Sansui 55" LCD T V Model STY0955 (Backlight issue)
    Hi guys,
    I have this set with a backlight issue that i need to resolve rather urgently. The problem is a s follows, Upon pressing standby the tv's picture comes up and backlight is present. I measured about 55V (Picture bright and correct) on each of the LED+ supply with respect to chassis ground. The return voltages i.e the LED- varies from 2.2V to about 1.6V (is that normal?) After running for about 20 seconds the back lights switch off and the LCD is still working (Flashlight test)
    I opened up the panel and observed all the LED's they all lit up properly ran for a short while and then switched off all together. I did not notice perhaps a strip going off first nothing. My question is, is the protection circuit so fast that you can't see a bad connection or LED before the LED supply circuit trips?
    Anyway, i checked the LED driver IC and got its datasheet and saw that this chip has plenty of protection. Things like LED over volt, LED under volt, Thermal and Open LED protection.
    I measured around the IC by soldering a thin wire to a circuit and then starting up the TV and then suddenly the LED+ voltage went to 38V. The LED's are now barely visible but are glowing slightly. I scoped the driver voltage waveform and it seems that the LED driver chip is driving the LED circuit at minimum duty cycle. I dont know what i did wrong. I am 100% sure that i made no short circuit. It feels like the LED driver circuit was faulty and now failed completely. I do have a circuit diagram for this board...
    I still have to look at the drive voltage for DIM or ADJ from main board but dont know what to expect there.
    As a test i tried to measure on each branch of LED strip what the current draw is and coupled my ammeter in series with one of the branches but the power supply did not like that and shut down the back light voltage immediately. Don't know why it responded like that?
    Any help as to where i can start or measure?
    Regards
    Angelos
    Re: Sansui 55" LCD T V Model STY0955 (Backlight issue)
    You have 6 LED strings with 6 LED driver controllers, so when it stops working what do you get on each one of the LED -?
    Please also provide good clear straight shot pictures of the Top and bottom side of the power supply board.
    You need to also provide the Voltages of each pin of the connector of the power supply that goes to the main board when the TV is working OK and when it is not, make sure to provide the pin name follow by the Voltage reading for each pin.
      Will do and revert back to you. For now i had to close the unit to do other work.
        Hello Budm,
        I will probably get to this set on Saturday but in the mean time i was wondering if you can assist me in understanding how this power supply interfaces the main boards Adjust pin (I assume this is the back light intensity control) and biases the LED IC's PWM pin. What is the minimum and maximum voltage to bias this LED driver from 0% to 100%. The datasheet does not tell me much. I have added the circuit diagram as well as the LED driver IC.
        BTW, there is no back light user adjustment in the TV menu's.
        Regards
        Angelos
          LED backlight failure is very common in these RCA/Sansui TVs. Backlight can be only set in the service menu under panel settings. With TV on, menu-1-1-4-7 with remote. Default was 80 in one I looked at and I always set to 55 or 60 after backlight replacement/repair.
            I need better and clearer pictures of that power supply/LED driver board, I cannot read the pin names of the connectors.
            Is that the schematic for your power supply board?
            Look at the ADJ pin with the oscilloscope.
              I lost that repair. Client lost patience and took tv.
                It seems i have double posted this thread, sorry. I could not find it previously. Anyway, Client brought tv back to me so we can continue fault finding it. Budm, i have your attention. I will update soon with what you asked for.
                  Here is a close up of the plug pin layout.
                    Yes Budm, the schematic i had attached is for my PSU, i will now scope the ADJ pin and post pictures soon.
