Samsung UHD UN50JU6500
    Re: Samsung UHD UN50JU6500
    Originally posted by lfhlaw
    Ok I didn't realize I had the black lead on pin 2 (which I thought was pin 1). I tested it briefly this morning and got much better numbers similar to post#3. I will post the voltages and variance when I get back from work and if not too tired lol.
    Ground pins are pin 10, 11, and 12.
    Pin 1 is not GND pin anyway.
    • lfhlaw
      • Mar 2014
      • 115
      okay finally got time to post.
      PS-on is 3-4 Volts
      pins 3,5,7,9 fluctuate from 8 v to 13 v
      pins 4,6,8 still show about 3-4 volts.
      the A13v and the 8V standby both fluctuate from 9 v to 13 v.
      with main board disconnected.
      Testing the pullup resistor with ground gives me a fluctuation of 8v to 13 v as well
      • lfhlaw
        • Mar 2014
        • 115
        Well. I did buy a new Power Supply board and that fixed the whole problem. still not sure what caused it to fail though...so a bit concerned that it might happen again after fixing it, but will see what happens.
          • 12330
          • U.S.
          #44
          Have seen bad voltage regulating diodes on psu make voltages fluctuate like that.
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • mrautom8
            Samsung TV UN75H6350AFXZC main board schematics?
            by mrautom8
            Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
            Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
            While relay is on, all voltage rails are present and steady (scoped) on main board.
            I love a good logic puzzle but getting lost without any schematics.
            No shorts on ANY capacitor main board.
            Thermal camera shows 3.3V inductor getting warm instantly but...
            10-19-2025, 06:32 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • Lee M.
            Samsung UN75RU8000FXZA bad main board?
            by Lee M.
            When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
            11-08-2023, 07:46 PM
