Samsung LN46D630 no picture
    Re: Samsung LN46D630 no picture
    Sorry obviously I meant the main to the power board. It would be impossible for the backlight to flash with the inverter board disconnected.
      Here's a pic of PFC IC ICP801
        I took caps CM809 and CM811 off the board but trying to test them with my my DMM without the capacitor mode is difficult. Sometimes no readings or all over the place.
          Here's the ICP801 FAN7930B pin out, what is the testing procedure? The power board is out of stock on jimmy...
            Remove the board so you can test the board by itself but you MUST be careful since you will be working in the HOT DEALY side of the circuit so you should at least power the board from GFCI outlet in case you make body contact with the board, you will use 470 up to 1K 1/4W resistor between the Standby power supply output pin and the PS-ON pin then power up the board and see what Voltage you have on VCC pin and the GND pin.
            BTW: Make sure to put the parts you remove back in correctly before doing the test.
              I found a used power board, problem fixed, thank you.
                Just repaired this model. Symptom - turns on and off with chimes but no backlight. Alligator clips on big caps show PFC going to about 250VDC on power on and shutting down quickly. Both fuses F801S and F802S test good and not open. Film cap CI818 tests good in circuit and not bulging on side. DP810 tests good in circuit with multimeter in diode mode. CP820 no reading in circuit and out of circuit measures as a resistor. Replaced with 220pf/3kv spare I had from previous repair and tv is fixed.
                  Solved here: I just had an LN46D630 come in with no backlight. Has power, and audio, but no backlight. I replaced CP809, CP810 and CP820. It has been powered on for 24 hours, with a few power cycles.
