LG 49UJ701V (Display Problem)
  • Diah
    • Feb 2013
    • 6438
    Re: LG 49UJ701V (Display Problem)
    better than nothings to watch.... or ???
    if you were not satisfied with it now. you should start trouble shooting the 4 line you hide, follow them on the downside Taps and check the components are connected to them line by line. any line you do post photo of it here we may help
      • 12276
      • U.S.
      Play around with the width of the tape, see what happens.
      • jasonr2000
        Advance Tech
        • Nov 2013
        • 209
        thanks Diah I will see how I go as I said the colour is slightly off on the left of the panel looking straight at it,
        and thanks nomoresonys I will try what you have suggested as I have moved it over about 6 lines on that side so far.
        ill try it again I have nothing to lose but I can get a picture out of it all be it a little off on the top left corner
        thanks
        Jason
        Samsung UE46D6530
        Samsung BD-F7500
        Samsung HT-ES6200
        • Unspun01
          • Jun 2011
          • 349
          What is this sorcery? covering some LVDS pins with scotch tape allows the double-image and horizontal lines to disappear?
          I've never seen such a thing.
          Does the tape need to be applied at mainboard AND panel ends? or just panel end or just mainboard end?
          jasonr2000: Is there still thin horizontal line on your image? I cannot tell
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 209
            yeah cover the ends on the screen side of the LVDS cable,
            as for the pixel line its gone as well.
            just need to work out the colour issue but thats it really.
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
              https://www.badcaps.net/forum/attach...7&d=1553629140
              So he double images at the bottom section of the screen are gone?
              BTW, what is the LCD panel model number?
              • jasonr2000
                Advance Tech
                • Nov 2013
                • 209
                hi budm yes the double image has gone
                as for the panel number ill attach a photo.
                Samsung UE46D6530
                Samsung BD-F7500
                Samsung HT-ES6200
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4462
                  • Italy - Milan
                  #28
                  Hi, i think there's not much more you can do to improve this, from your pic. i cannot see the brightness problem you talk, but you can try to locate more precisely the right trace to cover and not the others, needed a bright tcon picture with board markings well visible..
                  • jasonr2000
                    Advance Tech
                    • Nov 2013
                    • 209
                    hi davi.p the T-Con is intergreated in to the mainboard so there isn't a T-Con as such.
                    I can live with the brightness issue.
                    Samsung UE46D6530
                    Samsung BD-F7500
                    Samsung HT-ES6200
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4462
                      • Italy - Milan
                      #30
                      This doesn't prevent you from photograph it.
                      • jasonr2000
                        Advance Tech
                        • Nov 2013
                        • 209
                        yeah thats true
                        here is a photo of the T-Con/Mainboard
                        Samsung UE46D6530
                        Samsung BD-F7500
                        Samsung HT-ES6200
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4462
                          • Italy - Milan
                          #32
                          I guess you don't have wish to continue.. ok...
