Sharp LC-52D64U hard to start
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Sharp LC-52D64U hard to start
    Bypassing the protection on the inverter IC sounds like the only option left to mess around with at this point.
    Wattevah...
      • 12128
      • U.S.
      Wonder if there's a way to test the transformers on inverter, it doesn't look as easy to do as on some samsung tvs?
      • elitegroups
        • Jun 2010
        • 16
        Originally posted by elitegroups
        Thanks, a lot of good info in that video. I touched up all the solder joints of the transformers but didn't help. I was trying to zone in on the individual component that needed to heat up in order for the tv to fire up but I noticed if if heated up the bare sheet metal section next to the master inverter the set was firing up immediately as well. So it seems the hair dryer is heating up the tubes just behind which is the absolute worst case scenario. The set seems like a good candidate for an LED conversion! I saw a video on youtube where a guy converted 42" version but I have to figure out how get to the tubes without destroying the lcd.
        https://www.youtube.com/watch?v=jdk-GxU7TU4
        Please disregard, I tried heating up the sheet metal again but no go, it is something on the master inverter that is thermal related. I wil try to test the transformers. One has a slight bulge in it.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Can you hear any arcing ? I had the same issue with a Panasonic (I think) which used this master-slave inverter setup and although not visible, one of the transformers was arcing internally. It was just barely audible if I placed my ear on it, so I took the gamble and bought the two inverter boards and swapping the master one did fix the issue. If you can get them for a good price, it might be worth doing the same, instead of bothering to track down the issue and fix it at component level. True, it's more "fun" this way for us tech geeks
          Wattevah...
            • 12128
            • U.S.
            Ok, so if I'm understanding, you narrowed it down to 1 inverter board and tv is still coming on as soon as you hit it with the heat?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #26
              Well if heating the board causes it to turn on, I'd try to zone in on the problematic area by heating less and less of the board until you pinpoint it. I did this with a mainboard once which had a bad cap somewhere but there were a lot of them clustered together, so identifying the bad one proved difficult. I used the smallest nozzle of my hot air station and began heating each one gently and trying out the TV each time until I found the bad one.
              Wattevah...
                • 12128
                • U.S.
                #27
                Good idea Danny, I think I would try grabbing an inverter too, can probably get one for 10-20 bucks or less, shopjimmy list here, looks like theyre sold out, might show some substitute part numbers tho: https://www.shopjimmy.com/catalogsea...?q=+LC-52D64U+
                • elitegroups
                  • Jun 2010
                  • 16
                  #28
                  Great advice guys! I think i have it narrowed it down to a single mosfet now. I touched up the joints but no go. I made a funnel for the hair dryer and found it this way. I can remedy the the problem on command now by heating the fet and quickly induce the problem by cooling it. Im going to swap its position with another of the same fet on the board and see if the trouble moves with it.
                    • 12128
                    • U.S.
                    #29
                    Nice work, looks like you found the culprit.
                    • elitegroups
                      • Jun 2010
                      • 16
                      #30
                      So I swapped the suspect mosfet positions with another on the same board but the trouble didn't follow the suspected fet. So it looks now the issue is not the fet but the actual board being heat up. The pad area underneath the problem area looks darkened from prolonged heat and I noticed a very small hairline crack on the top side of the board underneath where the fet was. Now this is the trouble area and heating it up temporarily fixes the issue. I was hoping to find a broken trace or solder joint on the flip side but couldn't find any defects. There is an smd resistor and diode directly underneath where the fet was so I touched up the joints but no go. I did a lot of continuity tests on the traces and pads in the area as well but no improvement. I am uploading some pics of the area. One interesting thing I noticed is when the area is cold and I fire up the set while holding the fet, the screen flickers as usual and you can immediately feel the fet heat up a great amount. Now if I heat up the board with the hair dryer then turn it on the screen comes on immediately no flickering and the fet doesn't get very hot.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        #31
                        I would continue reflowing stuff in that area. Another idea that just crossed my mind is to see what transformer that FET is driving and swap THAT with another one, rather than the FET. The heat might cause some strange behaviour in the nearby transformer as well Though you said you tried funneling the heat as much as possible, through conduction some of it may have "leaked" down to the transformer...just my 2 cents at this point.
