LC65lE654u no power
  • charlie555
    • Feb 2018
    • 76
    • usa
    LC65lE654u no power
    When first recived this tv I had a light blue standby light. Unplugged power removed left side ribbon cable to the t-con board and now no standby light showing. Reset everything back to where it was and checked voltages. Getting all led power 86v. As far as voltages to mainboard pins 1,2,3 19 volts4,5,6 ground pins 7,8 0 volts pin 9-ps on 0v pin 10 0 volts. Checked main board caps getting different readings with same cap values 220uf 25v
  • nomoresonys
    • 12276
    • U.S.
    Re: LC65lE654u no power
    Test all pins on connector from mainboard to powerbard on powerboard side, all board connected. Test in standby/plugged in but off, then apply power report both conditions, example: pin 1 bl-on=0 volts standby and 3.3 powered on, report results for every pin.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      There is no STBY voltage on this PSU. There is 19V going straight to the main board. So your problem has something to do with that main board. The lower voltages are all created on there. If you look, there are a bunch of buck converters. Check them all.
      • charlie555
        • Feb 2018
        • 76
        • usa
        What are buck converters?
        • nomoresonys
          • 12276
          • U.S.
          " pin 9-ps on 0v" Check this pin with tv powered on, if no voltage, looks like the mainboard is not sending ps-on signal.
          • charlie555
            • Feb 2018
            • 76
            • usa
            Ok thanks will try when I get home
            • charlie555
              • Feb 2018
              • 76
              • usa
              Could it be the caps giving different readings they are the same value should they not be giving similar readings?
                You cannot accurately check the cap's capacitance while the cap is still hooked to the circuit, there are other component that are connected to the cap so the reading will not be valid.
                • charlie555
                  • Feb 2018
                  • 76
                  • usa
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8327
                    There is 19V going into the main board. However there is no way that the main IC, ram, flash etc. run on that voltage. Some thing has to convert the 19V down to 5V, 3.3V etc. to run all these IC's (buck converters, LDO's, regulators). So it could be that the main IC is dead, because it doesn't get any voltage.
                    • charlie555
                      • Feb 2018
                      • 76
                      • usa
                      That makes sense, so I guess I have to order a board.
                      • charlie555
                        • Feb 2018
                        • 76
                        • usa
                        “9LE366502120395” Does anyone have a main board ? To a lc65le654u
                        • stylishconsultant
                          un60j620dafxza - Samsung No Display Problem
                          by stylishconsultant
                          Hi All,
                          Need help.
                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                          09-04-2024, 03:26 AM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • AleMonti
                          LG 55EG910V - no power and no standby light
                          by AleMonti
                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                          After checking the basics I did the following:
                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                          11-04-2024, 05:02 PM
                          09-06-2024, 05:59 AM
