LC-42LB261U No Picture
  • jason123
    • Oct 2015
    • 1068
    a newer TV, Sharp LC-42LB261U shows 7 red flashes then blue on the power LED (I think this is normal), No backlight.
    1. I tested the backlight with a tester, and both string turn on. Voltages on the VLED+ (1 and 2) is 41.5 V, VLED- (1 and 2) about 0.115 V)
    2. Checked the connector from power to Main board. 12V is showing 19.46V (I thought defective, till I looked at the service manual page 21 - Seems 19.5 nominal is ok?)
    3. Buttons are responsive. PS_ON, O/F seem to do what they're supposed to (toggle from 0 to 3.3 V)
    4. Disconnected LVDS - No effect
    5. Disconnected ribbon cables to panel - No effect - Backlight is still not coming on.
    If I'm understanding the service manual correctly (Page 21) it's suggesting replacing the panel? Does not seem right to me unless by Panel they mean "Backlight"?
    Thoughts anyone?
    Thank you
    Re: LC-42LB261U No Picture
    1) You need to report all the Voltages of the connector of the power supply that goes to the main board.
    2) What does the Meter of the LED tester show when you test the LED strings?
    • jason123
      • Oct 2015
      • 1068
      Only one voltage on the connector from PS to Main. That has 19.46V
      My tester is a home made (multiple power supplies in series with current limiting resistor) and doesn't have a built-in meter. I'll have to test that again.
      I opened the panel and sure enough 3 of the 5 strips have one open LED each - replaced those and it's back to life. Thank you
        The LED's are connected in series so if one goes open circuit then the string will not light up.
        You can put the Volt meter on the Anode and the Cathode of the LED string to read the total Vf (Forward Voltage) of the string.
        • neilc6
          • Nov 2015
          • 1550
          You should invest in a LED tester. Failed LEDs are the most common failure in TVs nowadays. The latest models can pump out 300mA and can automatically reverse polarity.
          https://ebay.us/ZBB7QQ
          • jason123
            • Oct 2015
            • 1068
            Thank you.. I just ordered one. I've had several 24V power supplies with floating output, so I just put them in series.. I get close to 200V and current limit with an external resistor. Not elegant, but it does the job.. half-ass I guess Thanks
            • neilc6
              • Nov 2015
              • 1550
              I looked it up recently because I thought my tester wasn't working and it ended up being one of the probes. Ended up repairing the banana jack but I ordered a new jack for $1 and new sharp probes would have been $3.
              My LED tester gets more use on tvs than my multimeter.
              • Tjp444
                • Sep 2009
                • 20
                Jason, if you're still following this I'm working on the same model. Got it with no backlights but had sound. Opened it up, 5 failed LED's, fixed those, buttoned it back up, TV responds to the buttons and remote but no video. Did you have to do anything to reset the mainboard? I read somewhere, I think the service manual, that after so many attempts to start up with an error (backlight) it will go into a permanent state of no-start, even if it's fixed. Thanks for your thoughts.
                • neilc6
                  • Nov 2015
                  • 1550
                  You need to confirm your backlights are all working before buttoning it all up. Turn on the tv without the panel connected (it should turn on) and repeat after putting the diffuser panel on. Make sure your tcon ribbons are pushed all the way in and in straight and not crooked.
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Dodgethis
                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                    by Dodgethis
                    Hello all,
                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                    09-11-2024, 07:39 AM
