Thanks again guys, it just torks me because I was very methodical, labeled everything, etc, took special care of the screen. Seemed to be a crack in the lower left hand corner, almost the size of a thumb so maybe a grabbed it here too hard? idk could I have not have it centered perfectly and tighten down the bezel inappropriately? Perhaps I will never know the real reason it cracked. Anyway, in hind site, like Budm said, maybe a dark spot or two better than no darks spots? Well....I tried my best and learned alot, maybe I should look at it as a 6 hour workshop...
I think you missed the post about "won't power up" because of the crack screen. :-(
basically, now only the cards can be salvage ... along with the led I guess.
Oh I know about the crack screen, what I try to say that OP could use the TV with some LED's string not working and use it until other LED's failed to the point of unable to use the TV any more then open up the screen at that point since there is no other choice left.
The LED strings could also be tested as suggested in post 19.
???? The tv no longer works as in NO picture because of the crack. At best he could only get half the screen to display now because the other half with the crack won't display.
yes that would have been the wise thing to do BUT post 39 was the end result of a "first timer work on a very large panel".... and now the set is basically of no value / not working. :-(
