Samsung LN46D630 no picture
  • Bloup101
    • Mar 2019
    • 15
    Re: Samsung LN46D630 no picture
    Sorry obviously I meant the main to the power board. It would be impossible for the backlight to flash with the inverter board disconnected.
    • Bloup101
      • Mar 2019
      • 15
      Here's a pic of PFC IC ICP801
      • Bloup101
        • Mar 2019
        • 15
        I took caps CM809 and CM811 off the board but trying to test them with my my DMM without the capacitor mode is difficult. Sometimes no readings or all over the place.
        • Bloup101
          • Mar 2019
          • 15
          Here's the ICP801 FAN7930B pin out, what is the testing procedure? The power board is out of stock on jimmy...
            Remove the board so you can test the board by itself but you MUST be careful since you will be working in the HOT DEALY side of the circuit so you should at least power the board from GFCI outlet in case you make body contact with the board, you will use 470 up to 1K 1/4W resistor between the Standby power supply output pin and the PS-ON pin then power up the board and see what Voltage you have on VCC pin and the GND pin.
            BTW: Make sure to put the parts you remove back in correctly before doing the test.
            • Bloup101
              • Mar 2019
              • 15
              I found a used power board, problem fixed, thank you.
              • neilc6
                • Nov 2015
                • 1550
                Just repaired this model. Symptom - turns on and off with chimes but no backlight. Alligator clips on big caps show PFC going to about 250VDC on power on and shutting down quickly. Both fuses F801S and F802S test good and not open. Film cap CI818 tests good in circuit and not bulging on side. DP810 tests good in circuit with multimeter in diode mode. CP820 no reading in circuit and out of circuit measures as a resistor. Replaced with 220pf/3kv spare I had from previous repair and tv is fixed.
                • KONKAVE
                  • Dec 2020
                  • United States of America
                  #28
                  Solved here: I just had an LN46D630 come in with no backlight. Has power, and audio, but no backlight. I replaced CP809, CP810 and CP820. It has been powered on for 24 hours, with a few power cycles.
                    09-07-2024, 05:50 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Dodgethis
                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                    by Dodgethis
                    Hello all,
                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                    09-11-2024, 07:39 AM
