Sony KD60X690E No Video
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Set has backlight and audio. T-con has 12 volts on both channels. Tried cleaning LVDS cable. SMPS has proper voltages as labeled. Main board does react to signal and turn on when HDMI signal is applied. Nothing getting hot on T-con.
    Volume adjusts. No menu. suspect main board. Is there a way to test t-con?
    TIA
    LJ
    Re: Sony KD60X690E No Video
    What do see on the screen if you have one ribbon cable between T-CON and panel connected one at a time?
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      When I disconnect the ribbon cable on the left from the front of the panel I get the first picture with Left half of screen black and right half white showing image outlines. When I hook it back up and disconnect the other one it makes no difference, all black screen as in second picture.
      • budwich
        • Jul 2015
        • 3097
        I don't think I understand... you say that you disconnect the left side of the set and get black with "white" on the connected side. That seems opposite to "expectations".... but may be anything is possible. Normally, a disconnect tcon cable will generate a white screen. Please confirm your tests and check your cable seating as perhaps they weren't properly aligned. If you indieed are getting black screens as indicated, then it is likely that you have a problem with the bottom edge boards.... perhaps a short or open smd component.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Looking at the set from the rear, when I disconnect the cable on the right, it produces the first picture. When I hook it back up and disconnect the cable on the left, I get the second picture.
          • budwich
            • Jul 2015
            • 3097
            hmmmm ... you might want to remove the front bezel so that you can look at the tabs along the sides to see if you can spot any issues there.
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              You were right on the money Budwich. I found one tab unbonded totally.
              Another one for the pile. Aaargh. Manuf Date is Nov 2017
              Junk!
              Thanks for the assist.
              LJ
              • budwich
                • Jul 2015
                • 3097
                BUT wait.... unless you are trying to get a "resell" or "repair for money"... the set can likely be saved / restored by removing the tabs along the side that is bad. This is the "standard method" for side issues that have bad tabs whether they are "burnt" or "broken" / "detached". Of course, it depends on your objective.
                That is also assuming that you are showing a side tab and NOT a tab along the bottom of the panel which can't be removed.... then the set would be trash.
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Was looking at it for a friend..who watches it all the time. Sounds like removing the side tabs is a temporary reprieve. Tab shown is top right corner facing screen.
                  • zomi
                    • Nov 2011
                    • 505
                    Its still worth doing as they may well still get a good few years out of the set with the tabs removed.
                    even watching it all the time.!
                    • budwich
                      • Jul 2015
                      • 3097
                      well, if the "operation" works, the tv will likely be useful for a long time.... as in years, not days or weeks. Your friend will potentially not even notice a difference unless they have "golden eyes". I would say hundred of tvs have passed thru this forum with this type of "work" to save them from the garbage.
                      I personally, did this on a sony 46xbr4 as it had a connection problem on the corner tab... top corner (as edgeboards are on the top on this sony).... I used the set in for rec room video.
                      Relooking at your last picture, if the tab bond was basically a "manufacturer defect", the contacts might be marginally contacting which isn't good for overall operation depending on which contacts actaully get made. Rather strange... how old is the set?
                      The one question that I have, is how did this tv get to this state... someone had to be doing something to cause a tab to be like that... possibly only did a "part of the operation". How many tabs are along the side? Take a close look at the tab / edge boards at the bottom / top of the set... I suspect someone was in this set before you.... maybe. You could possibly try some pressure padding on the tab to see if things change any but I would be concerned that the contacts, once disturbed may not align which could cause further damage and take out other circuits / components if not "pressured back" in the exact position.
                        • 12145
                        • U.S.
                        If this is the case then probably best to just finish the "tab operation" should have usable tv after that.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          I think this is the same model of Sony TV that my sister rented back in September, 2018, before having it returned, because it reportedly failed to respond to power button:
                          https://www.badcaps.net/forum/showthread.php?t=71916
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Junk!
                            LJ
                            This looks possibly worse than pre-Hisense-Sharp, IIRC! Yikes! I see what looks like shit COF!
                            Arc A770 16 GB
                            • jjanssen7
                              • Nov 2012
                              • 252
                              Was the picture in post #7 of the unbonded tab? Because that looks normal to me. The piece that is disconnected is just a piece of tape, the tab/cof looks normal?
                              • Hakuu
                                by Hakuu
                                Hi There,
                                More Details
                                TV Model - LG OLED77G1PUA
                                07-12-2023, 02:37 PM
                              • Daren87
                                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                by Daren87
                                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                08-13-2023, 03:25 PM
                              • thelankanguy
                                Sony KD-55X9000F TCON Issue
                                by thelankanguy
                                The TV shows a black screen with no image.
                                TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                Later both ribbons were disconnected and TCON voltages were tested.
                                12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                There is also a short to ground in this circled inductor.
                                Is this a TCON issue or something else ?...
                                12-13-2024, 12:27 AM
                              • bbrain
                                Sony KD-55AG9 TCON?
                                by bbrain
                                I have this problem with my Sony 55' AG9.
                                It flashes 4x.
                                I have found the service manual, and seems it is the TCON.
                                Before I buy a TCON can someone check the vid?
                                Thanks in advance!...
                                09-19-2024, 10:50 AM
                                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                09-12-2024, 02:00 PM
