Lg 50ln5700 horizontal moving black line on bottom of screen
  • Gdog215
    • Mar 2018
    • 29
    • Usa
    Hello bought this tv with intermittent back light a few months ago and finally got time to work on it. I replaced all the led strips have full clear picture but now slight horizontal line that seems to move on the bottom 3 inches of screen. Already cleaned and reseated lads cables to tcom. Bad panel?
    You live and you learn right?
  • neilc6
    • Nov 2015
    • 1550
    Re: Lg 50ln5700 horizontal moving black line on bottom of screen
    https://www.badcaps.net/forum/showthread.php?t=71885
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4539
      • Italy - Milan
      If you think this it's a not good tv to use as is then you can try this: disconnect one at a time the output flats of the tcon an see wich is the faulty side, with the flat cable of the faulty side connected and image on screen, cut a square piece of opaque tape wide as much as 5-6 rows of pixels high and place it in corrisponence of the begin of the defect and exactly at te begin of the witdth where pixels starts at the side, then switch off the tv and take a sharp cutter and with magnifying glass you have to cut exactly before the first pixels in width starts, if it is too difficult to center the blade it's better if you cut in the center of the first pixel than before its begin, don't make too much pressure, it is almost easy to cut. Unfortunately i can't do this test because i have no cracked screens at the moment with a partial image to make the test on, because the cracked screens i bought are very easy to lost the remaining image cause the cracks runs easily. This job its valid only if your screen has no side tabs. In the truth the best work to do would be to remove the glass foil and flip it because on the front side there's a polarizer film that obscures all the pixels, instad in the back side you can see even the pixels and the gate drivers circuit and where to cut better, it is useful those goggles with magnifying glass and led light that are sold on ebay/aliexpress.
      • Gdog215
        • Mar 2018
        • 29
        • Usa
        when I unplug one side of tcom and than the other see pics
        what does it mean?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4539
          • Italy - Milan
          Yes this is typical of LG screens of today, it's normal, unfortunately in this way you can't judge which side is bad, i don't know what to do... anyway T-con not tcom..
          if there are many silkscreens then post a good clear tcon picture or better link a shopjimmy one that are the best..
          • Gdog215
            • Mar 2018
            • 29
            • Usa
            Here's the t con card
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4539
              • Italy - Milan
              No this is not what i call a good picture.. search its brand and model in internet with image search and post here a big clear picture..
              sorry i've noticed many errors in my post #3, 1. "and" not "an", 2. "which" not "wich", 3. "width" not "witdth", "instead" not "instad"...
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                You might be able to fix this by placing a piece I=of stationery tape 1cm wide on the right (looking from the back) FFC going to the Panel Bd. You would have to try it several times along the width, by trial and error, of the FFC to get the correct spot. It will take some time but a little patience will get you there. This is called the 'CUT-OFF' Method.
                • Biruslapio
                  • Nov 2013
                  • 552
                  • Brasil
                  what does it mean?
                  The right side(facing front) is the only that has an horizontal line on those pictures,also some glowing gradient on the bottom which happens often on panel faults, the left side looks more normal.
                  • budwich
                    • Jul 2015
                    • 3097
                    x2
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4539
                      • Italy - Milan
                      Biruslapio it is not enough as a proof, needed some tests, if you want to proceed as "hoping in God"..
                      • budwich
                        • Jul 2015
                        • 3097
                        there is "no hoping in god". All this means is the OP should focus his efforts on using the "tape cutoff" method on the connector associated with the right side of the panel. It is not a "catastrophic method" as long as they are careful with the connector so "god" won't come into play.
                          • 12330
                          • U.S.
                          Amen budwich, God won't be needed for this little situation.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4539
                            • Italy - Milan
                            Yes maybe the tiny little line that is visible is the true defect, but i had in mind my technique not the tape masking technique, this last is a risky one cause switches off a big part of the screen, furthermore in my case the result is far from perfect vision, it's advantage is that in the first times after it's reversible.
                            • Gdog215
                              • Mar 2018
                              • 29
                              • Usa
                              No matter where I place the tape couldn't get rid of the black horizontal line.
                              Until I watched a movie, the movie had black borders on top and bottom.
                              It looks perfect with the top n bottom black borders. Just gonna give this tv to my parents their Comcast cable box has the up down black borders on every channel.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4539
                                • Italy - Milan
                                This is what i was telling, but unfortunately some stupid people continue on their old road with the same old refrain... tape is not enough here..
                                  • 12330
                                  • U.S.
                                  Now he's calling people "stupid" I would get an infraction for that, hmmmm.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4539
                                    • Italy - Milan
                                    I know few words in english, it is not come anything else better in mind than "stupid".. some people has learned 2-3 things crossed and comes here to repeat them endless..
                                      • 12330
                                      • U.S.
                                      Everyone is "stupid" right? RIGHT here you admit you don't know what to do, then you turn right around and call people "stupid" like you have the fix. Well like I asked before WHERE IS IT THEN???????
                                        • 12330
                                        • U.S.
                                        davi why don't you put up a youtube video of all these sure fire "techniques" you know of that fixes everything???? or are you just a frustrated little would be "inventor" of techniques???? YOU are "smart" enough to figure out how to do a youtube video right??????
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                        • labello
                                          Lg43UJ620V horizontal line
                                          by labello
                                          Hi guys I have this tv and in one side of the pannel it shows some line i also cleaned the camble notting, although I found an smd capacitor on the pcb (there's no tcon on this model) but I can't find the same model thanks
                                          02-20-2025, 02:52 AM
                                        • labello
                                          by labello
                                          02-20-2025, 02:45 AM
                                        • kdaniel
                                          Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                                          by kdaniel
                                          As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                                          There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                                          After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                                          Left...
                                          11-16-2022, 09:23 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
