Samsung UE55KS8090 - Mainboard replacement failed
  • Hauke
    • Jan 2017
    • 78
    Hello guys,
    I bought this awesome 55" Samsung TV. The problem was, that it tried to start but did this indefinitely.
    I found a relatively cheap mainboard from a 65" KS8090 with broken panel and bought it. It is mechanically identical.
    After mainboard replacement the TV started again. I was able to pair the smart remote and I could hear sound.
    The problem is, that the TV does not show the right image. It only shows vertical colored bars.
    The colored bars change with the content that should be displaced on the screen.
    Sometimes they are all over the screen and sometime only in the middle or at one side.
    I flashed two EEPROMs (W25Q40 and W25Q80) with the software from remont-aud: https://****************/dump/crt_tv.../102-1-0-63971
    This dump was from an UE55KS8000. At the moment I can't flash the 24C512.
    But the problem stays the same. The TV works, but the displayed picture ist wrong.
    I attached some pictures of the mainboard and the weird displayed image.
    Has someone any ideas? I don't know what to try next.
    Thanks!
    Hauke
    Re: Samsung UE55KS8090 - Mainboard replacement failed
    So was the TV working correctly at all after you bought it?
    • Hauke
      • Jan 2017
      • 78
      I bought it as defect. The owner said the TV suddenly won't start anymore.
      It tried to start without showing any picture and then shut down and tried starting again. There was no difference if the one connect box was connected or not. And there was no sound.
      Edit: I added some pictures.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Well to be honest this could be 2 things.
        1) Bad t-con ( if available )
        2) Bad panel.
        Did you check the boards connected to the panel for liquid damage? There are people out there that clean tv's with water hahaha.
        • Hauke
          • Jan 2017
          • 78
          @Moreno83: Oh no, that would be very sad..
          There is no real T-Con board like it is in other TVs.
          I asked the seller of the new mainboard and he said, that he also wanted to repair his 55" TV with this mainboard. He told me, that he had vertical bars, too. He thought his panel was dead and so he sold the mainboard.
          Maybe the "new" mainboard is defective? Could this really be caused by a bad mainboard with integrated t-con? If yes I would try to buy a brand new mainboard for about 150€.
          What would you say? Would you risk it?
          • Beau28713
            • Feb 2018
            • 50
            Could it be possible that the 55 inch and 65 inch use different main CPU chips on the main board? Even if it is the same board part number it may be a different revision. This could possible cause the lines.
            • Hauke
              • Jan 2017
              • 78
              I checked the CPU chips. Maybe you are right.
              Both boards use "SDP1501 Jazz-M" chips, but the the original mainboard has a "S4B4PL S1622" and the new board has a "S5K56QD S1730".
              I will try to find the datasheet and look what these numbers mean.
              • Diah
                • Feb 2013
                • 6435
                SDP1501 Jazz-M both same.usually the integrated T-CON located at the panel taps not on the main boards.. back to post #4 and inspect the panel taps this should be the first things you need to do right now.
                • Hauke
                  • Jan 2017
                  • 78
                  Ok, ich checked the panel taps. They looked good.
                  I got a little deeper into troubleshooting. I bought a UE55KS9090 with a broken panel really cheap. I read, that the only difference between my model and this broken unit is the curved frame.
                  I took out the mainboard and put it into my TV. I got these colored lines again.
                  Then I put my replacement mainboard in the TV with broken panel and now this unit displays colored vertical lines too. After putting in the original mainboard the screen was normal again.
                  It looks like the mainboards aren´t exchangeable..
                    • 12268
                    • U.S.
                    Kind of looks like the mainboard you bought is defective???
                    • William1967
                      • Nov 2017
                      • 215
                      • Netherlands
                      Every type of display has it's own screencode, a 65"has another code than a 55" so I guess that's wil be the problem.
                      • Hauke
                        • Jan 2017
                        • 78
                        I don´t really know. The mainboard from the TV with broken panel also creates vertical colored lines in my TV.
                        Yes, but the mainboard of the 55" TV with broken panel does also not work in my TV.
                        After reflashing all EEPROM and Flash ICs on my original mainboard it starts. Now I can hear the starting sound and the backlight comes up. But the panel stays black.
                          • 12268
                          • U.S.
                          Ok, borked firmware strikes again, looks like you're making progress, now maybe try a reset.
                            • 12268
                            • U.S.
                            One reset procedure here, not sure if it will work with your model:
                            While the TV is On, press and hold the EXIT button on the Samsung remote control for 12 seconds. The standby light should blink the entire time without interruption.
                            The Factory Reset screen displays a warning message. Select OK to reset the TV.
                            Also try this one:
                            Make sure that your TV is OFF.
                            Take your Smart Remote and simultaneously press Info + Menu + Mute + Power.
                            Next, enter the following sequence into your remote: Mute > 1 > 8 > 2 > Power.
                            Your television will boot up in service mode. Using your remote, go to Options > Factory Reset.
                            Your television should now turn off and a simple restart should proceed with the setup.
                            This maybe difficult in your case since you can’t see the screen. Samsung has had plenty of issues with firmware updates that bricked their TV’s. You do wnat to go ahead and call the Samsung customer service line for your country and see if they can help you out with the firmware.
                            • Hauke
                              • Jan 2017
                              • 78
                              Thank you nomoresonys! I managed to do a factory reset. I pressed INFO -> MENU -> MUTE -> POWER. After the TV booted completely I pressed OK several times to select the factory reset.
                              Now the TV starts with the initialization sounds, but the screen is dark. The backlight is alright.
                              At this site I found some pictures of the service menu: https://forum.samygo.tv/viewtopic.php?f=94&t=10732
                              There are some configurations about LVDS, T-CON and Panel available in the service menu. I think "LVDS format", "Panel EEPROM upgrade" and "Panel flash upgrade" are interesting. But I don´t know what these really mean...
                              Maybe I will try to call samsung tomorrow. I never had luck with customer support until now, but maybe they can help me.
                              Edit: I found this menu in an other Samsung UHD TV of mine (Picture attached). Maybe this could be the reason? But how to select the right one if I cant see anything..
                              • petehall347
                                • Jan 2015
                                • 4436
                                • United Kingdom
                                is there a setting for panel id number or size ?
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  connect this TV with black screen to other working set via scart cable to take look on the screen what it show you.. even the SM could be displayed.
                                  • Hauke
                                    • Jan 2017
                                    • 78
                                    I will search for it. The only thing I found until now was the panel selection menü.
                                    I never heard of something like this. This sounds awesome.
                                    I checked the one connect box and the mainboard - I can´t find any scart output. Is there an other way to get the video output?
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      your set as other new set with new version of scart cable ( adapter ) you have this adapter plug on the TV
                                        • 12268
                                        • U.S.
                                        The SCART connection may be called EXT RGB on some tvs.
                                          09-07-2024, 05:50 AM
                                        • Mirenia
                                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                          by Mirenia
                                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                          03-30-2025, 06:47 AM
                                        • Akira81
                                          LG 55LF652V-ZA flashing led bars despite their replacement
                                          by Akira81
                                          I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
                                          If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
                                          Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
                                          04-14-2023, 11:50 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • bohaboha
                                          ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                                          by bohaboha
                                          Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                                          04-19-2025, 01:47 PM
