Toshiba 40D1333B No Backlight
  • london-freddie
    • May 2015
    • 472
    Hi guys just spent all evening playing with this Toshiba 40D1333B with no backlight
    When powering up the tv the backlights flash on for split second then off, ah ha another failed led or so I thought
    Tested voltages at led connector got 24 volts so then stripped the screen panel LTA400HM23 to find the dead led/s. However all working using my backlight tester, checked full circuit and every connection all seems good.
    This screen panel does have an inverter in the panel, crap idea if you ask me.
    Built the screen back up and now asking for help please, Power board maybe or maybe the inverter
    Testing PL306 on the power board supplying the leds I have pins 1 to 5 showing 24.6 V, pins 6,7,8,9,10 showing 0V, pin 11 showing 1.3V, and pin 12 showing 3.2V.
    Does that sound ok
    I am not at home tomorrow so will be sunday before I can look at this tv again
    Any help please
    Will get my pics on asap
  • london-freddie
    • May 2015
    • 472
    Re: Toshiba 40D1333B No Backlight
    Pictures as promised
    Picture of the inverter is not my inverter as I had reassembled my screen but am sure this is the same as mine
    Only other thing that I have noticed is when the set is powered on there is a buzzing from the power board, can not pinpoint where it is coming from yet
    • Diah
      • Feb 2013
      • 6438
      how about the sound... do you still have it ?
      you may read this threat too https://www.badcaps.net/forum/showthread.php?t=45871
      • london-freddie
        • May 2015
        • 472
        not had it connected to a source, and speakers removed with back cover so not sure if there is sound
        Doing the torch test I can see the menu showing on the dark /black screen
        • london-freddie
          • May 2015
          • 472
          I have just been reading that post by Dang seems exactly the same problem as I have got with this tv
          when I had the screen apart I checked every strip separately and all leds lit fine
          I also checked the whole backlight circuit from the two test points on the inverter again every led on every strip lit at the same time with no problems showing
          fuse F1 on inverter board tested good
          • Diah
            • Feb 2013
            • 6438
            if you plug out the socket from power board to LED driver the 24 volts and plug it again little fast the BL will be on ?? no problem you can do this also with out LCD in place if you take it out
            led tester fail to to test the ziner diode of the LED for forward currents, this ziner if get shorted led failed by circuit. best way to test DM in diode mode test each with tow way of changing the probe + and -
            • london-freddie
              • May 2015
              • 472
              Hi Diah just tried removing and plugging back in , still no backlight
              • london-freddie
                • May 2015
                • 472
                Hi Diah where is the Zener that you are referring to, is it on the power board or on the inverter board
                • Diah
                  • Feb 2013
                  • 6438
                  each LED had Zener bulid in to to control the currents forward. this could be open or shorted.. so you can find LEDs lighting up but its Zener open or its Ohm going down near to be shorted.. so currents will be changed , the led driver detect this change and turn them all out. also take your time to check them one by one with DM diode mode
                  • london-freddie
                    • May 2015
                    • 472
                    OK thanks for that, am at work tomorrow but all being well I will strip the panel again tomorrow evening and recheck
                    • zomi
                      • Nov 2011
                      • 509
                      Hard wire all the connections
                      just to rule that out.
                      • london-freddie
                        • May 2015
                        • 472
                        OK Update on this tv
                        Stripped panel again today to get to and check led's
                        Checked with backlight tester and all led's lit
                        Then removed all led strips and slightly bent all the plastic connectors on the ends of the strips to ensure a firm connection between strips
                        Re assembled panel and led's all lit under the tv's power
                        Tv now back together and seems to be working fine
                        Conclusion there must have been a poor connection or connections between led strips or inverter to strip
                        I am happy now but boy what a crap tv this is
                        • johnny250
                          • May 2019
                          • 3
                          • United Kingdom
                          Hi Freddie, is it still working OK?..... I have the same set with the same problem.....any tips on the dismantling procedure?