                        Wattevah...
                        • budwich
                          • Jul 2015
                          • 3097
                          you appear to have narrowed down the area of focus. You have looked at what happens in terms visual and "touchy / feely" observations.... but now you need to also check the voltages that are appearing at that component during your two different scenarios to see if its a gate or "switch issue". As suggested, perhaps its another component that is causing the draw thru the "switch".
                          one other point.... you have been working on the "premise" that heating is helping with "connectivity" but based on your recent observation (device heating up when "cold started") appears to indicate that may there is a some form of "short" connection when cold that is causing a large draw heating up the device but when the "area" is pre-heated, that "short connection" is broken... potentially by things like board expansion. Maybe check various resistance paths at "cold" and at "hot" to see if anything jumps out.
                          • elitegroups
                            • Jun 2010
                            • 16
                            #33
                            Those are some good tips to narrow it down. Im going to have another go at it today. Just wondering, does this seem like the trouble could be a bad lamp and the heavy current draw is from the fet and transformer trying to fire up the faulty bulb?
                            • budwich
                              • Jul 2015
                              • 3097
                              yep.... just like a regular house tube, if it takes quite a bit to start / if it is "burned" and take a bit to "arc up" then it is hard on the "ballast" and will usually / eventually take out the ballast.
                              • elitegroups
                                • Jun 2010
                                • 16
                                #35
                                Great News! The set is working now. I had to bite the bullet and buy the master inverter board and all looks ok now. It would of been nice to fix the old board but now I have some spare transformers in case of future troubles.
                                What led me to throw in the towel was while trying to measure the gate voltages to the mosfets to see if one wasn't receiving a proper gate voltage to fire, my probe slipped and shorted one FET out. So now my trouble was compounded and i just decided to get the whole board. However I was getting some measurements i didn't understand. There are 8 mosfets on the board, 4 p-channels and 4 n-channels. Now on the n-channel fets i got a reading of around 4.5vdc from gate to chassis but on the p-channels I measured 60vdc on their gates which seemed too high. 60 volts also happens to be the supply voltage to the board. I know a scope is really needed to see the waveform but I wonder if this is some sort of push-pull configuration how the fets are arranged. A big thank you to the great tips and help!
                                • federalhouse
                                  **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                  by federalhouse
                                  I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                  **Background:**
                                  I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                  **What I've Tried So Far:**
                                  1. I accessed
                                  08-01-2024, 07:03 PM
                                • ash91
                                  Hp pavilion 15 not detect hard drive
                                  by ash91
                                  Hello gentelmen .... this is my first post and sorry for my bad english,
                                  so my proplem is my laptop keep losing hard drive even if i but the
                                  hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                  when i turn the laptop on the massage that said no boot media found pop on
                                  the hard disk is fine and to be sure i try another hard
                                  i also update my bios to the last update
                                  the 5 volt is present on the hard connector on the motherboard
                                  the dvd rom work fine when i but a windows dvd in it
                                  also when i boot from flash...
                                  06-07-2023, 01:45 PM
                                • madura2010
                                  DAY11AM6E0 hard disk drive and optical disk drive not detected
                                  by madura2010
                                  Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                  i checked the connectivity of ribbon=good communication with hard and motherboard
                                  changed hard disk and checked=3f0 error persist
                                  sata power=+5v available
                                  Then checked data capacitors=all good
                                  Then checked data lines path connectivity to pch=all good
                                  reflashed...
                                  03-12-2023, 09:09 AM
                                • mikey5791
                                  Help on Samsung Syncmaster T220 dead ccfl lamp
                                  by mikey5791
                                  This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                  Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                  10-18-2020, 03:17 AM
                                • ttmi100x
                                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                  by ttmi100x
                                  Greetings everyone,
                                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                  Upon closer inspection...
                                  07-31-2024, 06:36 PM
