freddie
      • May 2015
      • 472
      In that case then yes the 5v is there at pin 15 with the mainboard disconnected
      • Diah
        • Feb 2013
        • 6376
        before you go further and lost try "vol+ & ch-" while plugging in the power. the LED indicator should remain steady keep with black screen.. keep it for awhile then press the power keep press until its goes off. then turn on
        • london-freddie
          • May 2015
          • 472
          Thanks Diah just tried vol+ & ch- not worked, not powered up
          • london-freddie
            • May 2015
            • 472
            Not having any luck sourcing a mainboard for this tv yet
            • Diah
              • Feb 2013
              • 6376
              power it gain by freezing the eeprom only.. when the screen come on go to setting to make factory reset
              • london-freddie
                • May 2015
                • 472
                Used all my freeze spray, will try and get some tomorrow and try that Diah
                • london-freddie
                  • May 2015
                  • 472
                  Pic of my mainboard with the covers removed, looks like I need one of these, but can not find one for sale, any ideas where I may get one
                  • london-freddie
                    • May 2015
                    • 472
                    tried freezing eeprom tv not powering up this time
                    • london-freddie
                      • May 2015
                      • 472
                      just warmed mainboard using a hairdriver and tv powered up to a good picture, however before i could get remote to do a factory reset it powered off
                      Now thinking nothing to loose maybe worth sticking mainboard in the oven for ten minutes
                      • london-freddie
                        • May 2015
                        • 472
                        As I write this post mainboard is in the oven @ 190C going to give it 10 minutes
                        • london-freddie
                          • May 2015
                          • 472
                          Mainboard cooked and refitted now led 3 flashes has changed to 2 flashes ??
                          • london-freddie
                            • May 2015
                            • 472
                            I give up on this one
                              • 12206
                              • U.S.
                              #34
                              I think you need around 220 C.
                              • london-freddie
                                • May 2015
                                • 472
                                Thanks for that nomoresonys I will try it again later at 220 C
                                May change my name to nomoresharps lol
                                  • 12206
                                  • U.S.
                                  #36
                                  • london-freddie
                                    • May 2015
                                    • 472
                                    Baked again at 220 C the 2 flashes has now changed back to 3 flashes and no power up
                                    I need a mainboard and can not find one for sale
                                    • london-freddie
                                      • May 2015
                                      • 472
                                      May be easier to find a 60" smashed screen tv with same screen as this and swap out screens
                                      • Diah
                                        • Feb 2013
                                        • 6376
                                        your issue are glitch at firmware ( eeprom ), all user over here only suggust the reset process & freezing could solve temporary to dump eeprom and reflash it on new or at same SIP. not baking cake :-) you still have chance to bring it back to life. don't give up .. write down the SIP No of it
                                        • london-freddie
                                          • May 2015
                                          • 472
                                          Tv is all back together, still not working, But I now notice led blinking has changed again to 1 quick flash then 3 slow flashes
                                          Back to google search again for this fault code
                                          I have had 3 slow flashes, then it changed to 2 slow flashes then back to 3 slow flashes and now 1 fast and 3 slow, maybe it will change to 4 flashes tomorrow
                                          • Egidio85
                                            SHARP LC-40LE814E does not turn on 2 flashes
                                            by Egidio85
                                            hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                            the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                            reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                            now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                            to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                            07-21-2023, 11:49 AM
                                          • joblo37pam
                                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                            by joblo37pam
                                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                            10-26-2023, 02:17 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • JayPoorJay
                                            sharp LC70EQ10U 2 slow, 2 fast blinks
                                            by JayPoorJay
                                            Good morning... I'm new here and have a LOT to learn.
                                            I'm a rescue-er. I live in NYC and I don't even want to get started on the amout of stuff that makes it onto the curb, to be crushed and in a land fill, simply because our repair shops have been sold out and because - well, it's a disposable society... Anywho
                                            I have 1 motorcycle, 3 Jaguars and a Porsche that were all headed to the crusher due to a couple handfuls of needed parts and a Lil Love,,, I'm hooked on the rescue. A member of several forums and a huge fan of DIY environments such as this one. Hats off to you...
                                            01-24-2022, 09:26 AM
                                          • Anzio
                                            Sharp LC60E79u 2 blinks power/3 Blinks OPC
                                            by Anzio
                                            I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
                                            The service manual indicates this as a β€œDET_5V (33pin) error (L). 5V is not applied.”
                                            I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and...
                                            07-03-2020, 01:12 PM
