How do I find exact replacement LED bead for this backlight strip? and will it last?
  • link626
    • Feb 2019
    • 36
    How do I determine what type of LED this is? I wanna buy some off ebay
    and I heard that if you replace the LED, eventually the whole strip will fail anyway. What's the reasoning for this?
  • CapLeaker
    Leaking Member
    • 8186
    Re: How do I find exact replacement LED bead for this backlight strip? and will it la
    Well, this isn't fully true, but not fully wrong either. LED's are current controlled, not voltage controlled. So when a LED fails, the other LED's in the string have to work harder and get over volted and they don't like that at all. Depending on how long the LED string is, if one LED fails may matter more or less. In your case, we don't know the size or model number of your TV, so have no idea how long your LED string is nor a better idea on what exact LED that is either.
    • link626
      • Feb 2019
      • 36
      I thought there was a way to measure the LED.
      But my TV is a TCL 43s405.
      part # LB4308, TOT_43D2900_3X8_3030C_D6T-2D1_4S1PX2 <<< oh damn. 3030 might be a clue. Are all 3030 LEDs the same output? What color temperature are TV backlights usually?
      and the strips look like this...
      • link626
        • Feb 2019
        • 36
        I also tried to test the individual LEDs with a 3V battery with 2 needle probes, and no matter where I scratched off the white paint and put the leads, I couldn't get any LED to light up.
        This strip has confusing lead pattern.
        I put the probes at the X's...
        And my probe tester....
          You have 4 strips so how many strips are not lighting up when they are connected to the TV? What Voltage do you have on LED+ pins and on LED1-, 2-, 3- 4- with all the connectors in place.
          https://www.shopjimmy.com/tcl-lb4308...43s405tdaa.htm
          https://www.shopjimmy.com/catalogsea.../?q=TCL+43s405
          • link626
            • Feb 2019
            • 36
            There are only 3 strips, and they all light up on the left side only.
            The 4 right LEDS on all 3 strips do not light up. The control board shut that side off.
            Without an LED strip tester, I have no idea which LED is bad.
            I measured ~60 volts on each +/- pair from the main connector from the power board, and this connector splits off into 3, one for each led strip.
            I'm really just wondering if I could do a longterm repair simply by swapping the individual LED, or if minor spec differences will cause it to fail.
            I see the 3030 LEDs on ebay are 3V 1W, 350-420mA, 140-160 lumens
            30 LEDs for $2.85 shipped.
            it would be good practice to solder some.
            I'd like to keep using my TV rather than trashing it.
            • angelos
              • Dec 2012
              • 571
              • South Africa
              For me its not the issue to replace the LED but rather to readjust the lens to the right position so that the light striking the diffuser sheets does not make a bright spot on the screen. The focal distance is critical on these sets and very noticeable when done wrong.
              Imagine you add your 3 dabs of quick drying epoxy and then position the lens whilst moving the diffuser over it partially to adjust the lens position. That is a nightmare. I can bear it to do 2 or three of these but to replace all 60. You will need 8 hours to do so. Also, i have had a high comeback rate when repairing and replacing only the faulty LED's since all are in series and they have all been stressed equally.
              Anybody else have a better idea or is it the best advice to replace all LED's???
              • zomi
                • Nov 2011
                • 505
                Replace all with new strips
                best way really.
                Life is too short to mess about with getting lens lined up
                Sometimes you have to as repalcments cant be sourced
                but you have you ask your self how much is your time worth.
                • Diah
                  • Feb 2013
                  • 6376
                  to me for this 3030 SMT LED i use one sort Only ( Like Tomato ) which it can cover current forward from 250-420 mA. as high power LED and to whom ask of VF it can handle from 3.3 -5 V.
                    So It only has two return wires, each strip has 8 LEDs (the connector on the strip has two pair of connections for 4 LEDs per sub string: TP1+ & TP2-, and TP19+ & TP20-). The three strips are wired up as two LED strings, each string has 12 LED's.
                    Since each sub string has 4 LED's each if they are 6V LED then using 3V is not going to be enough to forward bias the LED on to make it start conducting current, you can try with 4.5V first for each LED to see if it will glow faintly. I would replace all new strips myself so I do not have to take the panel apart again down the road.
                    BTW, what is the Voltage reading on LED+ with ref. to chassis GND?
                    • link626
                      • Feb 2019
                      • 36
                      ahh, I suspected these might be 6v leds.
                      Would I be able to use a 5V phone charger to light these up?
                      How do I test LED+ and chassis GND? Where do I put my probes?
