Sharp LC-55N620CU PSU 192020 help ID'ing a transistor
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Sharp LC-55N620CU PSU 192020 help ID'ing a transistor
    Originally posted by R_J
    Have you replaced N851 ? If it is still in circuit and shorted, it could be shutting down the power supply by turning on the opto
    "PIN6 is 6.6v to 11.1v up and down" That tells me the ic's startup cell is working, the ic should pulse the fet's gate and the fet should drive the transformer, this will give you the +20 volts on C819, so check that R821 & R823 are ok.
    Also check that you have +160 on the V807 Fet
    Ok I think we're getting somewhere. On the OPTOs my board's callout is N881 and 891. Both cold side pins of N881 show 3ohms resistance.
    If I am seeing it right R821 and 823 are in parallel, Both 2R2 resistors and with 1.5 ohms across both
    V807 has 166V
    They call me......."threadkiller"
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      I have a similar OPTO with the same 817B markings on the case. Will this work long enough for testing the TV, or do I need to get one with the exact same markings on it?
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        UPDATE: OPTO replaced
        I pulled the OPTO out of the board and checked it, same 3ohms across the cold side pins. I installed the same number OPTO but from a VIZIO power supply, no longer checks short but still no stand-by!
        • R_J
          • 9559
          3Ω is low for the led of the opto, Did you replace the blown TL431? as for the opto 817b and 817b are the same.
          I believe N881 opto is for turning on the backlight, so don't worry about that circuit now.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            I have not replaced the blown TL431 just yet. What I did do is have a look in my inventory list and found a near identical board (217654) from a LC-55N6000U.
            TL431 definitely needs replaced. I'm looking for one similarly marked on another board to transplant for testing. Is there a list somewhere I can look at for compatible IC's with other markings?
            I feel the need to go back to the up-and-down voltages off the bridge rectifier for just a minute, because when I fire off the 217654 power board the voltage at its bridge rectifier is rock solid.
            I guess the reason I went back to this is to ask...do you think the shorted TL431 is causing the voltage fluctuation, or is the bridge rectifier suspect too?
            Also, both boards have the same output specifications and pinouts. Can I substitute this board in place of my original to test the rest of the TV? If so I don't think I'd do that until I pull the main board and have a look for "crispies".
            With all of the damage on the cold side of the board I'm wondering if the damage trickled down from the main board? It's a confirmed nearby lightning strike with immediate thunder and other cooked devices in the home.
              Something is not adding up since the Voltage on the main cap is stable but the output from the bridge is not, if output of the bridge goes up and down then the Voltage on the filter caps should follow.
              • R_J
                • 9559
                The boards do look the same, so it should work. The TL431 is a Precision Programmable Reference. it is there as a reference so the 12 volts can be regulated by driving the optocoupler and controlling the N834's ouput. like I said before, almost all smps use this reference ic, usually in a to92 case. (3 leg through hole mount)
                Budm: there is a diode (VD808 &VD804) between the bridge output (ac3) and the main filter cap in the pfc circuit, so the bridge voltage which is not filtered could change if the N834 ic is trying to start and stop, pulsing.
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  #28
                  This is the only device between the caps and the bridge rectifier.
                    That diode (boost pre-charge diode) is part of the PFC Voltage booster circuit, the Voltage on the anode is 120Hz DC pulse.
                    See fig. 3
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      #30
                      Installed the P6000's PSU. Its good news and bad news. The good news....the best I can see the OSD appears OK......but with no backlights its hard to tell.
                      See fig. 3
                      Do you agree with R_J's belief that the fluctuation is from the board trying to start? It sounds exactly like what that Samsung 50" EH5300 was doing and it sounds logical.
                      EDIT/ADD: Backlight availability on this TV is super lousy, either high dollar used or cheap from China, ebay seller christmas2carol and arrival from late march to the second week of april.
                      • R_J
                        • 9559
                        check the voltage on pin4 SW, maybe the tv also has a backlight issue?
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          #32
                          Pin4 SW voltage on the original board from the TV is zero volts. Or are you asking about SW voltage on the substitute board? If so the SW voltage on that board's pin is 2.89v and remains. Both anode terminals on the backlight connector come up to 177/200 volts then drops and remains low.
                          • R_J
                            • 9559
                            I believe the backlight/SW pin should be high to turn on the backlights, If the backlight voltage comes up to 170 volts and drops down, that usually indicates an open led string in the panel, Do the backlights flash and go outl? how many wires go to the backlights 2 or 4 ?
                            • DXseekerMO
                              • Feb 2018
                              • 1119
                              • US
                              #34
                              Yes they do, and when the TV is on I can see a few points of light on the screen where is looks like some of the LED's are very dimly lit. There are 4 wires to the LED strips
                              I know this is an edge-lit TV but it looks like a few working very weak LED's like they are in an array behind the screen.
                              EDIT/ADD: Here's the best price I've found on the LED strips for this TV on Ebay. Does anyone have any experience with this seller or the reliability of their products?
                              https://www.ebay.com/itm/2-PCS-New-5...4383.l4275.c10
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                #35
                                That GB1 is a TL431 reference ic
                                Using hot ground, check if you have VCC on N834 pin 6, Also check for aprox +160v on pin 8. Then check the base of V812, it should have +16 volts (VZ810 is a 16v zener)
                                I went to find this GB1/TL431 to buy and there are several choices. Can someone please help me with what I need to know to order the right item?
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  #36
                                  Anyone?? I'm trying to complete an order for several TV's tonight if at all possible.
                                  • R_J
                                    • 9559
                                    AN431AN-ATRG1 is the original diodes incorporated number .5% tolerence
                                    the AN431BN is 1% tolerence, digikey only stocks this one
                                    One of these would likely work https://www.digikey.com/products/en/...=1&pageSize=25
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      #38
                                      Shopping list for this TV:
                                      1P regulator:
                                      https://www.digikey.com/product-deta...mSeq=286154013
                                      OPTOs:
                                      https://www.digikey.com/product-deta...mSeq=286187954
                                      GB1:
                                      https://www.digikey.com/product-deta...mSeq=286188767
                                      Would these all work OK you think?
                                      • R_J
                                        • 9559
                                        They should be ok.
                                        • DXseekerMO
                                          • Feb 2018
                                          • 1119
                                          • US
                                          #40
                                          They should be ok.
                                          Sweet. Thank you R_J, I'm going to get the stuff coming for this. Looks like it will be a bit before I have another update.
                                          I guess I'll go with those LED strips, worse come to worse they are protected by Ebay so hopefully they work out ok.
                                          • michalk3777@gmail.com
                                            Sharp Hisense - LC-65N7004U Error codes
                                            by michalk3777@gmail.com
                                            Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                                            Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                                            Regards,...
                                            12-15-2024, 09:20 PM
                                          • DrvLikHell
                                            Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                            by DrvLikHell
                                            Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                            The...
                                            02-05-2025, 01:44 AM
                                          • Coolgoodman
                                            Faulty Hisense 85Q6NAU TV
                                            by Coolgoodman
                                            85” Hisense TV
                                            Greetings,
                                            Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                            Dear TV technicians of forum, I hope this message finds you well.
                                            I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                            I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                            07-24-2025, 03:02 AM
                                          • ShahZaib Ghumman
                                            Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                            by ShahZaib Ghumman
                                            Hey folks,
                                            I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                            A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                            So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                            03-25-2025, 10:59 PM
                                          • nono34
                                            Hisense stuck in Colors cycle like test pattern.
                                            by nono34
                                            I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                            I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                            10-24-2024, 04:31 PM
