Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
Tags: None
Re: LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
Have a look at the components in this repair kit and check the parts on your power supply.
http://tinyurl.com/1a2204s7Willing to help but I'm no expert.Comment
Check all new parts and they match old, also checked with meter and all are good. Thx
http://tinyurl.com/1a2204s7Comment
This is a weird one, as mentioned below I checked and replaced the below components and put the the board back in and it did the exact same thing. As suggested I removed the board, reinspected and checked the complete board for cold solder joints and none were found. The board was a little dusty (I have seen much much worse) so I gave it a good dusting with a paint and tooth brush and put the board back in. Now the TV stays on now without issues, I have given it two tests for over 8 hours each. Is it possible there was some dust shorting out something on the board ??
Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. ThxComment
by huzoThe model is 15ec-1061nm
Board number is DAG3EDMB8D0​
SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...10-29-2024, 12:05 AM -
by Giggle2562Hello everyone,
I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
Here's what I've tried so far:- When the internal display is disconnected, the laptop works perfectly fine via HDMI.
- The laptop shows an image on the internal display for a few seconds before it shuts down.
- I tried swapping the LCD panel with a known good one.
- I tried swapping the LCD cable
by riko 656Hello everyone,
I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
Laptop Model:- Model: Lenovo Legion Slim 5 16APH8
- GPU: NVIDIA GeForce RTX 4070
- Main BIOS chip size: 32MB
- VBIOS chip size: 16MB
What I Have Tried So Far:- I
11-04-2025, 05:14 AM -
by brav1ezHello everyone,
I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
I’ve tried:
- CMOS reset
- Removing the SSD/HDD
- Reseating RAM (removing each stick individually stops boot completely)
- Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
With...09-07-2025, 10:47 AM -
by GRANDGGHi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
- Loading...
