Samsung LN 40D630 TV - No Power
  • jason123
    • Oct 2015
    • 1068
    Hi Folks,
    This might be a board replacement project, but wondering if other have had experience with this.
    Picked up a Samsung 40D630 TV, no power. No Standby or other voltages on the PS board. The large caps are not reading any DC, and AC is showing 1.5 V
    I found FM801S (cold side) fuse to be open. I replaced it, but no improvement, and the new Fuse is not blowing up.
    PS board replacement, or is it worth troubleshooting the board (ideally, I'd love to, but I never had one with no voltage on the large caps before)
    Thank you
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung LN 40D630 TV - No Power
    Is the fuse on the ac side good? Is your meter working with fresh batteries? Is the ac cord good?
    • jason123
      • Oct 2015
      • 1068
      Valid questions.. yes, the AC fuse is shorted, and I'm reading good AC on both legs of that fuse. Meter is the one I use, and Yes, I use it to measure the AC.
      Cord is good, and that was my first suspicion.. but another good cord shows the same symptom.
      Incidentally, the Power Supply board is BN44-00464A - Can't seem to find schematic for it.
      • R_J
        • 9543
        Remove the power supply and check the solder connections on the transformers like TM801S an components connected to the heatsinks.
        • jason123
          • Oct 2015
          • 1068
          Solder looks ok. They must have some non-conductive coating on the heatsinks. Differential reading on the large caps, shows 162 VDC.. sorry about that.
          Verified again that no voltages are present on the connector to the main board including the 5V standby. So main board is not getting any voltages.
          Diodes on PS boards check out (at least that they're diodes ), no shorted FETs or Diodes that I could find. ESR checks out (low mOhm) on caps around the connector going to Main board.
          Thoughts??
            SMPS IC UM801S OK?, RM811 OK?
            Fuse FM801S is in the HOT side not cold side, is for supplying the Voltage to run the SMPS IC and the inverter transformer driver circuit.
            Are you 100% sure that FM801S is not blown again? It should have 160VDC with ref to the negative leg of the main filter cap in the cold side.
            • CapLeaker
              Leaking Member
              • 8177
              Verify again Pin 16 on CN802 for A5V. That's your STBY voltage. If there is nothing there, look at the standby circuit of the PSU. Also verify Pin 16 against GND (if there is a short or not).
              • jason123
                • Oct 2015
                • 1068
                Not sure how to test UM801s, as i can't read the part number. Chip is in good physical shape and no shorts across pins. RM811 reads ~0.5 OHM. FM801S is definitely not open. Pin 16 definitely does not have any voltage. No short on pin 16.
                I stumbled across some shorts that i don't think are right: DP807 AND CP804 are shorted in-circuit. Thanks
                • CapLeaker
                  Leaking Member
                  • 8177
                  Does this IC on your last picture get power?
                  • jason123
                    • Oct 2015
                    • 1068
                    No, pin 8 referenced to pin 6 (GND) or chassis, does not show any DC voltage (or AC) IC is SEM3040, and according to datasheet, pin 8 is vcc, correct?
                      You look at the wrong IC, the one you need to check is UM801S mounted on the heatsink. UP801S is for PFC.
                      Samsung BN44-00464A
                      https://www.shopjimmy.com/samsung-bn...pply-unit.htm#
                      • jason123
                        • Oct 2015
                        • 1068
                        Thanks budm.. is there a datsheet for this UM801S? which pin is power I guess . Part number is not legible on the IC
                        • jason123
                          • Oct 2015
                          • 1068
                          please, does anyone has a circuit diagram for this BN44-00464A that they can share?
                            You cannot read anything printing on it at all? there must be something legible on it.
                            • jason123
                              • Oct 2015
                              • 1068
                              Ok, got the better scope, and the part number is STR W6052S
                              Looks like datasheet is:
                              https://cdn.badcaps-static.com/pdfs/...d55e88614f.pdf
                              I am not getting any voltages on any of the pins. No VCC voltage
                                Pin 1 D/ST pin should have about 162VDC (if the IC is not switching) through the primary transformer winding which is fed the fuse that was blown earlier.
                                • jason123
                                  • Oct 2015
                                  • 1068
                                  0 dc on pin 1. AC is jumping around 3 to 44 to 2.4 to 0...is it the IC that's bad or transformer replacement you think?
                                  • jason123
                                    • Oct 2015
                                    • 1068
                                    Naturally the new power supply board fixed the problem and the TV is working.. But would love to troubleshoot the Power Supply if at all possible.. if anyone has any ideas, or can share schematic.. I'd be appreciative.
                                    Thank you
                                      Well, you have good board and bad board for doing the resistance comparison readings.
                                      Check that pin 1 of the SMPS IC again, it should have continuity all the way to that blown fuse.
                                      • jason123
                                        • Oct 2015
                                        • 1068
                                        It does.. after taking the measurements yesterday, I guess the fuse did blow again. I also see that pin 1, 3, 5 and 7 of that IC are shorted.
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • repair-it
                                          Need advice testing a samsung power supply board with scope
                                          by repair-it
                                          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                          07-12-2025, 11:00 AM
