LG OLED65B7P-U thin horizontal black line
  • dibsrepair
    • Apr 2018
    • 26
    I unlocked the tv with a service remote. I can see a thin black line(see attached picture)
    i can keep the tv on from 20 sec to 4 min, depending on how much image is being displayed.
    high rez images make the tv shut of instantly.
    i can play a dvd for a min
    that line is on top every image, osd, dvd, menus, factory menus
    the line starts on the left side, 8 inches in and ends about 1 inch from the right side
    it is not locking up after 5 shut offs
    all voltages are good till it turns off
    i can turn it on again with a normal remote
    can i run a test (pattern) to determine where my problem comes from?
    is the osd generated in the main board or tcon?
    My question is: is this a bad tcon or main board?
    or a bad panel?
    cheers dan
  • budwich
    • Jul 2015
    • 3097
    Re: LG OLED65B7P-U thin horizontal black line
    its more than likely a panel issue... you might get lucky with some pressure padding on / near the panel tabs in the area.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Could it really be a bad panel driver or bad adhesion of COF, like LCD?
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        • 12145
        • U.S.
        Maybe feel the bezel area right where your line starts, see if its warmer there.
        • dibsrepair
          • Apr 2018
          • 26
          Thank you for the feedback
          bad panel driver/tabs or bad adhesion of COF; they are hidden behind an aluminum cover and i would have to dremel the back open to access them.
          I will try adding some pressure on the visible conections
          if that wont work i will see if the customer lets me disect his expensive piece of garbo
          so t con and mainboard are out of question then
          • dibsrepair
            • Apr 2018
            • 26
            I remember the screen stayed cold to the touch
            even after turning it on repeatedly
            i will test for heat, around the black line if it is shorted
            • Diah
              • Feb 2013
              • 6363
              if with service remote. IN-STOP didn't help then its much driver-T-CON which its lag with handling high resolution. this why the horizontal line not complete from side to side.
              • dibsrepair
                • Apr 2018
                • 26
                In this low light picture, you can see the line. It is there in normal mode too. So you say, it is a (not completed signal or not strong enough signal), that gives this TV an unfinished line.
                That sounds better then a COF or banding issue.
                Could it also be, that the main board sends an incomplete signal? instead of the t con?
                Danke
                • Diah
                  • Feb 2013
                  • 6363
                  Danke
                  i stooped at yours OP ( I unlocked the tv with a service remote.) what did you mean with it.?
                  MB had nothings to do with this line. but you said it turn off after few of time when you feed it with high resolution video signal. the most sickness at LG OLED the screen driver didn't load correctly or blocked some time some how. IN STOP to make the TV back to factory condition solve this problem. but now you have this line, which its generated by the driver self which located on T-CON board together. you need to take out the metal cover of the driver T-CON board and load here photo to see which version its.
                  important. if you want to to reset the ribbon cable between T-CON and panel. don't switch them at its places. ( they should be at same order as before.
                  • dibsrepair
                    • Apr 2018
                    • 26
                    ok i will be back with a t con picture in 12h
                    • dibsrepair
                      • Apr 2018
                      • 26
                      I ordered a t con will update, if it fixes the problem
                      • Diah
                        • Feb 2013
                        • 6363
                        did you made any further test on the driver ? such freezing it and the line disappear so you ordered the board ?
                        • dibsrepair
                          • Apr 2018
                          • 26
                          no i did not do such tests. The line is there before anything gets hot, right of the start. I use freeze spray to find components shorting to ground and if a devices's performance deteriorates over time as it is operating.
                          • dibsrepair
                            • Apr 2018
                            • 26
                            new t con did not fix the horizontal line. Bad panel it is. The TV is going to scrap. Anyone want to buy boards?
                            • Unspun01
                              • Jun 2011
                              • 339
                              Thanks for the update about the panel issue.
                              But you said this is a customer TV? Why turn it to scrap if it only displays relatively small defect.
                              Did the customer give you this TV?
                              Maybe they will pay for your time, but I'm sure they would want to sell it cheap (still working) to someone who would be happy to have it.
                              • dibsrepair
                                • Apr 2018
                                • 26
                                Hi Manitoban
                                The defect in the panel triggers a safty shutdown, it does not stay on longer then 5 min.
                                I charge a $50 diagnostic fee.
                                2 out of a 100 customers want there unfix-able (panel issue/parts do not exist)or (too costly to repair) TV back.
                                • Diah
                                  • Feb 2013
                                  • 6363
                                  i saw many OLED with broken screen Horizontal line or vertical too, other complete burn pixel at certain area all never turn off they keep produce sound with damaged picture
                                  • dibsrepair
                                    • Apr 2018
                                    • 26
                                    On this TV, the image is the same as before with a new t con.
                                    • dibsrepair
                                      • Apr 2018
                                      • 26
                                      is there a way to read an error log in lg tvs?
                                      • William1967
                                        • Nov 2017
                                        • 203
                                        • Netherlands
                                        The display is defect and beyond repair. This is much different than a "normal" led display.
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                          HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
                                          This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-06-2024, 06:50 AM
                                        • Raulnn
                                          Hisense LTDN40D36EU thin black vertical line
                                          by Raulnn
                                          good evening!!! I have this tv with a line that occupies 1 or 2 pixels in width. it has a solution? Can you do a test to find out if it's a panel or something else? Having the tcon integrated into the panel makes everything difficult. I have pushed on the flex attached to the panel, on both sides and there are no changes. I don't know what else I can do... the integrated ones that go on the flex get hot, but without burning yourself if you put your finger on it. to see if someone can help me. I attached a detail photo of the line. Thanks in advance...
                                          12-30-2022, 05:45 PM
                                          HP mt44 Mobile Thin Client Mobile thin client Specification for Upgrade or Repair
                                          This specification for the HP mt44 Mobile Thin Client Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client boardview and mt44 Mobile Thin Client schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
