Samsung UHD UN50JU6500
    Re: Samsung UHD UN50JU6500
    Originally posted by lfhlaw View Post
    Ok I didn't realize I had the black lead on pin 2 (which I thought was pin 1). I tested it briefly this morning and got much better numbers similar to post#3. I will post the voltages and variance when I get back from work and if not too tired lol.
    Ground pins are pin 10, 11, and 12.
    Pin 1 is not GND pin anyway.
      okay finally got time to post.
      PS-on is 3-4 Volts
      pins 3,5,7,9 fluctuate from 8 v to 13 v
      pins 4,6,8 still show about 3-4 volts.
      the A13v and the 8V standby both fluctuate from 9 v to 13 v.
      with main board disconnected.
      Testing the pullup resistor with ground gives me a fluctuation of 8v to 13 v as well
        Well. I did buy a new Power Supply board and that fixed the whole problem. still not sure what caused it to fail though...so a bit concerned that it might happen again after fixing it, but will see what happens.
          Have seen bad voltage regulating diodes on psu make voltages fluctuate like that.
