Sharp LC-80LE757U - Click - shuts off
  • jason123
    • Oct 2015
    • 1154
    Hi there,
    Hopefully someone has some experience with this TV - yes, it's a mammoth 80" in decent shape other than the plastic falling apart where the screws attach the back cover to TV.
    So, when I got it, the TV simply clicks almost every few seconds, small click then another (relay actuating and disarming)
    I disconnected LEDs to power supply, and the same clicking. Clicking goes away when i disconnect the mainboard (as nothing is turning the TV on)
    I started disconnecting the IR, Wifi,.. to the Main board, and voila.. the TV starts up, I can see beautiful screen with menu and backlight, then it dies (clicks) again, and the cycle continues. I can connect all cable to main board again and it does the same cycle. Seems like it just needed a little push to get in the starting up mode.
    I'm guessing there is a deterioration to the power supply board, causing it thermal / over-current shut down. All rails seem to come on on the power supply with the "On" click happens for few seconds. PNL12 V is running at 11.74 V. UR13.2 is running at 13.03 V. 5 is running at 4.92 V.
    Thoughts?
    • 12322
    • U.S.
    Re: Sharp LC-80LE757U - Click - shuts off
    Weak capacitor? maybe try hitting the caps with some heat, see if anything changes.
    • jason123
      • Oct 2015
      • 1154
      Thanks nomoresonys .. would that show up as a cap with high ESR? should I start there maybe?
        • 12322
        • U.S.
        Yes, if the heat decreases the esr and tv starts working, you found a bad cap, can add a little heat to the little blue ceramic caps too, looks like a reddish colored ceramic cap there by the sticker, a hair dryer works pretty good for testing. Might be a different problem but that test is easy and don't require a lot of labor.
        • jason123
          • Oct 2015
          • 1154
          You're right on my friend.. TV works beautifully with blow drier aimed at the area. Now pinpointing that cap is a challenge. I can find all the caps in the region on Digikey, but that red one, how would you test that?? it's a poly film of some sort.
            • 12322
            • U.S.
            Hmm, you said big tv with crumbling plastic, might be best to replace all the electrolytic caps in that area so you don't have to go back in there, the ceramics are more robust, they might be ok, those polyfilms do go bad, might be a good idea to replace or test on a esr meter.
              Verify that the AC_DET signal is OK or not when it acts up,
              • jason123
                • Oct 2015
                • 1154
                AC_DET does not seem to be holding at 3.3 V.. it's running at 0.5 V, then spike up then down..
                  That is the problem, more likely the Opto couple problem in the AC_DET circuit.
                  When you heat up the power supply board you need to do localize heating, may be you ending up heating the opto.
                  The standby Voltage, PS-ON, ect. are stable for sure, correct?
                  • jason123
                    • Oct 2015
                    • 1154
                    The BU5 is the one I looked at and it's solid at 4.92 V. The PS_ON coming form the Main board is stable, but it goes away as soon as STB shuts off.. so it follows it. Any idea which is the OPTO for the AC_DET? or do I need to follow the trace from the connector? Thanks
                    • jason123
                      • Oct 2015
                      • 1154
                      Any guidance on resolving this issue, budm, or anyone who's experience with the AC_DET troubleshooting, would be greatly appreciated! thank you
                        Since you are able to heat up the power supply board and able to get the TV to work, so just try heating up just the Opto's only and see which one will make the TV working again.
                        • jason123
                          • Oct 2015
                          • 1154
                          Thanks.. I used a blow drier and the optos are so close together that focusing on just one at a time may not be possible. I may have to trace the connection to a specific opto. I tried continuity test (since I don't have access to traces (single layer board) with board installed), but wasn't able to find the direct connection (from AC_DET to any of the opto pins in the COLD side)
                          The question is.. is the Opto circuit a simple current path from AC (or rectified) that pumps into the LED part of the opto and AC_DET is just the other side of the opto or is there more to the circuit? Could it be something else in the path? Because if not, then I can go ahead and replace all the opto couplers on the board for ease of fix implementation.
                          • jetadm123
                            • 2169
                            With the power supply unplugged, you can try to isolate the offending opto by cutting out a small piece of metal from an aluminum soda can. Place the metal over an opto and hold one end with your pliers and the and place your soldering iron tip over the aluminum piece. Once the opto is warm enough you can plug in the supply and give it a go. There are also several YouTube vids on how to check opto's. And of course there's the shotgun approach, which is replacing all 3 opto's. They are readily available and cheap.
                            • jason123
                              • Oct 2015
                              • 1154
                              Thanks jetadm123... all very helpful and I can try the aluminum piece trick.
                              I guess I wanted to be sure it's the Opto failing and not another peripheral that's in the AC_DET circuit.. I'm not sure what the circuit looks like as I haven't been able to find a schematic. I could reverse engineer it I guess too.
                              • jason123
                                • Oct 2015
                                • 1154
                                replaced all 3 Optos, and no change. I tracked the AC_DET to the first opto on the right, but that didn't do it, so I replaced all 3, and no luck. Thoughts?? I can't seem to heat up one component and get it to behave, but if I heat up the whole area, it seems ok.
                                • jason123
                                  • Oct 2015
                                  • 1154
                                  I would like to work on this power supply board out of the TV, as I received a replacement power supply board and the TV is working fine. I tied PS_ON, and PNL_POW to STB, but the relay is not clicking (turning on). Do I need to connect anything else to get the board to turn on so I can troubleshoot this? Thanks
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    ok... so you now have a working board and tv. maybe not "zipped up"? with the power off / disconnected, take some "strategic resistance" measurements of the two power cards to see if you can spot anything (ie. capacitor, resistor, switching ic /fet) to narrow down your effort.... and then go watch the big tv ... :-)
                                    • jason123
                                      • Oct 2015
                                      • 1154
                                      Thanks budwich :-)
                                      I couldn't really spot any differences worth nothing. resistors are off, some higher, some lower by 1% or so. TV is awesome!
                                      • jetadm123
                                        • 2169
                                        Possibly a bad solder joint?
                                        • goldbird78
                                          LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
                                          by goldbird78
                                          Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
                                          02-17-2021, 08:45 PM
                                        • FALKLAN
                                          Running Line Voltage and Integrating LED Pods - Automotive
                                          by FALKLAN
                                          Howdy everyone! I hope all is well where ever you are!
                                          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                          02-05-2025, 12:30 AM
                                        • huzo
                                          HP Omen shuts down when loading OS
                                          by huzo
                                          The model is 15ec-1061nm
                                          Board number is DAG3EDMB8D0​
                                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                          10-29-2024, 12:05 AM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • brav1ez
                                          ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
                                          by brav1ez
                                          I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
                                          I’ve tried:
                                          - CMOS reset
                                          - Removing the SSD/HDD
                                          - Reseating RAM (removing each stick individually stops boot completely)
                                          - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
                                          With...
                                          09-07-2025, 10:47 AM
