RCA LED65G55R120Q No Backlight
  • zacheriaj
    • Jan 2014
    • 138
    hello, I picked this TV up for free and started to diagnose it. I assume either a main board issue or shorted LED's. When I power it on, my voltages come up correctly and the LED's light for a split second. Then the entire system shuts down. No voltage anywhere. I assume shorted LED's forcing the PSU into protect so I disconnected the LED connector, powered on again, and the same issue occurred. Voltages came up for a second and then everything shut down. Any ideas?
    You Can't Succeed Until You're Willing to Fail
    • 12322
    • U.S.
    Re: RCA LED65G55R120Q No Backlight
    Try disconnect powerboard from mainboard, turn it on see if backlight come on and stay on, always good practice to have tv unplugged from wall outlet before unplug any connector then plug tv in and try.
      Pictures of what we are dealing with will help.
      • zacheriaj
        • Jan 2014
        • 138
        What connection should I remove on the main board?
          "When I power it on, my voltages come up correctly and the LED's light for a split second."
          So what DC Voltages do you have on the control pins of the power supply board connector CN2: ADJ, BK, and PS?
          What Voltages do you have on the LED connector pins with LED connector in place? You need to leave the probe on each pin and then Turn on the TV to see how high it goes up to then wait 5 seconds to see how low it goes down to, do that on each pin of the LED connector, black probe on the chassis GND, you have two LED (+) and two LED (-) so 4 tests total.
          • maxvalutech
            • 804
            • australia
            Voltage checks are a must as budm has indicated. A year ago I had set from friend of friend with similar problem except logo displayed. Power board and LEDs checked out OK by forcing them on. That left me with likely eeprom corrupted on main board. That set 65" Polaroid similar to RCA was recently given to me and I will first be trying freeze spray on the eeprom.
            • zacheriaj
              • Jan 2014
              • 138
              Sorry for the delay. I'm in WI and its been a rough week! Finally got voltages for you.
              PS-5Vs: 5.1v always
              ADJ-BK: 1.6v when turned on, drops to 0
              5V+5V: 4.9v once powered on, then drops to 0
              LED Connector (left to right)
              +: 285V drops to 0 in five seconds
              -: no reading
              +: 135V drops to 0 in 5 seconds
              -: no reading
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                This is the typical Backlight failure issue.
                • zacheriaj
                  • Jan 2014
                  • 138
                  I assume the low voltage string is bad?
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    The higher voltage string is showing the same symptom. By displaying 0V on the both (-) pins say the Backlights are faulty and if you want to fix it then you would have to open up the Panel and test the Backlight Strings.
                      PS-5Vs: 5.1v always
                      -: no reading
                      -: no reading
                      You count the pins wrong for the connector CN2. It has 18 pins total. The expose pins you see from the top side of the board are ODD number pins, the even number pin you will have probe from the bottom side of the board or via the wire entrance side of the connector.
                      Pin name assignment for example: Pin 17 is ADJ (DIM control), Pin 18 is BK (BL-ON).
                      1) So to troubleshoot the problem we will need correct data first.
                      2) I need the pictures of the bottom side of the power supply board to see if the two LED strings are connected in series or not.
                      This looks to be the same as your board:
                      https://www.shopjimmy.com/rca-re46hq...led-board.htm#
                      RCA RE46HQ2120 Power Supply / LED Board
                      • RRice25541
                        • Nov 2015
                        • 47
                        Hi, Any chance someone could post some high resolution pictures of the solder side of the power supply RE46HQ2120.
                        • pni
                          Backlight panel diffuser melt by backlight leds broken
                          by pni
                          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                          10-12-2025, 12:08 AM
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
                        • hollox123
                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                          by hollox123
                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                          1. Laptop keyboard doesn't work
                          2. The backlight on the laptop keyboard doesn't work
                          3. The x2 side LEDs (red) on the laptop don't work
                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                          05-11-2025, 08:05 AM
                        • signal.quest
                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                          by signal.quest
                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                          03-17-2024, 10:14 AM
                        • lmcancu
                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                          by lmcancu
                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                          Instead of putting it back together I decided to replace...
                          04-01-2023, 01:11 PM
