Vizio M70-C3 Dark Spots
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Vizio M70-C3 Dark Spots
Hard reset meant only the reset which done via Service menu. it roll back all driver and firmware to Factory condition. rest from user menu its just rest the setting of the user.Hello Diah, I restored the factory defaults and picture still the same. Next, I copied the black and white jpg's to a thumb drive and played them on a slide show for a couple minutes. I could always see the shadows when the white screen played.
Is that the tests you are asking for?
thank you,
Kent
this test should be done with Cable or areal signal. not USB or HDMI signal.
please turn off the light of your room ( in case the TV set had build in Light room sensor ), and set the backlight level of the TV to Zero. keep it on and watching any things for at least 30 minute. then turn the backlight level setting to up slowly .. but not to full and check the dark spots at which level there no spots.Last edited by Diah; 02-26-2019, 09:46 AM.Comment
Hello Diah, I restored the factory defaults and picture still the same. Next, I copied the black and white jpg's to a thumb drive and played them on a slide show for a couple minutes. I could always see the shadows when the white screen played.on the specification of the this TV there are full arrow dimming system. as other said. this panel are big the risk to take out with one person do high.
reading voltage don't work at all as its currents to dimming or turn off. if there was one burned then whole back light will be out and TV will never start.
the rest we can think what i said before.. but its much we can know more close with easy steps
1- make hard reset from service menu and check result
2- attached UHD learning full arrow dimming system put them on fat32 usb format and play them on the tv one by one until you can see the white one full White.
if no change please report to do other test
thank you,
KentComment
OK, turned out the lights in the room and reduced the backlight to zero for 30 minutes. While watching, all dark spots are still noticable . Slowly increased the backlight from zero to 55, checking for spots while doing so and they remain on the screenComment
i do wondering how you can remarkable the dark spots at back light level Zero.. you may have under picture setting some things like Auto Brightness Control.. this need to turn off.
please upload photos as other members request. now start the hard workLast edited by Diah; 03-01-2019, 02:24 PM.Comment
Two pics on zero backlight, auto bright offAttached Filesif you find these attachements useful please consider making a small donation to the site
do the same test again of backlight level zero.. i thnk this auto brightiness was on... if it was off then no need to do it
i said the test with channel signal not jpeg or s other.. areal signal or cable signal of program that the picture will change and moved time to timeLast edited by Diah; 03-01-2019, 04:07 PM.Comment
I will be removing the back and taking pictures and posting tomorrow morningComment
not good news 4 reasons
1- software issue ( local dimming blocked ) hard reset from service menu can approve it
2-LED driver replacement
3- Led strips ( must all replaced with new one )
4- panel sandwich layersComment
Looks like backlights. I had one of these that had gotten hit by lightening. Minor damage to Power Supply that cost $8 to fix, but then 1/3 of the backlights were out. Not fun. A good test video can be found on YouTube by searching for "Monitor Color Test".Comment
OK Guys, I have decided to tear it down and look at the LED's. And now for perhaps the dumbest question ever. I would like to plug in and look at the LED's for which ones may be bad. I plugged in, but how do I get them to light up?..sigh...Comment
Top tip: make sure that before you attempt to turn it on you have isolated the tconnribbons. I learned the hard way that if you disconnect them from the panel but leave them connected to the tcon they can short against the body of the TV and take out your tcon.
When you attempt to turn it on as normal, they don't turn on?Comment
Great, thank you. no, plug it in and turn on the power but no LED's, but if all the ribbons and IF filter, etc, etc are disconnected , how does it get the signal?Top tip: make sure that before you attempt to turn it on you have isolated the tconnribbons. I learned the hard way that if you disconnect them from the panel but leave them connected to the tcon they can short against the body of the TV and take out your tcon.
OK...sigh...now that everyone, including me has had a good laugh at the rookie. I powered on the set at TV and YES!, I have backlights that are out! Replacing now....wish me luckComment
just when things were going so well, got the new LED's installed, powered up and all good. I put everything back together and fired it up and no joy, left side of screen was all white and the other side had a picture. So my first thought was the 4 ribbon connectors, so took apart again, re-seated them and put back together. Hung on the wall and fired up again, bottom left corner, screen cracked, wont power up, Game Over! sigh...appreciated all the help guys!Comment
by YanlebI have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've... -
by JaviercityHello there i have a Sharp 80" LDC that has some dark spots in the middle of the screen, since its a 80 inch need another person so hang it on the wall or move it around, so i hope the collective wisdom can help me to determine what is wrong, I've been doing some research online and there is next to nothing about this TV, i tend to believe that the spots are due the back films/diffuser sheets, that are bit dirty, or perhaps one or two LEDs being burned, but what throws me off is that the dark spots are more noticeable when the image is bit dark like night scenes, and also noticeable when...06-13-2023, 12:02 PM
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by RozpHello Everyone,
This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area.... -
Assuming...7 Photos - Loading...
