Sony KDL-52Z5100 power relay clicks 4 times then standby blinks 10 times
  • Mcologist
    • Jan 2019
    • 20
    Troubleshooting a Sony KDL-52Z5100 and when you plug it in the power relay clicks on and off 4 times and then stays off and the standby light blinks in groups of 10 repeatedly.
    I checked the standby voltage going to the main board and it stays consistent at 3.3v the whole time.
    The other voltages coming from the main power board all match their written values.
    The "power on" connection coming from the main board to the power board changes between 3.3v and 0v while the relay is clicking.
    The issue also occurs when only the main board is connected to the power board.
    Would I be correct in deducing that the error in this TV is on the main board? If you think this is a power issue what should I test/check next? If the main board is the defective one is their anything I could check/replace on it or would it be best to swap the board?
    Thanks so much!
    • 12323
    • U.S.
    Re: Sony KDL-52Z5100 power relay clicks 4 times then standby blinks 10 times
    10 blinks may point to the D4N board, as always make sure you buy the right board for your tv, if you buy one. some here: https://www.ebay.com/sch/i.html?_fro...&_odkw=fire+tv
    • Mcologist
      • Jan 2019
      • 20
      If it was an issue with the D4N board would disconnecting it enable the tv to power up partially? Even with that board disconnected the tv does the same power cycling and blink code.
        • 12323
        • U.S.
        Try unplug mainboard from powerboard, turn on tv, see if backlights come on and stay on, it's recommended to have power cord unplugged from outlet, unplug cable from mainboard to powerboard, plug power cord back in outlet, turn tv on.
        • Mcologist
          • Jan 2019
          • 20
          I unplugged the main board from the power board and jumpered "standby" pin to "power on" pin to turn on the relay but got no backlight activity. I then tried plugging the main board back in and unplugging the D4N board and the tv still did the power cycling and blink code.
          Any ideas what I could try next to find the problem?
            • 12323
            • U.S.
            So did you try it without the jumper?
            • R_J
              • 9633
              according to another similar Sony manual, 10 blinks = DTT WDT = Watch Dog Timer used to track micro processors, not to record errors.
              Jumping st-by 3.3v to POWER ON will turn part of the power supply, like +12 & AU15, but likely not the backlights, Backlight on is likely on CN6204
              • Mcologist
                • Jan 2019
                • 20
                Without the jumper the tv is just in standby. I will see if I can find a backlight on connection. Would it likely also be a 3.3v trigger voltage to turn on the backlights
                • R_J
                  • 9633
                  I don't have this service manual, so I am guessing, what happens if you disconnect the two backlight boards (DN3) from the power supply, does the relay still click on and off? You could also check the two voltages on the power supply labeled PFC-OUT & PRI-VCC
                  Does this use the APS-247(CH) power supply?
                  Does it use two D4N or D3N boards?
                  I doubt its the power supply, I do see that shopjimmy is out of stock on the BU main boards, which could be a sign that the main is the problem.
                  • Mcologist
                    • Jan 2019
                    • 20
                    Yes this one does use a D4N and D3N, I'm pretty sure I tested with both of them disconnected and it still clicked but I will recheck that.
                    The PFC-OUT & PRI-VCC on both boards are at the correct values.
                    Yes it does use the APS-247(CH) power supply.
                    • Mcologist
                      • Jan 2019
                      • 20
                      So I just found a service manual for this model and a few others that lists the blink codes and for 10 it says to replaced the main board. I have attached the manual to this reply.
                      • jason123
                        Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                        by jason123
                        Hi there,
                        I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                        So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                        I see 2 posts that are relevant:
                        https://www.badcaps.net/forum/troubl...j-oled-5-blink
                        https://www.badcaps.net/forum/troubl...g-hardware-dev...
                        10-29-2025, 02:01 PM
                      • brithepi2k
                        Sony KD-65XE8596 no standby light
                        by brithepi2k
                        I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                        cheers...
                        09-06-2025, 02:22 PM
                      • matwan
                        Sony XR-55X90J 5 blinks
                        by matwan
                        I have problem with SONY 55X90J. After several check status is as below;
                        1. Running power board as stand alone:
                        TCON_12V =~ 12.6V
                        EVDD V On Max 24V= 19V.
                        2.
                        Running power board with TCON as stand alone:
                        Effect as below, attched.
                        3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                        "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                        Best regards....
                        09-28-2025, 04:26 AM
                      • GoodCapDude
                        Sony XBR-75X940E intermittent 6 blinks error code
                        by GoodCapDude
                        Hi everyone. First post on Badcaps!
                        I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                        09-20-2025, 06:07 AM
                      • thstuff
                        Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                        by thstuff
                        A) TV initially dead
                        B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                        C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                        D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                        E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                        12-26-2024, 09:10 PM