                      • link626
                        • Feb 2019
                        • 36
                        If these leds happen to be 3v, 6v led can be substituted? with no decrease in light output?
                        (I'm sorry, I don't know anything about leds)
                        • link626
                          • Feb 2019
                          • 36
                          best way really.
                          yeah, I get it. In the future though, when parts may be hard to find, I will want to replace an led, since a new TV will cost $XXX.
                          Right now, shopjimmy sells used pulled led strips for this TV.
                          New parts for this TV are impossible to find.
                          Also, getting the lens lined up seems easy because the strip has markers to line up with. Scrape it clean, then use e6000 adhesive.
                          • CapLeaker
                            Leaking Member
                            • 8186
                            No.
                            If you try to get a 6V LED to light up with 3V, that doesn't work. You proofed that one already yourself.
                              LED connector has label for each pin.
                              Put all connector back in place, keep black probe on the chassis, red probe on the LED connector that is labeled with LED+ (the one with red wire r the white wire) then turn the TV on to see how high the Voltage jumps up to and then wait 10 seconds to see how low it goes down to.
                              • link626
                                • Feb 2019
                                • 36
                                I was wrong before.
                                both LED+ measure at 80V stable. It starts at 60-70V and gradually rises to 80V.
                                On each led strip connector, TP1 TP2 measure at 0v,
                                TP19 TP20 measure at 26V.
                                I measured the voltage across a single LED at 6.5V, so confirmed this is definitely 6V 3030 LED.
                                So I go on aliexpress and buy "50pcs Lextar LED Backlight High Power LED 1.8W 3030 6V Cool white 150-187LM PT30W45 V1 TV Application 3030 smd led diode"
                                for $2.61
                                and I'm golden?
                                SMD LED -3030 WHITE
                                CAT:190-200lm
                                CCT:6000-8000K
                                REF:6.0-6.6V
                                I(MA):350-700ma
                                QTY:50pcs
                                High Power LED - 1-2W
                                I watched some youtube videos, and one guy did some current adjustment after replacing some LEDs.
                                I hope I don't have to do that, cuz I don't have the tools.
                                I measured the current across one LED at 290mA.
                                Will the LED specs quoted above work?
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  In theory, You may have a lot of shorted 6v LEDs but you only have one LED open, Yes, only one chance, one of your LEDs is open, see if you can find out which one?
                                  TV has no backlight, I found one led open by visual method then I shorted this led, TV backlights lighted up, i add more leds (any) to close to power supply led driver voltage, that's all.
                                  Khufu's secret II......adding LEDs.
                                  https://www.badcaps.net/forum/showthread.php?t=74702
                                    Hopefully the PCB foot print will match your replacement LED, the replacement LED has large heat transfer pad as Cathode.
                                    The ratings of the LED are OK.
                                    http://www.lextar.com/?sn=90&lang=en-US&c=774
                                    • link626
                                      • Feb 2019
                                      • 36
                                      so when those LED specs are 350-700mA
                                      If the TV only supplies 290mA when plugged in, that will still run?
                                        Since we do not have details spec of the LED, the 350 mA rating may be the maximum current rating at 25c, the 750 mA may be the pulse peak current.
                                        You do not want to run the device at maximum spec, you also need to do good thermal management. You always want to have safety margin when operating the device.
                                        The 290 mA you measured may not be the maximum current the LED driver power supply is putting out since you do not know what the backlights setting is at for your TV right now, it may be at max, or 90%, 80%, who knows.
                                        Look at example of the spec sheet.
                                        BTW, looking at your pictures in your post 16, I cannot tell how the strips are wired up together, each strip had 4-pin connector, so it has 4 wires on each connector? The LED's have to connected in series some how.
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • Won Dee
                                          Could you please help me find the exact replacement IC?
                                          by Won Dee
                                          Can't found the datasheet on internet....
                                          07-25-2024, 11:00 PM
                                        • adelage
                                          220v Led strip flickering
                                          by adelage
                                          Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                                          I know that the best solution would be to get a voltage...
                                          11-03-2024, 09:49 AM
                                        • Briesmith
                                          Help Finding a Replacement LED Strip
                                          by Briesmith
                                          Hello Everyone
                                          I've spent hours looking at Chinese (mainly) websites offering replacement LED strips for backlighting monitors, TVs etc but I can't find one to replace mine.
                                          Mine goes into a BENQ GC2870, it contains 32 LEDs and is 355mm long. It is marked E117098 94V-0 on the front and NLM144LL077BDBKALB00751R901LGA on the back. I have attached some pix in case that helps....
                                          04-20-2022, 08:00 AM
