Sony KDL-52Z5100 power relay clicks 4 times then standby blinks 10 times
  • Mcologist
    • Jan 2019
    • 20
    Troubleshooting a Sony KDL-52Z5100 and when you plug it in the power relay clicks on and off 4 times and then stays off and the standby light blinks in groups of 10 repeatedly.
    I checked the standby voltage going to the main board and it stays consistent at 3.3v the whole time.
    The other voltages coming from the main power board all match their written values.
    The "power on" connection coming from the main board to the power board changes between 3.3v and 0v while the relay is clicking.
    The issue also occurs when only the main board is connected to the power board.
    Would I be correct in deducing that the error in this TV is on the main board? If you think this is a power issue what should I test/check next? If the main board is the defective one is their anything I could check/replace on it or would it be best to swap the board?
    Thanks so much!
  • nomoresonys
    • 12075
    • U.S.
    Re: Sony KDL-52Z5100 power relay clicks 4 times then standby blinks 10 times
    10 blinks may point to the D4N board, as always make sure you buy the right board for your tv, if you buy one. some here: https://www.ebay.com/sch/i.html?_fro...&_odkw=fire+tv
    • Mcologist
      • Jan 2019
      • 20
      If it was an issue with the D4N board would disconnecting it enable the tv to power up partially? Even with that board disconnected the tv does the same power cycling and blink code.
      • nomoresonys
        • 12075
        • U.S.
        Try unplug mainboard from powerboard, turn on tv, see if backlights come on and stay on, it's recommended to have power cord unplugged from outlet, unplug cable from mainboard to powerboard, plug power cord back in outlet, turn tv on.
        • Mcologist
          • Jan 2019
          • 20
          I unplugged the main board from the power board and jumpered "standby" pin to "power on" pin to turn on the relay but got no backlight activity. I then tried plugging the main board back in and unplugging the D4N board and the tv still did the power cycling and blink code.
          Any ideas what I could try next to find the problem?
          • nomoresonys
            • 12075
            • U.S.
            So did you try it without the jumper?
            • R_J
              • Jun 2012
              • 9514
              according to another similar Sony manual, 10 blinks = DTT WDT = Watch Dog Timer used to track micro processors, not to record errors.
              Jumping st-by 3.3v to POWER ON will turn part of the power supply, like +12 & AU15, but likely not the backlights, Backlight on is likely on CN6204
              • Mcologist
                • Jan 2019
                • 20
                Without the jumper the tv is just in standby. I will see if I can find a backlight on connection. Would it likely also be a 3.3v trigger voltage to turn on the backlights
                • R_J
                  • Jun 2012
                  • 9514
                  I don't have this service manual, so I am guessing, what happens if you disconnect the two backlight boards (DN3) from the power supply, does the relay still click on and off? You could also check the two voltages on the power supply labeled PFC-OUT & PRI-VCC
                  Does this use the APS-247(CH) power supply?
                  Does it use two D4N or D3N boards?
                  I doubt its the power supply, I do see that shopjimmy is out of stock on the BU main boards, which could be a sign that the main is the problem.
                  • Mcologist
                    • Jan 2019
                    • 20
                    Yes this one does use a D4N and D3N, I'm pretty sure I tested with both of them disconnected and it still clicked but I will recheck that.
                    The PFC-OUT & PRI-VCC on both boards are at the correct values.
                    Yes it does use the APS-247(CH) power supply.
                    • Mcologist
                      • Jan 2019
                      • 20
                      So I just found a service manual for this model and a few others that lists the blink codes and for 10 it says to replaced the main board. I have attached the manual to this reply.
                      • thstuff
                        Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                        by thstuff
                        A) TV initially dead
                        B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                        C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                        D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                        E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                        12-26-2024, 09:10 PM
                      • Rensiee
                        Panasonic TH-50PX8EA Black screen, only relay clicks
                        by Rensiee
                        I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                        I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                        When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                        I have measured the voltage in the VSUS line, which...
                        06-18-2024, 12:58 PM
                      • Seb932
                        LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
                        by Seb932
                        i'would like to fix my not working LG 49UB850V tv.
                        Symptoms:
                        -AC plugged in, Standby LED not working
                        -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
                        Checked already:
                        -Powersupply Output in Standby => 3.5V ok
                        -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
                        Any suggestions what to check next?
                        Thanks in advance!
                        09-14-2023, 06:28 AM
                      • AK_777
                        Sony KD-65A1 Repair – 4 Red Blinks Error
                        by AK_777
                        Hi everyone!
                        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                        02-20-2025, 04:15 PM
                      • rabbituk
                        Sony HCD BX7700dbi CMT flashing standby
                        by rabbituk
                        I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                        So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                        02-11-2025, 05:05 PM