                          • johnny250
                            • May 2019
                            • 3
                            • United Kingdom
                            this looks like it could be my problem too..... https://youtu.be/AeAGI0yNgEM?t=203
                            • johnny250
                              • May 2019
                              • 3
                              • United Kingdom
                              Contacts are OK on mine, It has a Samsung LTA400HM23 panel, with at least 5 LED's faulty
                              it has LED's in strips of 4 and 5 LEDs. (10 strips, 43 LED's)
                              Some numbers on the strips : SVS400A79 4 LED and 5 LED A,B,C and D types
                              anyone have a source for replacements?.THANKS!
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Ebay or Aliexpress, for either strips or individual LEDs.
                                • hicsvntdracones
                                  • May 2019
                                  I am having a similar issue with a Toshiba 43L612U. When I plug it in the logo flashes up for a second then the backlight goes off, along with the display I think, can't see anything on with a flashlight to the screen. The more I use it, the faster it shuts off until I get just a quick flash of white. If I let it sit or drain all the power, I'll get the logo again for a second at max. All the other posts & videos i've watched end up with an LED issue, though my multimeter isn't giving any similar results. When it first powers on, the backlights jump to about 70 volts (it is very fast til they shut off) then they drop down to 45 volts and stay stable, when the BL shuts off. All 3 led power connections have the same pull and the voltage coming back in is also the same and very small, so it doesn't look like a bad led or short. all the pins have the correct voltage from PSU to COntrol board to T-con, except DIM & BLON, which sit only at 3.5 volts constantly, though when I turn on the TV, it seems like DIM goes to 1.5V then jumps to 3.5 V as soon as the leds kick off, but it is quick and could just be an artifcact of my DMM.Not sure if this TV uses 1.5v to 3.5 or if they all use 3.5v to 5v for those pins. The Power LED blinks red when plugged in, then goes solid red, when i hit the power button, it just goes off.
                                  I keep thinking it is a capacitor, since the more drained the voltage is, the longer the backlight stays on initially, but could be something completely different, I am simply "dangerous" in terms of experience and more or less stop at Arduino projects, though have been known to Mr. Magoo my way through some PCB repairs.
                                  I did try jumping DIM to BLON as has been suggested in the past, with no luck. I am considering forcing the backlight on to verify if I am getting an image also, but want to verify if I need to jump BLON to PWON with 1k jumper or BLON to a nearby 5v on the board, or something different.
                                  Anyone see this before? Sorry to jump in off this post, but can't find my old login so new acct, and similar thread.
                                    • 12276
                                    • U.S.
                                    Don't see the pinout legend but it's usually jumper from pwon to 5 v stndby plus blon to 5 v stndby both, expected voltages should be there and backlights should come on and stay on as long as jumpered. MAKE SURE cable from powerboard to mainboard is UNPLUGGED for this test.
                                      • 12276
                                      • U.S.
                                      Try unhook cable from powerboard to mainboard, plug power cord in, turn on see if backlights come on and stay on, actually this is the test you do before the one above.
                                      • triplefour
                                        by triplefour
                                        09-13-2023, 10:43 PM
                                      • Boyxba
                                        TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                        by Boyxba
                                        I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                        05-13-2023, 11:47 AM
                                      • lostone
                                        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                        by lostone
                                        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                        05-19-2024, 11:40 AM
                                      • DanPoka
                                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                        by DanPoka
                                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                        02-15-2025, 05:05 AM
                                      • Comp_Pro
                                        No Backlight Macbook A1990 820-01041
                                        by Comp_Pro
                                        Hello all,
                                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                        Tests performed:
                                        There is no backlight even with a good screen.
                                        Backlight IC is receiving the correct support voltages.
                                        Fuse F8400 ok
                                        Current sense resistor R8400 ok
                                        Backlight IC is receiving 3.3V on enable pin.
                                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                        Backlight IC receiving 5V from PP5V_G3S
                                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                        05-06-2024, 10:23 PM
